Question about Kenmore Washing Machines
Washer will not hold water.
Water will not stay in washer tub - keeps draining - I cannot find my operation manual. please help.
  • Kenmore Master
  • 3,463 Answers
It sounds as though your drain outlet hose is too low, and the water is syphoning out as it is filling.
Lift the hose higher, and see if that solves the problem, if it does not. then it sounds as though the pump is on all the time, and you will probably have to call an engineer.
Plz rate my solution.
Thanks.
Posted on Jan 04, 2009
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
Kenmore 70 series i installed my washer yesterday but im having a problem the water will stay in the tub of the washer it just rushes out the drain in the back washer what can i do to keep the water in...
Hello, Welcome to FixYa. The drain hose coming out the back of your washer must be placed in a stand pipe or wash-tub to the highest water level of your washer, otherwise it will simply drain/siphon out as quick as it fills. I suspect you likely have the hose lying on the floor or shoved into the stand pipe too far or too low in some manner. Let me know how you make out or if you require more help. Good luck and thank you for choosing FixYa. Please take second to rate the info I provided here today. Regards, Macmarkus :)
Dec 05, 2010 | Kenmore Washing Machines
Hot Point Washer will not drain water from tub.
my old hitachi washing machine PAF-760P was not used for a long time.I started yesterday, it started washing but when the knob rotates and goes to drain the water,it only clicks and does not drain the water. What must be wrong with it. can you help please.
Jul 28, 2009 | Hotpoint Ultima WF860 Front Load Washer
My washer will not keep water in the tub. The
Hi, You need to make sure the drain hose is as high as the top of the washer. If the drain hose is to low, the water wil drain out before it reaaches the proper water level.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 15, 2009 | Maytag PAV2300 Top Load Washer
Washer will not drain after washing and just stops and stays idle
Hi
If your washer won't drain, check these:
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 05, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Washer stays in wash cycle-will not drain or spin
Jun 23, 2009 | Kenmore Elite 45986 Front Load Washer
Won't drain, cycle keeps on going
May 20, 2009 | Washing Machines
Water will not stay filled in tub on rinse cycle
It sounds like a siphon issue.
Check that the drain hose does a high loop before it goes into the drain pipe. (ie. drain hose loops above the water level inside the tub). Make sure the drain hose is not pushed too far down into the drain pipe. Also if the drain hose is sealed to the drain pipe this will create an airlock and a siphon will occur, allow air to enter between drain hose and drain pipe connection.
This should help you but if there is still a problem let me know and I'll try to assist you further.
Mar 21, 2009 | Maytag Washing Machines
Washer not draining water
It won't drain If your washer won't drain, check these:
May 29, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washing machine
hi friend,
hoses
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
May 18, 2008 | KitchenAid KAWS850L Top Load Washer
Washing Machines Logo
29 people viewed this question
Sal De
fordexpert
Robert Rankin
