Hello, I have a candy grand O gofs262 and I am having problems when it is spinning it can't build up speed to reach the proper speed so just stops. How can I fix it ??
  • 38 Answers
U need a new clutch. google model number and then order proper clutch
Posted on Nov 02, 2012
  • 25 Answers
SOURCE: Spin problem on Candy CN450 Washing Machine
nice
Posted on Dec 14, 2007
SOURCE: my smart drive is not reaching full spin speed on spin cycle
You are right with your last comment. Laying the machine on its back is a no no. It allows the residue water in the bowl to possibly travel up the small plastic tube and enter into the water level sensor on the main (computer) control unit. It only takes a very small amount of water and it upsets the sensor so that the machine may not go through its cycle correctly. The water (depending on model) is extremely difficult or impossible to get out.
This may cause the machine to think that the bowl is not completely drained and so it will not go into full speed spin. Other problems may occur as well.
Bear in mind also that that a number of machine models do not go to full speed spin on a water temperature setting of warm or higher. When checking for high speed spin put your water temperature control down to cold / warm or cold.
Check also that your machine is sitting level ( the bowl is sitting centre in relation to the top shroud. If the bowl is leaning toward the rear of the machine when you look down into it, the ability to spin may be affected. There is a lever behind the bowl which activates a switch if the bowl comes in contact with it (when the wash load is out of balance) to stop the spin. The switch can also be activated when the machine is not level.
If your problem persists you may have to get a replacement main contol unit. If you are a little savey at technical things you may be able to get a discarded control unit from your local tip or recycler and recover the water level sensor for a change over. This may involve soldering though as well as precautions concerning stored electricity in the control unit capacitors and precautions about static electricity from your body or solder iron destroying other electronic components on the main control unit.
Hope this helps.
Posted on Mar 28, 2009
  • 464 Answers
SOURCE: Hello experts! Kenmore is slow to spin
you may need to replace the direct drive coupling. this part consists of 3 pieces, an inner rubber piece sandwiched between to nylon pieces. it is situated on the shaft of the motor. it is a wearable part and also an inexpensive part to replace. if you are handy you can do this yourself. hope this is a help to you.
Posted on Oct 14, 2009
  • 6277 Answers
SOURCE: Need to get a pdf user manual that I can download
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
May I also suggest you try the manufacturer's web site direct?
Good luck,
John C.
Posted on Mar 30, 2011
  • 6277 Answers
SOURCE: I have 3 problems with my maytag washer (don't
Providing your particular model has one I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter- so many 'faults' are caused by blocked filters.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Oct 08, 2011
I cannot get my Candy GOFS262 on a 'SPIN ONLY' cycle? It just fills with water, drains and spins? I only want to spin some already wet laundry - HELP please?
this is a problem with these machine turn the selector anti clock wise slowly to spin as the contacts on the selector wear out or try clock wise but slowly some times this works
Jan 31, 2015 | Candy Washing Machines
Washing machine does not work on any program though stop light and spin speed light are flashing t
The stop light and the spin light flashing are acting as an error code. Have you tried to google what this means? here is a link to candy error codes for that machine...
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3319-candy-grando-washing-machine-series-fault-codes.html
hope that helps
Jan 15, 2014 | Candy Washing Machines
Candy Grande o, stain vanish and 90 min light flashing
Try to find error codes on the Candy website.
Dec 20, 2013 | Washing Machines
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
Candy gofs262
BRUSHES ARE IN MOTORS STARTING MOTOR ALTERNATOR
Sep 25, 2012 | Cars & Trucks
HI: My washer will not drain all the water out at the end of the wash can you help me out
Hello there and thank you for choosing fixya
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Aug 04, 2011 | Frigidaire Washing Machines
Candy grand o not spinning when loaded
Kindly replace the motor to solve your problem
May 17, 2010 | Washing Machines
Candy GrandO 8kg Erratic Cycle Selection and Flashing Lights
I can't solve this problem but have exactly same problem with erratic lights. I 'm starting to worry about possible explosion.
Mar 12, 2010 | Candy Washing Machines
Loud Loud Noise and a jumping machine on spin mode
hi it may be the belt problem ...better to change it thank u....
Jun 03, 2009 | Candy Washing Machines
Washing Machines Logo
184 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
