Question about Juki DDL-8300
Juki straight stitch upper needle broken off and stuck.
I have a Juki straight stitch and in a rush to remove a broken needle, I accidentely broke the needle off in the machine. The top piece is still up in there. How do I rememove it/
You could try to pull it down with a magnet or see iff it will stick to some blu tack and pull it out with that.
Posted on Nov 02, 2012
SOURCE: juki stuck needle
check settings
Posted on Apr 28, 2008
  • 48 Answers
SOURCE: there is a wrong way and right way to insert a new
-If your bobbin case is inserted from the left side of the machine, then the scarff( indentation on the back side of the needle ) should be on the right side as you insert the needle.
drtension
Posted on May 02, 2010
madelinesalo
  • 59 Answers
SOURCE: Juki DDL-553 and adusting stitch length
to adjust your stitch, just move the wheel there is #. change the number.
Posted on Mar 26, 2010
  • 43 Answers
SOURCE: skip stitch
The three most obvious causes (other than that of the machine possibly being slightly out of time) are:
1) Too small of a needle size - increase the size.
2) A needle that has a flaw / defect - change the needle.
3) Needle not inserted correctly, either not pushed all the way up into the needle bar, or not installed facing the correct place. On this machine, the small "scarf" in the needle (an indent just above the eye) shouldface the right side of the machine.
Posted on May 07, 2009
SewTechWayne
  • 186 Answers
SOURCE: Needle Thread breaking after about 30 seconds of quilting
Make sure the feed dogs are dropped (or feed dog cover is on - I can't remember which way this machine works). The stitch length on the machine has no function so ignore it. (I set it to zero so the machine doesn't have to work as hard). Hopefully this is all that's wrong. If not, use a shorter setting for the stitch length on the regulator, oil the hook and move slowly and smoothly.
Posted on Jan 31, 2009
I am a swimwear designer and just got a juki ddl 8300n did I pick a good machine? How can I adjust the machine for a more stretchy stitch?! What number should my stitch dial be on to get a stretch?
Perhaps a manual would be helpful:
File JUKI DDL 8300N Instruction Manual pdf
You should probably contact the manufacturer with questions. Hopefully, you did some thorough research before purchasing this machine. From the info I found, it appears to be a straight stitch only machine. I don't know anything about this machine, but I would be hesitant to purchase a straight stitch machine for sewing swimwear. Usually, swimwear needs a stretch stitch or zig-zag capability. Just my thoughts...
Amazon com Juki DDL 8700 Industrial Straight Stitch Sewing Machine Arts...
Juki DDL 8300N Industrial Single Needle Lockstitch Sewing Machine with...
JUKI DDL 8300N Straight Stitch Industrial Sewing Machine With Table Lamp...
Nov 21, 2016 | Juki Sewing Machines
We got Juki DDL8100E. Few days ago. when sewing, needle broke and since then our machine is making heavvy noise. Also, the Stitch adjuster knob is vibrating up and down. please help
check that a bit of the broken needle is not interfering with the bobbin case movement
if the breakage was hard enough it may have altered the needle / hook timing which will cause a knocking sound as well
Aug 20, 2016 | Juki Sewing Machines
Can I adjust the timing on my Juki TL-2010Q myself? I need realy detailed directions!
Have you replaced your needle first. Sometimes simply a new needle will do the trick. That Juki being a straight stitch only machine make it simple. When the needle reaches its lowest point and then starts back up about an eight of an inch. The point of the hook should be slightly above the eye of the needle and be directly behind the needle shaft.
Feb 02, 2016 | Juki Sewing Machines
Needle breaking
The most common problems that cause broken needles is a thread tension that is too tight and the machine needle/hook being out of time.
Nov 25, 2015 | Juki DDL-8700 Industrial Straight Stitch...
How do I stop my Juki DDL-8700 machine from skipping stitches?
set up on quilting table? wheres the oil pan?? if your machine sews fine straight and skips on curves i think you are lifting the presser ft as you make the turn. theres nothing wrong with the machine. you could always change the needle which is always the first thing when you encounter a sewing problem.
Oct 08, 2014 | Juki DDL-8700 Industrial Straight Stitch...
Why wont my Juki DDL-8700 form a stitch?
machine is out of time and u probably have burrs on the hook since you broke the plate with a needle probably from pulling fabric and bending the needle. you instruction manual will tell u how to time machine and its really very simple. all u have to do is take off feeder plate, loosen the 3 screws that hold the hook then lower the needle with the wheel until the needle just starts to rise. bring the loose hook point to i/16 " fron the needle and tighten hook screws. machine must be tilted back to do this whole operation. it helps to have a short screwdriver to tighten the hook screws. remove burrs with lite emory paper stroking in the sale direction as the hook.
Jun 25, 2014 | Juki DDL-8700
My wife broke several needles on her Juki DDL 555 machine and I need to know how to adjust the timing as she put a new needle in and the point was damaged
First thing to check is if you've got the right needle system: http://partsbooks.sewingmachine.com/Instructions/Juki/Industrial/DDL-5550%20&%205530%20Instruction%20Manual.pdf and that the needle is correctly oriented... the scarf has to be precisely set.
The next things I'd check are the stitch cycle -- hand crank the machine through the normal stitch cycle and see what's hitting. Then fix that. I've got my suspicions this may be a needle bar height adjustment. Don't thread up for this test... misthreading can also cause the needle to hit something and break, so start with the fewest possible variables first.
Feb 18, 2014 | Juki DDL-5550 Industrial Straight Stitch...
The bottom stitching looks like a line and not stitches the top stitching is fine
try adjusting the top thread tension and see if that helps
also try changing the thread.
also change the needle--make sure it's the right needle for the fabric
being sewed.
Dec 13, 2012 | Juki DDL8300N Sewing Machine
Needle broken
hi there
first please make sure you are put the needle to the end top in the needle bar.
second check timing between needle bar and hook is it correct or no?
juki lock stitch machine used two type from needle ( DBx1 and DAx1 ) please mak sure you are use the correct type for your machine,
best regards
ashraf abozid
aabozid@hotmail.com
Nov 03, 2010 | Juki DDL-8700
Loose stitching underneath. HOW CAN I FIX!!!!
Sounds as though you may have a burr or rough spot on the hook where the bobbin inserts. Run your finger along the edge of the hook to see if there are any rough spots.I'm sure you're going to find at least one from the time you broke the needle.Once you locate it, remove it with an emery stick or small sharpening stone. Polish it so that it is smooth. Should work okay.
sewman7
Jun 27, 2008 | Juki TL-98Q
Juki DDL-8300 Logo
73 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
Derek Massey
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
