Question about Hanns.G Corporation HW191D 19" LCD Monitor
Hanns g hx191d no picture. My monitor went black while I was working, the green led is lit, I get a picture for a split second when I first turn on the computer or monitor.
I have tested both the power cord and the video cord on another monitor. I have also tested the monitor on another computer with the same results.
  • 1,684 Answers
The most common cause of this type of display issues is a failure of the back light power supply. There are parts called capacitors that fail and this causes the power supply to not be able to put out the correct voltages to operate the monitor. You cn repair the monitor easily by replacing the bad capacitors on the power supply board. The old ones need to re desoldered and the new ones soldered back in place. You can get a kit of the proper capacitors to do the repair here:
http://www.ccl-la.com/catalog/product_info.php?products_id=194
Posted on Nov 03, 2012
4 Suggested Answers
  • 70 Answers
SOURCE: hanns 17" LCD MONITOR
internal power supply failure,the AC power supply that powers the backlight fails every time you turn it on. Unfortunatly electronic repair is costly, A new monitor is cheaper.
Posted on Dec 26, 2007
SOURCE: HANNS-G MONITOR BLACK SCREEN JUST FLICKERS
I have the same problem. I leave the computer on for awhile to warm up the screen. I don't know why, that seems to help. I turn off the screen on the bottom right and do that a couple of times. Behind the screen I unplug and plug and unplug and plug the screen in again. After it gets going, it works all day. But at night I like to turn off the computer to rest. So I have to do this every morning.
Posted on Mar 26, 2009
  • 1684 Answers
SOURCE: hanns.g hx191d only green led flickering but no display graphics
Hello Joe,
Your monitor has a power supply that is going out. if you can solder you should be able to do the repair yourself, it involves replacing a few parts but its not that hard to do. Go to our web site at: www.ccl-la.com/badcaps.htm and look at the pictures and repair guides. Open your monitor and replace any capacitors that look like the ones in the pictures and you should be back going. We have a repair guide for the HW173 monitor that should be very close to your model.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Sep 12, 2009
Testimonial: "Nothing to say but THANK YOU VERY MUCH FOR YOUR SOLUTION!!! It was the real problem of my monitor. I wish you a bunch of luck on your business!!"
One day it went black, if I turn it off then on I can see a perfect picture for half a second
If this is a LCD monitor, most likely the invertor or the bulb is not working correctly. If you shine a flashlight at the monitor you should be able to see the image. What has happened is the back light is not lit to display the image. If you are handy at repairing electronics you can swap invertor and bulb from the other monitor if they are the same model and size. It may require some soldiering though.
Dec 07, 2016 | AOC Computers & Internet
Screen colour adjust
Go to link and download the manual.
http://www.hannsg.com/US/EN/Products/LED%20Monitors/Common.aspx?productId=125
Remember that the computer display card can override all manual settings.
Jul 18, 2014 | Hannspree HANNS.G HX191D 19" LCD Monitor
Flashing green led on my hanns-g HX191D
Try it on another PC fIrst.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 15, 2010 | Hannspree HANNS.G HX191D 19" LCD Monitor
Flashing green LED on my Hanns-G HX191D
Common problems on monitors are due to capacitors in the power supply/inverter circuits failed, you need to open it up and look inside for caps with bulging top/seal first and post back what you see so we can guide you further, see failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 17, 2010 | Hannspree HANNS.G HX191D 19" LCD Monitor
Hanns-g 19" HX191d monitor blank screen. Power led is intermittent flashing green. Does not show 'no signal' when powered up alone. Has this monitor died or is there a way to fix it?
This type of issues is caused by parts called capacitors that have failed and are keeping the power supply from starting up correctly. You can rebuild the power supply board by replacing the bad capacitors and this will bring the monitor back to full working order. Here is a link to information showing what parts need to be replaced with pictures and parts list.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_31&products_id=194
I hope this helps you.
BuddyMc
Oct 14, 2009 | Hannspree HANNS.G HX191D 19" LCD Monitor
Hanns.g hx191d only green led flickering but no display graphics
Hello Joe,
Buddy
Corporate Computer
www.ccl-la.com
Sep 12, 2009 | Hanns.G Corporation HW191D 19" LCD Monitor
Hanns 17" LCD MONITOR
Dec 25, 2007 | Hanns.G Corporation HU-196DP LCD Monitor
Monitor flashes image for split second then goes blank but green LED flashes as well
have you checked the capasitors?,if they,re ok then the proublem is one of the transistors it will have the letters DKQA on it ,they control the backlight power
Nov 30, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Hanns.G Corporation HW191D 19" LCD Monitor Logo
616 people viewed this question
Top Hanns.G Corporation Computers & Internet Experts
nm8r
Level 1 Expert
Are you a Hanns.G Corporation Computer and Internet Expert? Answer questions, earn points and help others
