Question about Humminbird 365i Combo W Internal Antenna
Depth indication varies and is usually showing 100-350 ft when actual depth is 1-5 ft.
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 227 Answers
Bottom lock is out not locking to bottom
Posted on Dec 19, 2013
Editor925
  • 285 Answers
SOURCE: My depth finder loses its depth reading at about
You need to set the transducer lower. When at speed, the hull of the ship raises up out of the water and hence your transducer is probably not deep enough at these times to give a proper reading.
Posted on Feb 02, 2010
  • 3 Answers
SOURCE: My 570 quit showing the depth and continues to
I had the same problem. It was the transducer.
Posted on Aug 30, 2010
  • 2926 Answers
SOURCE: the depth digital read out
If you purchased it new, bring it back for an exchange. The transducer is what reads the depth, and is not operating correctly. I'm assuming you tried to adjust the depth tolerance in the menu options and also disconnected battery power and reconnected.
Posted on Dec 04, 2010
  • 4 Answers
SOURCE: my temp is always fine but my depth will be
If you know someone that will let you try your unit on their hookup (same type unit) you may be able to isolate the problem to know if it is in the transducer or the unit. If you have the same results with a different hookup, then you would need to return your unit to our factory for a service check. If a different transducer corrects the problem, please contact me at the following email address and I can replace your transducer for you. sbates@johnsonoutdoors.com
Sharon Bates
Humminbird Consumer Service
678 Humminbird Lane
Eufaula, Al 36027
8-5pm Central Time Mon-Fri
1-334-687-6613 ext. 1202
Posted on Dec 28, 2010
  • 29 Answers
SOURCE: I have a humminbird pmax 170. It does not show
Contact our customer service group and they will be able to help you. There number is 800-633-1468.
Posted on Jan 11, 2011
I want to replace an old microwave from 1988: GE Model# JVM130001. What microwave will fit in that space?
Laura, most any over the range microwave should fit that space. It may hang a little below your height but that should not be a problem.
Jul 29, 2014 | GE Microwave Ovens
The GPS component of my Lowrance Elite-5 Gold is malfunctioning about 50% of the time.
Hey Les, Since you have replace both the unit and transducer, you have eliminated/diagnosed most of your problem.. Its in the wiring... sometime when I am in full GPS mode I get erroneous depth readings..?? Have you tried a different GPS module (the "puck")?
https://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5-7_HDI_OM_EN_988-10647-001_w.pdf
Apr 22, 2017 | Lowrance ELITE 5 GOLD COMBO
When we are deep water (500 ft or deeper) the fish finder will display 3.5-10 ft. and won't show the fish or shows tons of fish. Are we able to set the depth that we would like to see eg: if we are...
Im not familiar with your particular unit but you should be using a low frequency transducer for water over 500'; something like a 50 kHz transducer or a dual frequency transducer like a 50/200kHz for detail with the high freq. but increased depth range on the lower frequency. As far as setting it to 250 ft, you should be able to use the range feature and adjust the maximum to 250'. typically the factory default is automatic so it will caonstantly adjust the range based on the maximum current depth.
May 22, 2011 | Standard Horizon Standard Ff520 Fish...
Bn125a nailer not sinking nails all the way
The depth to which a fastener is driven is controlled by the depth adjustment
knob (A) Fig. 19 below. The depth of drive is factory adjusted to a nomimal setting.
Test fire a fastener and check depth. If
a change is desired, rotate the
adjustment knob (A) Fig. 19: the
adjustment knob has detents every 1/4
turn. Rotate the knob clockwise (see
Fig. 19), to increase the depth of drive,
rotate the knob counterclockwise to
decrease the depth of drive. Test fire
another fastener and check depth.
Repeat as necessary to achieve
desired results. The amount of air pressure required will vary depending on the
size of the fastener and the material being fastened. Experiment with the air
pressure setting to determine the lowest setting that will consistently perform
the job at hand. Air pressure in excess of that required can cause premature
wear and/or damage to the tool.
Good Luck
Nov 26, 2010 | Porter Cable Cable BN125A Factory -...
Dimensions
This model is a 25.6 Cu. Ft.
Height to Top of Hinge: 69 1/4"
Height to Top of Case: 68 3/4"
Case Depth w/o Door: 28"
Case Depth less Door Handle: 32 1/4"
Case Depth w/ Door Handle: 34 7/8"
Depth w/ Fresh Food Door Open 90°: 50 1/16"
Width: 35 3/4"
Width w/ Door Open 90° w/ Door Handle: 42 3/8"
Air Clearances - Each Side: 1/8"
Air Clearances - Top: 1"
Air Clearances - Back: 1"
Approximate Shipping Weight: 360 lbs.
Capacity
Total: 25.6 cu. ft.
Fresh Food: 16.02 cu. ft.
Freezer: 9.59 cu. ft.
Shelf Area: 22.4 sq. ft.
Dec 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Loses the depth after around 60 feet.
Is the transducer face clean? Fouling and barnacles can cause poor depth readings. Also, a low power output from transmitter or poor sensitivity of the receiver (both internal), or a broken transducer cable connection (usually accompanied by heavy noise being painted on screen). With your ear in the water, fairly close to transducer (6-10 ft., you should hear a clear tick-tick-tick sound as it transmits on a medium depth range.. No power adjustment is available in the menus, but the unit does transmit at a slower rate, with wider (stronger) pulses on the deeper ranges.
Sep 14, 2009 | SI-TEX Sitex Cvs106lmkii Color Lcd With...
Furuno 4100 depth sounder shows depth twice what it really is
check your gain setting try auto gain and try manually gaining back to see if it resolves, if yes, send unit in to furuno, if no, ducer is probably at fault.
Aug 01, 2009 | Furuno Ls4100 5" Mono Lcd Fishfinder Temp...
Can you give me the measurements height width depth of the KTRC19KK?
Depth Cab. Width Door Width Cab. Height Overall Height
Model size "A" "B" "C" "D" "E"
STANDARD MODELS
19 cu.ft. 30 3/4" 29 1/2" 29 3/4" 65 1/2" 66 1/4"
21 cu.ft. 29 3/8" 32 1/2" 32 3/4" 65 1/2" 66 1/4"
22 cu.ft. 30 3/4" 32 1/2" 32 3/4" 65 1/2" 66 1/4"
INTEGRATED MODELS
19 cu.ft. 31 1/2" 29 1/2" 30 1/8" 65 1/2" 66 1/2"
22 cu.ft. 31 1/2" 32 1/2" 33 1/8" 65 1/2" 66 1/2"
ARCHITECT® SERIES MODELS
19 cu.ft. 32 7/8" 29 1/2" 29 3/4" 65 1/2" 66 1/4"
22 cu.ft. 32 7/8" 32 1/2" 32 3/4" 65 1/2" 66 1/4"
Jul 07, 2009 | Refrigerators
Humminbird 365i Combo W Internal Antenna Logo
107 people viewed this question
Top Humminbird Boating Experts
Mike Marcotte
Mike Marcotte
Phil Walker
Phil Walker
Steve
Steve
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
