Question about Datacard SP25 Printer
Datacard sp25 printer grinding
When we go to print a card the printer makes a grinding noise and spits the card out unprinted. We installed a new printer ribbon and have had this issue since then
3 Suggested Answers
alexvelez052
  • 40 Answers
SOURCE: Datacard SP25 only printing half of ID Card
it sounds like a driver error try to reinstall the software
Posted on Jul 08, 2009
  • 36 Answers
SOURCE: THE RIBBON BROKE ON MY DATACARD SP25 PLUS.
to fix the problem that is causing the ribbons to brake or the broken ribbon it self?
1. check edge to edge settings in printer toolbox
2. to fix broken ribbon re wrap it straight over the take up spool and use a piece of tape to hold in-place.
Posted on Mar 19, 2010
Why is my datacard SP25 plus not printing?
Could you be more specific about your OS, software you are using and driver?
Jun 16, 2015 | Datacard SP25 Printer
Sp25 won't print colors
Roll back drivers and check print heads for flow
Apr 22, 2014 | Datacard SP25 Plus Plastic ID Card Printer
Datacard sp25 plus is only printing black and white
a) You bought a black Supply(check code and catalog)
b) You have set your driver to print only black dots(check your driver settings)
Jan 20, 2014 | Datacard SP25 Printer
When i try to print card it causes a paper jam all time. it used to print card but not now i feel this is a grat pity cause its a good printer. It doesnt matter which place i put card it just will not lift...
fter a clear card option has been installed in a Datacard card printer SP35 Plus or SP55 Plus, a card jam error my occur. The same error may occur when after replacing the main control board.
To clear this error the printer will need to determine the sensor type. For the printer to recycle through and make this determination, a power on test card is required using the appropriate clear or opaque card type to force the firmware to redetermine the sensor type. Each time the card is changed from clear or opaque to the other type, a power test card will be necessary to redetermine the sensor type.
For additional information about Datacard printers currently on the market, SP25 Plus, SP35 Plus, SP55 Plus and the SP75 Plus, contact our id card experts toll free at 888-485-4696.
Nov 19, 2009 | Epson AcuLaser C4100 Printer
I have a DataCard SP25 card printer that won't power up. I switched cords to a known good one and still no power. I suspect it's the power supply in the unit. Is this replacable and what might the cost be?...
There is no power supply in the printer, the power supply is external, nothing user replaceable inside, sounds like you need a new system board, you would be better off trading in for a discount on a new SP25 Plus.
Check midwestIdSolutions.com
Nov 10, 2009 | Datacard SP25 Printer
Jul 08, 2009 | Datacard SP25 Printer
Datacard sp25 ID card Printer printer about half of the picture is this a printer problem or a ribbon cartridge problem?
you need consider:
1) it should be no gap between roller--ribbon--card and base when it printing need enough pressure on the card. if not enough pressure it could be printing bad.
2) the ribbon move under the roller might be not normal, to check or adjust it
3) the ribbon near the end, need to change
hope it help you
May 12, 2009 | Datacard SP25 Printer
Dec 31, 2008 | Datacard SP25 Printer
Datacard SP25 Printer Logo
37 people viewed this question
Top Datacard Office Equipment & Supplies Experts
Safe-Card ID...
Level 1 Expert
james laughton
james laughton
Are you a Datacard Office Equipment and Supply Expert? Answer questions, earn points and help others
