Replacement belt on bosch classixx 6 keep slipping off
Replacement belt keep slipping off
  • 38 Answers
Make sure motor shaft and wheel are properly lined up.
also check if motor is pulled backfar enough
Posted on Nov 02, 2012
SOURCE: Bosch classixx 6 1200 express has F17 on display
fault F17 error code appearing. What does this mean ? thanks
Posted on Jan 24, 2010
  • 1382 Answers
SOURCE: door wont open on bosch classixx 6 1400 express washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board. The wash program should halt when this comes up but you should be able to restart it when the door is closed. As the cost of a new door interlock isn't overly expensive. The best way to fix this problem is to purchase a new lock and fit it.
Thank you !
Posted on May 19, 2010
  • 662 Answers
SOURCE: key symbol showing
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
Posted on Jun 14, 2010
  • 662 Answers
SOURCE: Got the Bosch Classixx 6 Express 1400 washing machine cant
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently. Means the machine is locked, for children. I think if you do it again it locks.
Posted on Jun 17, 2010
richroth
  • 9472 Answers
SOURCE: bosch classixx 6 1400 machine
F21 relates to a motor or control board fault.
However, it is also caused by spikes in the mains and can be spurious.
To reset it.
Turn the appliance knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position.
Press and hold the spin button.
While holding it, turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds.
Release the button.
Turn the knob to off.
When your turn it back on it should have cleared the error code
Posted on Nov 27, 2010
How to replace brushes on a classic 6 1200
Disconnect the power
disconnect hoses
lay machine on it's left side
remove back cover screw and cover
slip belt off pully
unplug motor wires
undo bolts holding motor
pull motor to rear of machine
revome motor to bench
locate brush housings
undo retaining clip and slide out old brush
fit new brush
replete with other brush
reasonable in reverse of removal
Oct 04, 2014 | Bosch Washing Machines
F21 flashing on my bosch classixx 6 1200 express
F21 is a motor fault and in some cases can also involve a module fault. It could be as simple as the brushes need replacing or the drum has been severely out of balance.
Mar 21, 2013 | Bosch Washing Machines
How do you change the drive belt on a Bosch Classixx tumble dryer WTA3003GB/17?
Its a fairly simple process depending on your machine. Most Bosch machine belts are simple to replace. Here is a good resource: http://www.videojug.com/film/how-to-replace-the-belt-on-a-tumble-dryer-bosch
Dec 03, 2010 | Bosch Axxis WTA 3003 Electric Dryer
Washing Machine will bo start
May 26, 2010 | Bosch Classixx WFL 2066 Front Load Washer
I have a Bosch washing machine /classixx 6 12 Express and the key sign is on and cannot programme wash
May 21, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Got the Bosch Classixx 6 1400 Expresswashing
I have the same problem - Did you mange to sort it out?
Mar 23, 2010 | Bosch Classixx WFO 2466 Front Load Washer
Keep getting error f17 on my bosch classixx 6 washing machine
My old Bosch only had a filter in the machine (where the hose attaches. My Exxcel has a filter IN THE HOSE at the tap end too. I removed that one and it made a big difference !
Dec 17, 2009 | Bosch Classixx WFO 2866 Front Load Washer
My bosch classixx 6, 1200 express washing machine keeps displayin
Bosch classixx 1200 express washing machine won't drain
Mar 29, 2009 | Bosch Washing Machines
Bosch classixx 1200 fills, drains, but won't wash ?
This a classic example of worn brushes in the motor.
To check , remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws that secure motor, and lever motor back with a screwdriver or similar.
Keep hold of the motor as you lever it back.
You will find the brushes at the terminal end of the motor, replace if less than 4=5 mm in length.
Refit motor belt and motor plug.Test. before you refit panel
Plz rate my solution.
Thanks.
Jan 12, 2009 | Bosch Washing Machines
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
