Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Need help with my Mitsubishi W52525
I thought the lamp had gone out and I got another one. It didn't help, thought maybe that one was bad too, but the replacement didn't work either. Came to this site saw ther was a way to get a reading by holding down the deive and menu buttons. I get a 1-2 blinking Can you help?. The red lamp light comes on when trying to turn on the set.
  • 1 more comment
  • Mark Devine
    Mark Devine May 21, 2007
    I let it sit over night and rechecked the connection on the lamp. I tried it on emore time and rechecked the codes, now I am getting a 34 code
  • Mark Devine
    Also, Leadtech, I saw your solution for this, but where do I get a ballast?
  • Anonymous Nov 16, 2008
    Well, that's why I bought the 4 year extended warranty. They came and simply picked up the TV to return it in about a week all better. In the mean time we went out and bought a 52" Samsung LCD, , 1080p, 120Hz refresh rate, 40,000 : 1 contrast ratio, it's amazing! Know anyone who wants to buy a Mitsubishi 52" DLP in great condintion?
Yeah, only one. I purchased a new extended contract through Sears (where I originally bought it) and they are going to fix it. Because at last I was at a loss.
Posted on Jun 08, 2007
I am having the same problem with my TV. Have you figured out a solution yet?? I have a repair man scheduled to come out next week
Posted on Jun 05, 2007
Mitsubishi wd-y65 binking red light problemm
Hello... Your TV has a lamp that has probably gone bad. The lamp is accessible from the back of the TV, located towards the right side. There is a square-ish piece of plastic with one screw on the left side. Unplug the TV, open the cover and there are two silver screws on the left, top and bottom. Loosen the screws, and then grab the handle and pull out the lamp. It may be obviously bad, but if you're not sure, take it to a service center to get their opinion. Be careful buying a lamp online, some will not last long and some may not work at all. Mitsubishi TVs need the correct lamp to work properly. I hope this helps.
Nov 11, 2017 | Mitsubishi Televison & Video
Put new lamp in 12hrs later red light was on lamp had black around it why
new lamp may have gone bad. was this the recommended lamp for the unit. Most Mitsubishi units must have the correct manufacturer recommended lamp installed.
The correct part# for this unit is 915B403001
You may find that lamp at the following web site:
http://www.shopjimmy.com/catalogsearch/result/?q=915b403001
Jan 31, 2015 | Mitsubishi WD-60C9 60" DLP HDTV
Red "lamp" light stays on
Red light indicates the lamp has failed to light. You may just need to buy a new lamp. If that does not help then the capacitors on PWB-Power need to be replaced or the lamp ballast itself has gone bad.
Dec 29, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Tv starts to turn on then red light comes on and tv turns off
The red light indicates the lamp has has failed to light. You might just need a new lamp. If replacing the lamp does not solve your problem then the capacitors on PWB-Power need to be replaced or the lamp ballast itself has gone bad.
Dec 25, 2010 | Mitsubishi WD-62525 62" Rear Projection...
I thought the lamp had gone out on my Mitsubishi WD-62825G but after replacing the bulb (2 times) I figure it?s something more as the red light comes on instead of the TV. Called out A+ as they said they...
if is not under warranty then you should buy a new tv. i had 3 lamps, 1 light engine, and they are currently rebuilding the chasis for the second time. i got my tv in 12/04 and got the 5 yearextended warranty THANK GOD! they are spending more time/money to keep repairing this pos than its worth. they could have gotten me a new model and saved everone the hassle. i would not recommend repairing it.
good luck
Jun 26, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi w52525 - replaced lamp and red light still on
could be the wrong lamp or not set right in housing or bad door switch.
May 03, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 Shuts off, shows red lamp light even after replacing lamp
maybe your problem is in the power supply circuit of your tv,but then try to replace the flyback first maybe there is no high voltage coming out on the cap.
Jul 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
319 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
