Question about Samsung ML-2550 Laser Printer
Ml-4551nd out-bin full - Samsung ML-2550 Laser Printer
Fuser door open
There is a black sensor that detects when the fuser door is closed, and an actuator that the sensor either sees or doesn't see. If this sensor is dirty, it might not be seeing the actuator. It could also be broken or knocked out of place.
Locate the actuator on the side door (a small metal or plastic tab that sticks out from the door) and find the corresponding sensor. Make sure the sensor is in place and not broken or moved, and make sure it's connector is well-seated. If you have a can of compressed air, blow it into the sensor to clear away any dust or dirt.
Nov 16, 2015 | Samsung ML-4551ND Printer
How many tea spoons is 30 grams
a litre = 1000 ml 1ml = 1 gram
a teaspoon is about 5ml full and flat
By my reckoning it is 30 ml divided by six which equals 6 spoons full
Jun 03, 2015 | Office Equipment & Supplies
I have a Westinghouse freestyle fridge and it is collecting up to 500 ml water underneath the crisper bins each day.
remove crisper bins and look for the drain tube . it must be clogged . as water is supposed to drain to the evaporation tray under the fridge .
Dec 17, 2014 | Westinghouse Refrigerators
When i start My Samsung ML2551 N it comes with an error..OUT Bin Full...i have replaced my printer toner as well..but still the same problem.. your prompt solution will be highly appriciatable...
HEY DUDE,
There is a sensor at the paper output bin,and i think it something broken or else some paper particle stucked on that sensor.If you are familiar in servicing try to open and check the output bin for a sensor.Else get the printer for a service center for servicing.It will cost a low price.
I wish you best of luck
Mar 07, 2011 | Samsung ML-2550 Laser Printer
Dear Expert how to reset chip ML-2850 Series printer, please help me
If firmware update is unsuccessful, you can throw printer.
I recommend you build yourself a very simple "reset device" (resetter) for many models including this one. Address is,
http://www.tradebit.com/filedetail.php/178510406-at88sc0204-reset-software-full-package
List of chips that can be reset is,
Samsung ML-1630
Samsung ML-1631
Samsung ML-2850
Samsung ML-2851
Samsung ML-3050
Samsung ML-3051
Samsung ML-3470
Samsung ML-3471
Samsung ML-3472
Samsung ML-4050
Samsung ML-4550
Samsung ML-4551
Samsung SCX-4500
Samsung SCX-4501
Samsung SCX-4725
Samsung SCX-5330
Samsung SCX-5525
Samsung SCX-5530
Samsung CF-560
Samsung CF-565
Samsung SF-560
Samsung SF-565
Samsung CLP-350 (Bl/M/C/Y)
Samsung CLP-351 (Bl/M/C/Y)
Samsung CLP-610 (Bl/M/C/Y)
Samsung CLP-660 (Bl/M/C/Y)
Samsung CLX-6200 (Bl/M/C/Y)
Samsung CLX-6210 (Bl/M/C/Y)
Samsung CLX-6240 (Bl/M/C/Y)
...and many others.
Excuse my poor English.
Aug 20, 2010 | Samsung ML-2850 Series
My Canon Pixma MP450 keeps reading ink absorber full. What does that mean?
Like peeling potatoes or oranges or apples, and throwing the peel into a garbage-bin, eventually the bin will get full, and you'll have to empty the bin, before you can do more peeling.
Similarly, when printing, some INK is "wasted", and ends up in a small bin, with an ABSORBER pad (like a baby diaper) in the bin.
So, your printer's bin has become full, and a qualified printer technician can properly empty the bin.
Dec 30, 2009 | Canon Pixma MP450 All-In-One InkJet...
Display say "BIN IS FULL"
HP says: 1) remove all printed pages from output bin 2) "flick" the output bin lever with your finger
If fault continues, contact HP.
Nov 27, 2009 | HP LaserJet 4000n Printer
Samsung ML-2550 Laser Printer Logo
98 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
