Question about RCA 25423RE1 Phone
I want to be able to forward the phone line to a cell
How do I forward calls from Panasonic KXTG4500 to my cell?
Call forwarding needs to be activated by your phone company and then set up through your account settings. The phone itself cannot forward calls. You would need a two-line phone with call forwarding features and two separate phone lines to accomplish call forwarding locally.
Feb 02, 2015 | Panasonic KXTG4500B 5.8 GHz 4-Line Corded...
HOW DO I FORWARD A CALL TO ANOTHER PHONE?
On the Land line phone, dial *72 then you should hear the dial tone again. Enter the 10 digit cell phone number that you want the land line call to go to, hang the phone back up.
*73 will set the calls back to the land line when you no longer need the calls forwarded to the cell phone.
Sep 19, 2014 | Lands Phones
HOW TO CALL FORWARD TO CELL PHONE NUMBER
There are a couple of ways to achieve this.
First, press 355 on your phone to activate the call forward feature. Once it asks for a forward destination, press whatever number your company uses to dial an outside line. After that dial your number like normal and hang up the phone.This will forward all calls directly to your cell phone.
The second method is the same as the one listed above but it uses the feature code 356. 356 will forward calls if you do not answer from your Mitel phone first.
I hope this helps
Sep 03, 2014 | Mitel 5330 IP Phone
How to transfer main phone number to cell number
If the featured is enabled at the phone company, grab the main line, enter call forward code (maybe *72), get stutter tone, dial your cell number, hang up. In the morning cancel forwarding, access main line, dial cancel code ( maybe *73), hang up.
Apr 08, 2014 | AT&T 922 Corded Phone
FWD/DND will not cancel on KX-TDA200
Hello,still having the same problem?I can remotely configure and cancel call forward and configure your system as you want it.Contact me for help.
Mail me: omonat@yahoo.com
Make the subject be PANASONIC PBX
Aug 21, 2012 | Panasonic (KX-TDA200)
How do i forward a call to a cell phone?
I believe your landline carrier just needs to have the capability of call forwarding (ie we utilize Verizon for our business). We also use the call forward feature by: picking up line, (hear dial tone) dial *72 [ then phone number you want calls to forward to, even a cell]. To discontinue: pick up line (hear dial tone) dial *73
Mar 02, 2010 | NEC Dterm DTP 16D-1 Corded Phone
How to farward calls to cellphone landline is verizon
If you have call forwarding service, then its done by accessing the line on the phone you want to forward to your cell enter *72 you should get dialtone reordered then enter the number of your cell phone.
You have to answer your cell phone for the forwarding to take place.
Dec 04, 2009 | Lands Phones
Sound issues with Forwarded calls to cell
Are you using a PRI, or POTS lines?
Probably pots lines, as this is a common occurance when forwarding out over pots lines.
Basically you are doing an unsupervised conference call when you forward to cell.
To prove the lines in the office are the problem, set up a conference call. If the 2 remote people can not hear each other the same as you describe in your forwarding, then it is the POTS lines.
The problem is, no one is going to be able to do anything about it. If this is an important feature, then you may want to look at a new system that can have different line types and then this isnt a problem.
Jul 08, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Fowarding the Phones
The Prostar 816 wasn't capable of an external transfer of lines so its my guess that your using call forwarding through centrex to accomplish the job. i.e. *72 dial the number you wish to transfer to wait for an answer and hang up. *73 would be the disable code for call forward but is done by the line that originated the call. The only way i could see around that is to have ultra call forwarding on the line so it can be established and terminated remotely.
If i'm missing the mark please let me know
Nov 24, 2008 | Samsung Prostar 816 Phone
Forwarding to cell phones or outside lines
Hi Lauri, the calls can be FORWARDED to a cell phone or the call can be CONFERENCED with a cell phone but can only be TRANSFERED to a phone/voicemail in your office. The information for external fordwarding and conferencing is in the iDCS user guide. Let me know if I can help .....Mike
Aug 06, 2008 | Samsung DCS 12 Corded Phone
RCA 25423RE1 Phone Logo
222 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
