Question about Ricoh Office Equipment & Supplies
Service call sc542 for Aficio SP C430DN - Ricoh Office Equipment & Supplies
    New Friend:
Works for me, thanks
OfficeServiceAjnc
Posted on May 19, 2016
mimranon
  • 72 Answers
SOURCE: Ricoh Aficio SP 420dn shows SC542 error code after
Hi dear pls take you printer to service center
Thank you
Imran
Pls rank as possible have nice day
Posted on Apr 20, 2009
Ickoajnc
  • 183 Answers
SOURCE: i have a ricoh aficio sp c420dn, when and turn on
You may try first to reset the SC 542 before calling a technician!
That you can do by following method:
1.Turn the machine off and then after 5 second turn it on while pressing the “On Line” key and “Escape” key together until “SYSTEMver x.xx/1. Service” shows on the display.
2.Use the “Up/Down arrow” keys to scroll through the menu listing.
3. Press the (OK) key while
on the display writes " 2. Engine " .
4.go to "[5810 001] - Fusing SC Reset" by scrolling the “Up/Down arrow” keys and press the [OK] key (on the display should write execute or done) press [OK] again if is needed to press it.
5. After this turn off and than after 5 second turn it on the machine.
Please do not change nothing else in this menu only reset the fusing unit SC code, because if you change some other values and settings you might to regret that and pay high price for that.
So only reset the Fuser SC code SC542 by the upper mentioned method and do nothing else, if the SC code appear again then do not try this again because you might burn some parts.
If this do not help than call the technician.
Please answer do this is helpful for i to know do the problem was solved.
Regards
Posted on Jan 13, 2010
  • 393 Answers
SOURCE: Ricoh Aficio SP C411dn error SC542
It represents a fuser (hot section) failure you must enter service mode to reset. New fuser time?
Posted on May 17, 2010
pateltraders
  • 35 Answers
SOURCE: I have an Aficio SP
We have solutions Ricoh Chip reset and device
skype: indianrefiller
Posted on Jun 07, 2011
tinualbinale
  • 436 Answers
SOURCE: Hi, I have a Printer
This error code means temperature fusing problem. Check all of the connectors on the fuser connector and receptacle, just to make sure that full contact is being made.According to Ricoh direct techs after 100K to 200K copies on a new machine the Hot Roller would start to warp (ever so slightly) because of its thin wall construction (fast warmup time).Replacing the Hot Roller will solve the problem.Please don't forget to rate me if satisfied.
Service manual for Ricoh Aficio SP 5200 DN with all parts and troubleshooting
go to service mode.
press up and down button. then press ok. go to SP5810 and reset.
Jan 29, 2017 | Ricoh Aficio SP 5200 DN Laser Printer
HOW TO OBTAIN PRINTER READINGS FROM MACHINE RICHO AFICIO SP C430DN
Hi.
You will need to print the Printer configuration page.
The procedure is;
Menu > Printer Features > Configuration page.
You will see it in the top.
Nov 18, 2016 | Ricoh SP C430DN Laser Printer
Aficio sp c430dn error sc670. In service manual prepose to replace engine board. But i can find it. Is in SM engine board called Controller board? Also am trying to upgrade firmware. When I put in the
You cannot update firmware when there is an error condition. Reseat all the connections on the controller board. If it still fails then replace part number D0655715.
Nov 28, 2014 | Ricoh Aficio SP C430dn Laser Printer
Ricoh Aficio SP C430DN - Print Data Error
Its you, change drivers, postscript on the printer? PCL 5C is what your are using?
Mar 31, 2014 | Ricoh Office Equipment & Supplies
Aficio C430DN error SC540
this is a problem with the fusing section
call an expert to check on it for you
Mar 06, 2014 | Ricoh Aficio SP C430DN
Ricoh aficio 2232c sc542 error
SC542 means that the thermistor hasn't detected right temperature in given time.
Often you only have to reset service code.
Try this reset:
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
from http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/ here is another service procedure:
  • Press Mode(The Yellow Button)
  • Enter 107
  • Press STOP Button for 3 second (RED Button)
  • Copy Sp
  • 5810#
  • Execute
  • Power Off
  • Power On
Nov 19, 2009 | Ricoh Aficio 2015 Copier
934 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
