Washer overfills with water - Washing Machines
  • 38 Answers
Has bad pressure switch
need to order new one
google model number
Posted on Nov 02, 2012
Washer overfills & excess comes out from underneath
what is your model number then we can get started then okay
Feb 11, 2013 | GE WBSR3140DW Top Load Washer
The washer overfills
if you unplug it and the water keeps running replace the valve where the hoses are connected to but if it overfills and the water stops when you pull the plug replace the pressure switch
Jan 16, 2013 | Kenmore 98702 Stacked Washer/Dryer
The washer is having the following issues. Overfills excess water drains out on the floor down the overfill pipe. Washer cycles and doesn't spin.
The float on the water level shut off valve is probally stuck and not telling the washer that its full and to turn off the water. once thats fixed it will probally cycle normally. Try it on half load and see if the water stops at the correct spot.
May 15, 2011 | Washing Machines
Hi. My Whirlpool Duet Sport washer stopped mid-cycle and is flashing F-. I can't open the door. Help!
The pump on your washer is apparently not working. It should have pumped the water out when the FL was displayed. You should schedule service and let a technician diagnose and repair the washer.
Flood Condition F L "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed. With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Mar 21, 2011 | Whirlpool Washing Machines
The water is overfill
Hi
Overfilling is caused when either the water inlet valve or water level switch is bad. When any of these parts goes bad it won't shut off the water and so cause overfilling. Hope this helps...please post back for further assistance.
Daniel
Jan 21, 2011 | Whirlpool AWZ410 Front Load Washer/Dryer
My Kenmore elite with Calypso motion top load washer is reading FL and is asking for the overfill switch to be reset. water is leaking from underneath. what do i do besides turn the water off to the...
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 07, 2009 | Kenmore Elite 45986 Front Load Washer
OVERFILLED AND FLOODED HOUSE
1 of two problems happened.
1) either the water level sensor went bad. Which tells the water inlet valve when to shut off and the machine to start operating.
2) The water inlet valve has failed. This comes from the water hose and fills the washing machine.
May 25, 2009 | General Electric WCSR2090D Top Load Washer
Washer will overfill on small load and large
If this happens only on small load cycle , then it can be a faulty timer board.
however check also the water level switch, when there is overfilling this part is always the first suspect.
May 21, 2009 | Kenmore Elite 21082
FL SIGN AND BEEPING, AND THE WATER WON'T DRAIN.
This problem i see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
This is not the same washer but all the parts are the same. Please check here for a more detailed appoarch to this problem. Click Here
Feb 13, 2009 | Kenmore 24032\24036 Top Load Washer
Hot water runs constantly - overfills
This is often, if not all the time, a faulty fill valve, the fill valve has mechanically stuck open and is not fully shutting off when not the washer is not in use. This normally will become worse and could flood over the top of the washer = big mess .... replace the fill valve. The fill valve is the part the hot and cold water hoses are attached to.
Jan 11, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
