New water pump car still overheating
Maybe the water pump is faulty ?
  • 38 Answers
Check for thermostat pluged
Posted on Nov 02, 2012
  • 1 more comment
  • macasan
    macasan Nov 02, 2012
    How do i do that ?
  • matt lyall Nov 02, 2012
    look at top of radiator where large hose connects inside the thermosat lies
    google installing radiator thermostat. good luck, cheap fix
Overheating 97 Lincon Town car
Connie, Were the radiator,water pump and thermostat replaced to try and fix the over heat issue or as maintenance. Engine overheating can be caused by a lot of things, Leak in cooling system, air in system, bad rad. cap, slipping belt, faulty thermostat or installed upside down, faulty water pump, plugged radiator (inside/outside), collapsing rad hose, faulty cooling fan, leaking head gasket, sludge plugging engine water passages, poorly tuned engine, etc..
Take into a good shop for diagnoses and estimate for repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Troubleshoot an Overheating Engine
Steve Litt Overheating Guide
Diagnose Engine Overheating Auto Repair Help
How to Troubleshoot an Overheating Engine DoItYourself com
Jul 21, 2016 | Cars & Trucks
Halo there n overheating problem on my 200sx det i have replaced the moter replaced the radiator to n twin core new water pump new thermostat and i fitted 2 12' electric fans i drive about 15min and it...
When the car overheats be sure to check all pipes are hot if some pipes are cold there might be a air lock which stops the circulation are the car heaters blowing hot air ?if the rad ain't hot then those fans not going to do much good if everything is hot are the fans working ? Is it a faulty reading from the engine coolant sensor ? And don't rule out faulty new stuff I've had lots of faulty new stuff remove the thermostat to rule that out .
Feb 08, 2015 | Cars & Trucks
2004 nissan quest overheating a little
You can run the engine without the thermostat as a test.
Not recommended to run it forever like that.
The problem could be air in the system, or a faulty water pump not making the coolant flow.
Jan 24, 2013 | 2004 Nissan Quest
Engine overheating
check for water coolant circulation. either you might have a clogged radiator or faulty water pump. to check the radiator after you run the engine for a while switch it off and try to find an easy access to radiator vents and touch all surface to see whether is all ho or if is some,then you remove it and send it for cleaning. as regards water pump,take the thermostat out put water in and start the engine follow the water circulation when you rev.if it rotates the water pump is working if is steady and coming upwards to over flow then the water pump is faulty. Also the other possibility is the matrix to be clogged..
Aug 30, 2012 | 1996 Ford Taurus
Car overheating and changed everything, WHY??
Maybe a faulty water temperature sensor or a loose connection on the sensor.
Jun 08, 2012 | 1998 Pontiac Firebird
2001 deville low coolant light is on, overheating. changed thermostat and water pump. what is the cause for overheating
blockage in rad, headgasket or maybe a faulty sensor,you need to get a presher test done on the cooling system first.
May 29, 2011 | 2001 Cadillac DeVille
Lincoln 2000 is overheating
Check that the thermostat maybe faulty. Then have the cooling system pressure tested for any leaks externally and internally. Also check that the water pump is pumping the coolant around the engine adequately.
Thanks
Jason
Apr 13, 2011 | 2000 Lincoln LS
Took out the thermostat, replaced the radiator, the water is circulating in the radiator but it is still running hot. what do i do next?
Overheating can seriously damage a car's engine if left unchecked. Although overheating simply means that a car's engine temperature exceeds normal operating temperatures, the causes of overheating are varied. What follows is a brief list of some of the most common causes of engine overheating.
    Faulty Radiator
  1. A car that overheats will often have a faulty radiator. A radiator is responsible for cooling hot engine coolant that picks up heat from inside a car's running engine. A radiator "radiates" the heat from engine coolant out into the outside air. A faulty radiator loses its "radiating" effects and allows engine coolant to become overheated, thus rendering it ineffective at adequately cooling and engine.
  2. Faulty Water Pump
  3. A faulty or malfunctioning water pump prevents adequate engine coolant flow and can cause a car to overheat. A water pump serves to pressurize and propel engine coolant throughout a car's engine and radiator to increase the heat-reducing capabilities of engine coolant. A faulty water pump loses its ability to adequately pump and propel engine coolant, and can cause a car to overheat.
  4. Coolant System Leaks
  5. A leaky engine coolant system reduces the level of circulating engine coolant, which increases engine temperature and leads to engine overheating. Radiators, water pumps, and coolant system hoses and seals--all of these coolant system parts can develop leaks, which can result in low coolant levels and engine overheating.
  6. Faulty Thermostat
  7. A car thermostat regulates the flow of engine coolant. A thermostat is a heat-sensitive valve that opens when a car engine reaches a set operating temperature and closes when a car engine is cold and warming up. If a thermostat gets stuck in the closed position, coolant will be prevented from reaching the engine, which will quickly lead to engine overheating and potential engine damage.
  8. Low Engine Oil Level
  9. Engine oil, in addition to lubricating an engine's internal parts, helps to keep engine operating temperatures reduced by eliminating friction within the engine. If engine oil levels are low, friction and heat build up inside an engine, a condition that causes increased engine operating temperatures and can lead to engine overheating.
Jan 15, 2011 | 1998 Isuzu Rodeo
My car is overheating.i changed the thermostat,radiator and coolant sensor.
What is the indication that the car is overheating, is it the temp gauge or is the cooling system overflowing? A high tech scan tool can read the actual engine temperature, maybe you gauge is faulty.
If car is actually overheating, other areas to check or suspect is the water pump, hoses or there maybe some obstruction in the engine itself.
Sep 12, 2010 | 1996 Oldsmobile Cutlass Supreme Coupe
1996 Pontiac Grand Am / Overheating
Below u will find Auto zone list for reason ur car can over heat Shaun Inspect Cooling System Mix Coolant level low or flow is restricted. grey_line.gif 2 Inspect Belt Incorrectly routed, adjusted, tensioned, missing, or worn water pump belt(s). grey_line.gif 3 Inspect Oil Pan Gasket - Performance Ruptured, cracked or leaking radiator hose. grey_line.gif 4 Inspect Radiator Cap Worn or damaged radiator cap grey_line.gif 5 Inspect Thermostat Thermostat stuck closed grey_line.gif 6 Inspect Fan Blade Broken, missing, or defective fan blade(s). grey_line.gif 8 Inspect Water Pump Damaged, worn or leaking water pump. grey_line.gif 9 Inspect Intake Manifold Plenum - Perform Leaking water pump gasket. grey_line.gif 10 Inspect Cooling Fan Control Faulty cooling fan control or circuit. grey_line.gif 11 Inspect Cooling Fan Switch - Radiator Faulty radiator cooling fan switch or circuit. grey_line.gif 12 Inspect Engine Temperature Sensor Faulty engine temperature sensor or circuit. grey_line.gif 13 Inspect Temperature Switch Damaged or faulty temperature switch or temperature switch circuit. grey_line.gif 14 Inspect Fan Clutch Worn, loose or faulty fan clutch. grey_line.gif 15 Inspect Ported Vacuum Switch Damaged, leaking, or faulty ported vacuum switch. grey_line.gif 16 Inspect Radiator Obstructed radiator core or radiator cooling fins. grey_line.gif 17 Inspect Head Gasket - Performance Head gasket leaking coolant into cylinders grey_line.gif
Nov 15, 2008 | 2004 Pontiac Grand Am
Washing Machines Logo
Top Washing Machines Experts
