Question about LG WFT1071TP Top Load Washer
I have a brand new LG 8KG top loader washing machine
Why does the buzzer come on and tell me that the lid is not closed when it is closed.
    Problem Solver:
  • 4 Answers
Thank you for coming back to me, yes I have had the problem solved today. A technician came around to my home and made a slight adjustment to the Lid and said it should never give me trouble again. It was a free service as my washing machine was brand new and it started up perfectly and went through it's full cycle with no hicups!
Many thanks,
Billie. South Africa. ( Durban)
Posted on Jan 06, 2009
I have a LG front loader, when I start the machine it doesn't do a washing cycle, Why?
The common issue is that the washer lid switch is defective, unless it senses the lid is closed the cycle will not start.
Jul 13, 2017 | LG Washing Machines
My LG WT-R807 8KG top loader washing machine will not rinse or spin I have a huge load in there at the moment. Have removed most of washing from it still won't drain. Have tried turning machine off and...
Did you try it in other cycles (delicate, permanent press, etc.)? The more symptoms - what works and doesn't allows better advice. Because right now it could be the control board, the timer, the drain pump and more.
Also you need to give us the model number off the id tag in your unit since that once keeps coming back as invalid.
Jul 14, 2011 | LG Washing Machines
LG 8kg Fuzzy logic top loader and it will wash and fill the water but the water wont stop when it wash, rinse or spin it, the water also come out even there is no power to the machine.
Assuming the water is coming in even when unit is unplugged from wall. You should to replace the water inlet valves where the hoses connect to the machine. You need to unplug the power and remove the top, disconnect the hoses unhook the wire harness plugs, unscrew the hose valve hex nut and remove valve. Install the new one in reverse order.
May 16, 2011 | Washing Machines
How do you remove the top on a LG WM2077CW front loader?
I can not remove the top cover of my LG WM-2277HW
can somebody tell me how to lift off the top cover. I already
removed the screws from the rear
Nov 09, 2009 | LG WM-2277HW Front Load Washer
Hi my LG 8kg top loader washing mashine says UE and wont drain
UE code means an imbalance error. Either the load is too small, the appliance is tilted, laundry is gathered to one side or a non distributable things are put into the drum.
Make sure the unit is placed in level location and distribute the load evenly inside the drum. Do not load the unit with on-distributable items.
Oct 19, 2009 | LG WFT1071TP Top Load Washer
LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Sep 11, 2009 | LG Washing Machines
LG toploader washing machine alarm signal Lid Open.
The lid switch is bad, not making contact.Replace switch or see where it is not being contacted by the lid or hindges when the lid is closed.
Jan 04, 2009 | LG KU990 Viewty
LG WFT1071TP Top Load Washer Logo
105 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
