Question about Clarke Power Products 2 Clarke Mig Welder Gas Diffuser 130en 180en Tip Holder
Wire drive moter assembely for einhell sga 175 turbo please
Ould an assebmely from another source do, do you think thanks jem
  • jeremy joel Nov 04, 2012
    I am sorry but my question didn’t come out very well So I will start again.I have just been given an Einhell sga 175 turbo mig welder, but it is missing the drive assembly the motor that pushes the welding wire to the gun. Does anyone know where I can get a new or better a second hand assembly complete? Or if another make of  this assembly would work, as it is a separate part of the mig welder, isn’t it? Thanks again jeremy
My 2006 freelander (2000lt BMW moter) very high diesel consumption. You can smell it and lots of smoke (white and darker) please help. where do i adjast the pump.
One or more of the new injectors may be bad and delivering too much fuel. I don't think adjusting the pump is something that can be done without expert knowledge and tools.
Jun 24, 2016 | BMW Cars & Trucks
Trimmer head rotates on shaft, how do i fix it
you will have to source a new front shaft because the seals inside have worn out and im not sure where to source them parts you could try einhell ltd they sometimes have spare strimmer parts
Aug 22, 2011 | Poulan 25cc 2-Cycle Gas Powered String...
Our MillerMatic 175 wire feed cannot be adjusted down enough. The rheostat seems to function, but even the lowest setting is now way too fast.
Your Millermatic 175 has syncronize wire speed-voltage feature in order to reduce the wire speed first reduce your heat (voltage). Try again.
If this was useful to you please vote. thanks.
Feb 10, 2011 | Miller MATIC 180 MIG w/cart/AND SPOOLMATE...
Where can I find a lower spring mounting for a Spear and Jackson cs38 chainsaw.
They appear to be well constructed, I wish they were available here.
If purchased at Einhell an OM may be found here:
Spear & Jackson
http://www.einhell-uk.co.uk/index.php?id=2&br=7&sb=11
Please click the "Spares & After Sales" link for parts.
If purchased at ARGOS there is a phone number mid page.
Spear and Jackson UK
http://www.spear-and-jackson.com/en/contact-us
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 15, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Samick sga 120 amp keeps blowing fuses. Replaced all rectifier diodes and tranformer seems to be working fine. Any suggestions?
The fault may not be in the power supply area! The other area of blame is the main amp section. Suspect any of the devices on the heat sink (also any device in the power supply with an heat sink). Transistors can be tested easily with this problem. An Ohm Meter on the resistance setting, on the terminals (even in circuit) of the transistor, will act like you have touched the test probes together. Just like a piece of wire, because that's what it has become and why they blow the fuse!
May 15, 2010 | Audio Players & Recorders
How do i tighten the chain on an electric royal einhell 1840/1?
Hello James;
Your saw is listed here and contians a link to "isc-gmbh" for an instruction manual. My German is a little weak.
http://www.einhell.com/englisch/englisch.aspx?file=gartentechnik
I think this will get you to a "Contact Us" page where you can make your request.
http://www.microsofttranslator.com/BV.aspx?ref=IE8Activity&a=http%3A%2F%2Fwww.isc-gmbh.info%2Findex.php%3FPHPSESSID%3D4848211954ba3bd3d5041a%26mainid%3D4%26subid%3D8
I must admit I am not familiar with your saw and many electrics are different. This is a very good manual for an electric and while it may not be exact is good guidance. Please obtain the correct OM for your saw, but this should work in the interim.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_OM.pdf
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 19, 2010 | Garden
Miller 175 trigger will not feed wire very
First thing make sure the lead cable is as straight as possible. and make sure the wire has a unobstructed path. then you should check the trigger input/output switch and see if the switch is getting power to it continuously. I hope this help please rate this thank you
Mar 15, 2010 | Welding Tools
What goes where
please explain what wires you need to sort out and year of vehicle ,because to mje an rs turbo must be at least 30yrs old by now
May 06, 2009 | Ford Escort Cars & Trucks
Download a Janome (Jem 639) sewing machine manual
Just today  i got out my little janome i bought years ago and it is this model.  There was no "manual" with the machine.  All that came with it is a large 20X14 two sided print out.  I can scan and send this to you with an email address.
Feb 17, 2009 | Sewing Machines
Clarke Power Products 2 Clarke Mig Welder Gas Diffuser 130en 180en Tip Holder Logo
117 people viewed this question
Top Clarke Power Products Welding Tools Experts
 Kenneth
Kenneth
Wade Mobley
Wade Mobley
Are you a Clarke Power Products Welding Tool Expert? Answer questions, earn points and help others
