Question about Eclipse Metrologic MS5145 Barcode Scanner
The barcode reader eclipse ms5145 powers on,the laser light blinks and beeps at scan by not scan the barcode
  • 91 Answers
It could be either one of two things, first of all will this unit scan any barcodes, or is it just one particular one it will not scan. If nothing scans and if no special programming was added to the scanner I would consider defaulting the unit back to factory settings. This procedure can be found in the manual that came with the scanner or here is a link http://www.honeywellaidc.com/CatalogDocuments/00-02544%20Rev%20K%202-11.pdf *** If you are going to do this please confirm that no special programming was done to this *** but normally they are ready to scan right out the box. So scan the barcode to "enter/exit configuration" the unit will beep tree times, then scan the "recall defaults" and the unit will beep once. Then scan the "enter/exit configuration" once more. Then try to scan a retail barcode. Hope this helps.
Posted on Nov 02, 2012
My eclipse MS5145 is locked after the first scan , what can i do ?
connect the 2nd end of the scanner cable to a ps2 keyboard and reboot
May 11, 2012 | Metrologic Instruments Eclipse MS 5145...
Hi.....im using Eclipse Metrologic Instruments, model no.is MS5145 LS USB barcode scanner. now it is not working. whenever i tried to scan a barcode, it red light goes on continously. i also initialized it...
If the kit number : MK5145-71a48 that you referenced above is correct, your scanner is single ended keyboard wedge, not usb. You would need to order the correct cable : MX009-3ma7c from Honeywell to connect via usb.
Sep 14, 2011 | Metrologic Instruments Eclipse MS 5145...
My mac is not recognizing barcode reader honeywell MS5145
The scanner may need drivers, check for the brand name and go to their website to find the required drivers (if any.) If you already have drivers installed, try other USB ports.
May 04, 2011 | Honeywell MS5145 Eclipse with Codegate...
How can the barcodes can be stored vertically insted of horisontally on the computerscreen
Interesting question. Try scanning them with a printer/scanner and use as a photo, then rotate photo to vertical. For storage only. Then if you need them at any time just print out then scan them again, with barocde scanner.
Hope this helps
Nov 16, 2010 | Metrologic Instruments Eclipse MS5145
Trying to restore MS5145 Ecclipse scanner to factory defaults
Hello brett62. I can help you with this. I have the Metrologic Configuration Guide hosted on my website for my clients (www.shiftintoblue.com/resources/metrologic_config.pdf). Go ahead and download that pdf and you'll find the barcodes to recall the unit's defaults. I hope this helps. Good luck!
Jan 07, 2010 | Metrologic Instruments Eclipse MS5145
Hanging problem
scan the exit code it will close your scanner and then scan the recall default code (4 times) then scan the ENTER code your problem will be solve
Eshwer
Dec 18, 2009 | Eclipse Metrologic MS5145 Barcode Scanner
Need to ignore + (plus) caracter in barcode
This is done in the software that you are using to decode the scan, call whoever you got it from as there are many packages out there.
Sep 11, 2009 | Metrologic Instruments Eclipse MS5145
DON'T KNOW HOW TO USE
Firstly you connect ps/2 scanner cable of ms5145 to computer.then connect keyboard to Scanner.You can open word and Scan any barcode it displays on screen
Feb 14, 2009 | Eclipse Metrologic MS5145 Barcode Scanner
Scanner won't scan red ribbon
metrologic ms3780 scanner only scans a few times then stops..when you remove it from the base and reinstall it it works afew times then stops again?
Jan 02, 2009 | Eclipse Metrologic MS5145 Barcode Scanner
Eclipse Metrologic MS5145 Barcode Scanner Logo
768 people viewed this question
Top Eclipse Computers & Internet Experts
yuda kaufman
Level 1 Expert
 Russ Hill
Russ Hill
David Fischer
Are you an Eclipse Computer and Internet Expert? Answer questions, earn points and help others
