That is a monitor battery. How do I remove it? Please
  • 2,878 Answers
No, that is a CMOS battery. A CMOS chip hold BIOS software that instruct the motherboard. Removing it will clear all custom settings.
There should be a small clip, or part of the plastic holder is holding it in place. Either way take your time and be careful not to damage.
Posted on Nov 02, 2012
Replace battery in Acumen heart monitor watch
Important: remember the position of removed items.
Remove the four small screws on the back of the watch. I used a screwdriver designed for replacing screws in eye glasses.
Observe the position then lift the cover and take care to carefully remove the O-ring.
Observe the position then lift the case holding the battery.
Remove the battery again observe the position.
Replace battery, case holding battery, O-ring, cover and screws.
Your watch should how have power. Best wishes.
Feb 09, 2013 | Acumen Ergo Basix Heart Rate Monitor Watch
Mark of Fitness, wrist blood pressure monitor MF-78. Purchase date: a few years ago, I really don't remmber the date, From QVC. The screen is flashing the picture of the battery. This happens when i try to...
The picture looks very much like the Walgreens brand, which is manufactured by HoMedics. If that is the case, you can access the batteries as follows:
1. The battery cover is located along the bottom side of the monitor. Remove the battery cover by pressing down and pulling away from the monitor.
2. Remove the old batteries and take note of whether they are corroded or not. Install the new batteries according to the polarity indications inside the battery compartment. It will require 2 - AAA Alkaline Batteries..
3. Replace the cover by inserting it back into place.
Jan 25, 2011 | Mark Of Fitness MF 81 Wrist Blood Pressure...
My hp notebook dv2201ca power on by itself, but lc...
Hi, to isolate the issue perform the following.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
Step 2 :External Monitor
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook.
May 20, 2010 | HP Pavilion dv6000z Notebook
When I turn on My HP Laptop the system start booting and all of the lights on the laptop turned on but the screen doesn't display a thing it is always dark could anybody help me... Thanks in advance...
This could be due to presence of static charges or hardware malfunction of video card or defective LCD display screen of your notebook. To isolate this issue, perform the following:
HARD RESET
This will discharge the static charges from the notebook. Now check for the issue. If the issue persists then connect an external monitor to the notebook and check if it works fine. You can follow the steps listed below to connect an external monitor to the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear/side of the computer.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
May 18, 2010 | HP Pavilion dv1000 Notebook
Monitor will not start up on off switch is blinking
The problem is actually in the CPU and not in the Ram
This happens due to dust in the Ram .In order to fix the problem try removing the Ram from the slot and fix again after cleaning the Ram and the Ram slot .
If the problem persists try resetting the Bios by removing battery.
please rate me
May 11, 2010 | Dell E193FPC 19" TFT LCD Flat Panel...
It turns on then immediatly goes black
hi,
check the power supply to the monitor...
the problem here is a corrupted BIOS you can correct it by booting the system with default settings...
if you are not getting any display then you can try the following
it should be blinking, the lights on the monitor... the cpu is working (all fans running)
then switch off the system...
remove the cover of the CPU on the motherboard there is a small battery called CMOS battery take out the battery after a minute later put it back...
it should fix it....
please give a vote if it helps
Mar 13, 2010 | Computers & Internet
When I'm booting my system I getting a message "Monitor going to sleep" in my monitor.. I dont know why this happens? Please help.. Im using HP w1707 monitor...
this is not your monitor problem...
remove the monitor cable from CPU Blow some air, clean the clip & reinsert it...
now reinsert the cable & start your system
hope its done...
And if its not done, open your CPU & remove the CMOS Battery and then start it... then reinsert it & then again start it..
Hope it worked u out... If u liked my post, please rate me.. i really need some good ratings..
Jan 29, 2010 | HP W1707 LCD Monitor
DOESN/T DISPLAY ON MONITOR
Does the monitor work on the BIOS setup screen?
If not, reset the mobo: either remove the mobo battery for a few minutes, or "short-out" the two reset pins next to the battery or next to the CMOS BIOS chip.
If you are not using the built-in video interface, then put two monitors on the system and adjust the way you want the monitors to behave.... or disable the built-in vga interface through the BIOS setup.
More info, please....
Sep 30, 2009 | Biostar GF7050V-M7 nVIDIA GeFORCE 7050...
Monitor screen going black.
Hi
Please try with resetting bios by remove the bios battery for 5 mins from the motherboard, It should work if not the try with reinsurting the RAM from its slot if your system has 2 RAMs then try with single RAM. It will solve your problem
Boopathy.T
Aug 17, 2008 | Computers & Internet
Soltet sl-85erv motherboard
if there is no issue with your monitor then try to reset your CMOS by shorting the jumper or by removing the CMOS battery
remove the battery and start your pc after 10 sec power off and put the battery again and follow the instruction on the monitor or press the del key and F2 to enter into the bios do this and let me know.
Nov 12, 2007 | Soltek X400A (SL-85ERV2-L) Motherboard
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
