Question about Cuisinart Supreme Grind DBM-8 Electric Burr Grinder
Cuisinart DBM-8 coffee grinder started by itself.
I was in another room, in the house alone, and all of a sudden I heard the grinder going. It went through a whole cycle. Nothing fell on top of the start button. I just unplugged it. is this an electrical problem? There was no indication of a power surge or outage.
Mine did it as well. I had an electrician out to check out the outlet. He replaced the outlet, but it still has done it. It freaks me out, so I unplug it after use.
Posted on Feb 05, 2013
4 Suggested Answers
SOURCE: Cuisinart DBM-8 Grinder Automatic Burr Mill stopped grinding
perhaps remove the hopper (top) and inspect to see if a buildup of very fine compacted grounds as accumulated. knock the stuff loose.
Posted on Mar 28, 2009
SOURCE: coffee grinder not working
My burr grinder also stops if the ground spout (where the coffee shoots out) is clogged. I use my grinder for an espresso machine so i always have the setting on the finest and so with the oils and the fine grind it clogs this spout pretty often. I"d check yours out too (ie remove the coffee ground bin and you can see the spout. If it is clogged uplug the machine and take a tooth pick and un clogg it. Don't jam the tooth pick in there to deep you don't want it to get shuved into the grinder wheels.
Posted on Feb 07, 2010
blueextc3221
  • 15935 Answers
SOURCE: Coffee grinder won't work
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 14, 2010
How do i clean dbm-8 grinder
Do yourself a favor and got the right kind of grinder for the coffee you drink. If you have a dry coffee use a grinder. High oils in some coffee need the blade type of grinder. Usually you can tell by looking inside the bad. See oily coating get a blade type.
Feb 19, 2015 | Cuisinart Supreme Grind DBM-8 Electric...
Grinder will not grind or turn on
will not stay turned on. have to keep hitting start button
Jun 28, 2011 | Cuisinart Supreme Grind DBM-8 Electric...
Grinder does not run at all.
MY DBM-8 CRUISINART WILL NOT GRIND COFFEE BEANS THE
Apr 04, 2011 | Cuisinart Supreme Grind DBM-8 Electric...
Grinder will not start
Make sure that the coffee ground container is fully inserted. You may need to make sure there are no grounds are keeping it from seating properly. Use something soft such as a toothpick to clean it thoroughly...Good Luck.
Mar 05, 2011 | Cuisinart Supreme Grind DBM-8 Electric...
I have a cuisinart ccm-16pc coffee grinder. I need a couple of parts, namely the grinding wheel (that's attached to the motor) and the plastic gromet (for lack of a better word) that fits on top of the...
For future reference the Manual for the DBM-8 is here:
http://www.cuisinart.com/share/pdf/manuals/dbm-8.pdf
Available parts:
http://www.cuisinart.com/parts/coffee_bar/dbm-8.html
Here is another site for parts; they do not list what you are looking for but you can make an on-line inquiry for parts.
http://www.abtecparts.com/cuisinart_grinder_DBM8C.htm
Parts Inquiry:
http://www.abtecparts.com/parts_enquiry.htm
Unlike many appliance makers Cuisinart does not have an on-line search function for service centers. If they could not name one you might try contacting some small appliance repair shops; if not able to help they may be able to direct you.
Feb 13, 2011 | Microwave Ovens
Grinder fell. Black "button" inside broke off.
Use just about any 2-part epoxy, clean parts with rubbing alcohol first to remove coffee oil and get a good bond.
Nov 08, 2010 | Cuisinart Supreme Grind DBM-8 Electric...
Coffee does not go from grind to brew basket. Plugs..must clean every time
Try running some unflavored panko breadcrumbs or rice through it. That will clean it up and remove any oil that's causing sticking. Try to use less oily coffee in the future to avoid this.
Feb 03, 2010 | Cuisinart Supreme Grind DBM-8 Electric...
Cuisinart grinder stem wobbles
Search Cuisinart's website for DBM-8 - that model has exactly the same parts as your Cuisinart. If you call them, they may even cover it under warranty.
Jun 22, 2008 | Cuisinart Supreme Grind CCM-16PC Grinder
Cuisinart grinder wobbles
The model that you have is Costco's equivalent of the DBM-8 - the parts are exactly the same, so enter "DBM-8" as your model # on the Cuisinart website for parts.
Dead machine
It's under warranty, contact Cuisinart for repair.
Jun 21, 2008 | Cuisinart Supreme Grind DBM-8 Electric...
Cuisinart Supreme Grind DBM-8 Electric Burr Grinder Logo
292 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
