Question about Foxconn NF4UK8AA-8EKRS Motherboard
Foxconn NF4UK8AA-8EKRS NO BOOT
I have hooked everything correctly into my computer with a Foxconn NF4UK8AA-8EKRS Motherboard and plugged everything in. But when i hit the power button nothing happens. The only effect when the power supply is turned on is the lan lights flash for a split second. What could possibly cause this? I have tried other powersupplys with no luck. Any suggestsions would help.
  • 2 more comments
  • Greg Kenneally May 19, 2007
    Okay thank you. I think it is something else than the motherboard as i had the same problem on the first one i recieved and RMA'd it and am still having the same problem with the new motherboard. Could you explain what buggling is? Is a cmos battery easy to replace and is there any way to make sure this is the problem? I have an alternative processor that i will try. Thank you for your help
    I tried the other processor i had and still no luck is there a chance that the front panel with the power button is not working? How exactly do i check the capacitators? Is there a chance it is my power supply and how would i check for that? I will continue to try differnt things like ram and ram slots.
  • Greg Kenneally May 20, 2007
    Okay thank you. I tried changing the battery with one from an older computer. I will contintue to try different combinations of batteries, memory, and processors. Thank you for the help if anything else comes to mind it would be appreciated. I will also look for bulding thank you for the picture it is very helpfull
  • Anonymous Mar 13, 2008
    Intermittant no-power up problem. Thought it might be power on leads, nope...power supply leads..check OK...very perplexing. If I jiggle all the cables. pull and reseat power cord it will fire up but I can't isolate problem yet.
    President:
  • 2,961 Answers
Could be one of three things, either your motherboard is faulty (check the capacitors for bulging) and is not getting the power to the processor, the processor itself has faulted, or it's simply a flat cmos battery, as this can cause none starters.
Posted on May 19, 2007
  • andrew pester
    andrew pester May 19, 2007
    it wasnt buggling it was capacitor bulging, and the cmos battery is very easy to change its on the motherboard called cr2032 its flat disc shaped.
    __see image of bulging capacitors
NF4UK8AA-8EKRS motherboard no longer sees either of the SATA hard drives. Any thoughts?
Hello here is the homepage:
http://www.foxconnsupport.com/download.aspx?models=en-us0000013&category=C000000001&brand=en-us0000002&Series=en-us0000004&chipset=en-us0000064&keywords=&sort=
Try to enter the bios, and look for the harddrive settings.
The driver is needed for the pci card, do you have them ??
Your friend could have damaged the mainboard.
Good luck
Jan 30, 2013 | Foxconn NF4UK8AA-8EKRS Motherboard
Cmos ckecksum error
Hello change the battery on the mainboard.
Its a 2032 watch type.
Try to look in the manual or get a computer repair guy
to change it.
It does not cost much.
Jul 17, 2012 | Foxconn NF4UK8AA-8EKRS Motherboard
How and where do I get a FOXCONN passcode?
U dont need one
passcord is a simple authentication they ask
just simply type 0000 there u go
try this this will work
Dec 08, 2009 | Foxconn NF4UK8AA-8EKRS Motherboard
Foxconn NF4UK8AA-8EKRS doesn't recognize CPU
Smithbrother is right...
the file you need is here:
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001689
You'll have to get yourself a BIOS flash utility. There are some simple, good boot disks for that here: http://www.bootdisk.com/
then you'll need to boot to that disk (not into Windows), and run the flash utility provided at the previous link. Once your BIOS has updated itself, you should be good to go.
This is a known issue with early BIOS revisions of your board.
Jan 17, 2009 | Foxconn NF4UK8AA-8EKRS Motherboard
Computer just beeps when you turn it on
The beep is part of the POST (Power On Self Test). Does it just beep once or is it a combination of beeps. If there's more than one beep you need to let us know what the sequence is.
Dec 29, 2007 | Foxconn NF4UK8AA-8EKRS Motherboard
Won't boot or start, fans and leds work
Are you hearing any beeps when you start it up?
Dec 17, 2007 | Foxconn NF4UK8AA-8EKRS Motherboard
Restarting
It sounds as if you have a flat CMOS battery, remove and replace. To delete the password and bios settings locate 'JBAT1' terminal on motherboard and put jumper from pins 1-2 across 2-3 for a few seconds and then back to pins 1-2. You will have to reset time and detect drives in standard CMOS settings.
Jan 09, 2007 | Foxconn NF4UK8AA-8EKRS Motherboard
Foxconn NF4UK8AA-8EKRS Motherboard Logo
628 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Anders Bergwall
Anders Bergwall
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
