Question about Panasonic Smart Viera 65"" Class Vt50 Series Full Hd 3d Plasma Hdtv 64.7"" ..."
Panasonic vt50 65 inch keeps losing my wireless connection.needs a factory reset to start again
Wireless internet. when i turn on tv my wireless connection will not work. every time i try connecting it says nothing found when i do a factory reset it then finds my wirless router ok. but after several times days it losing it again . i then have to keep using the factory reset to connect it again. please help
GregV24CHOPP
  • 11 Answers
SOURCE: 50 inch Plasma panasonic TH-50PZ80U.
if you have a warranty let them check it out before opening the panels, it may void it.... may be an internal power short.
Posted on May 14, 2009
keiffertech
  • 96 Answers
SOURCE: Having a problem connecting HP G50 laptop to TV
You will have to select the input for this connection.
Posted on Sep 03, 2009
SOURCE: Push the reset button
My camera has been doing this too, searched this site not through product but problem and found this solution posted by "margarita" for another camera. Said to try removing/replacing the tape. When I pushed the eject button the tape did not come up, removed the battery for a minute and tried again. This time the tape came up so I removed it and put it back in, it seems to have worked. The reset button is not flashing and it did record and playback when I tried them.
Posted on Jul 28, 2007
Orbixx
  • 133 Answers
SOURCE: panasonic ct-36hl43 tv
This is usually down to a safety feature cutting out the Television from harming itself. Or quite possibly a fault that make it turn itself off - it may well be thinking it's receiving the command to turn itself off. Either way, it's impossible to find out without opening it up. A professional repair is the only way, check up on your warranty. You may want to plug it into a different power source, just on the off-chance that it may solve your problem - but don't get your hopes up.
Posted on Sep 07, 2007
SOURCE: PANASONIC DMR-ES30V KEEPS SWITCHING OFF
I had this code (f09) on my Panasonic DVD VHS recorder. After seeing that it meant overload I took the cover off to look for burnt out components. I found that an electrolytic capacitor had bulged (look up capacitor plague on wikipedia). I replaced the capacitor with one of a similar value from an old power supply and it worked fine.
Posted on Mar 01, 2008
I have a Panasonic 55 inch Smart TV (sorry I don't know the model number) but when I try to connect it to the Wifi, and it does the search, it doesn't find any sort of Wifi to connect.
Do you have wifi installed in your place. You need to have an internet connection and a wifi router to enable your TV to connect to it.
Jul 03, 2017 | Panasonic Computers & Internet
48" HISENSE SMART TV 2014 /I HAVE NO WIRELESS INTERNET CONNECTION ANYMORE
Check out your manual and look for the section regarding connecting to your home network. The tv set must detect the network for it to properly set up the connection after you give it the name and password to your account.. Check for the network working properly with your laptop or other device(s). If those units connect then the problem has to be with the wireless circuits of your tv.
Can also try resetting the set to factory condition and starting anew with the setup procedure. Also unplug the set while it is on - then while unplugged press in the "on" button on set for about thirty seconds. Then replug set and try again.
Mar 06, 2016 | Hisense Televison & Video
Keep losing connectivity to wireless network.
Problem could be with your wi fi transmitter or the receiver in your device. Use another known working device and see what happens so you can localize the source of the anomaly.
Aug 23, 2017 | Amazon Kindle Fire HD
Netgear wifi router
1) does it lock up completely or will it work hard lined when wifi fails?
2) do all devices wireless fail or just a single device?
3) do you lose connection to the wireless completely or keep the connection but lose access to the internet? (confusing but very different to me)
in the end you could narrow down the problem but if you have already reset to factory defaults and set back up again and again then it may be time to retire that old router.
Dec 28, 2012 | NetGear DG834G Router
Internet light keeps flashing and I lose internet connection every 9 - 10 minutes
Hi and welcome to fixya.
This kind of problem can be either an ISP problem (which cannot be fixed from here) or a router problem.
If it is the latter, the following can cause such a problem:
  1. If you are trying to connect via wireless, make sure that there is nothing blocking the wireless signal from the computer to the access point/router and that they are close enough to one another.
  2. Try to reset the router to default factory settings or upgrade its firmware to start from the beginning its setup. Latest firmware can be found here and general setup/reset instructions here. If this was caused AFTER you reset or upgraded the firmware of the router, this indicates that you missed all the previous settings (if something was needed specifically for internet to work).
  3. Try to connect via ethernet cable only or wireless only if the problem is in either just to see the difference in connectivity issues in each case.
  4. Try to use the following commands (cmd prompt for XP/Vista/Win7) to get and check the network settings that the computer gets every time you connect.
ipconfig /all (this shows general connectivity info,if you see a computer's IP address of 69.*.*.* then the problem is with your ISP's modem which probably needs re-setting).
ipconfig /release (this releases all ethernet or wireless from any IPs that the router provides. Equals to 0.0.0.0. - use ipconfig /all to review the change after the command finishes).
ipconfig /renew (this renews all ethernet or wireless IPs from the router. Again if you get any addresses starting with 69.*.*.* the problem is with your ISP).
Please let me know if this troubleshooting helped you at all.
**Don't forget to rate this solution**
Thanks.
Regards from FixYa.
Apr 06, 2011 | Zyxel P660HWD1 v2 WirelessADSL2+ Gateway...
I have been setup on my panasonic tv model # TC_P50G20 for about two months. Then out of the blue I keep getting connection to the server failed code 001. I know that it is not the router or wireless...
Tries tv,router or wireless adapter unplug,replug it back about an hour.For tv reseting it back to the factory setting and router or wireless adapter to reboot so all incomming signals in these devices are in sync together.The server signal sould be back to the tv.
Feb 06, 2011 | Panasonic Viera TX-P65V10 65 in....
My belkin n series keeps losing internet connection hard wired to my computer and three wireless computers in the house. when hard wired to the virgin broadband modem everything works fine
I would suggest taking a look at your modem LEDs. What happens exactly when you lose connection? A look at the LEDs should give you some thought as what might be causing this. You can also try resetting your Belkin to default factory settings by pressing the Reset button at the back for 30 seconds, and then putting back your Belkin settings.
Nov 16, 2010 | Belkin N1 Wireless-N Wireless Router
I have an AT&T Uverse provided 2Wire 3800HG-B gateway in the basement. My desktop PC is on the 2nd floor and connects to the internet at 11Mbps when the TV is not on. When we turn the HDTV on, we lose...
Turned on the TV, but not the Uverse box and still lost the internet. Determined that it was the Panasonic Home Theater wireless speakers which operate at 2.4 GHz causing the interference. Next step is contacting Panasonic to see if they have a solution for that issue.
Oct 02, 2009 | 2wire (1000-400108-001) Router
Laptop wont connect to wireless belkin router
If you connect the laptop wired, does it work correctly?
If your Wireless router has password protection, try resetting it to factory defaults, and connect it that way.  If you can connect with the factory defaults (with no security), it's likely an issue with the security on your router.
I'd suggest starting again. Reset to factory defaults, re-secure the network and try a different SSID name this time, and try again.
Mar 18, 2009 | Gateway 802.11g Wireless DSL/Cable Router...
Panasonic Smart Viera 65"" Class Vt50 Series Full Hd 3d Plasma Hdtv 64.7"" ..." Logo
831 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
