Question about Electrical Supplies
Dayton 5JJ84 generator won't start. Oil is full, battery is new. What should I try to get it to start?
Generator worked for 3 days...was turned off to let cool during the day for 3 days...was on at night only for 12 hours. .
  • 8 Answers
SOURCE: Generator is not working!
pramac has bought coleman powermate. to order parts call 1-800-445-1805. my guess is the printed curcuit boaed on the back of the gen head is bad if sparking the roter doen't fix it. i hav e had to change alot of these boards out.
Posted on Oct 15, 2008
SOURCE: Brand new Generator not working
Take it back where you bought it with the sales receipt. Just about everything has at least a one year warranty, Anything that's well built should last AT LEAST one or two years. As long as it wasn't submerged, abused or dumped off the tailgate of a truck they should make it right for you.
Posted on Oct 22, 2008
MokSport
  • 4 Answers
SOURCE: New battery in 03 VW Passat, engine turns but will not start.
Possible flooding, cold weather can freez open injectors causing them to leak into the cylinders. Press the gass pedal all the way to the floor and crank the engine for no more than 60 seconds. The cylinders will clear themselves allowing proper mix of air/fuel and should start easy. If that does not solve please specify if the engine is 1.8l or 2.8l.
Posted on Jan 18, 2009
  • 83 Answers
SOURCE: My troy-Bilt 5550 watt generator will not start
First drain the fuel bowl. Any old fuel in there will keep it from starting. Fuel stabilizer is not what it's it cracked up to be. I've worked for 6yrs at a rental yard and had no luck with any fuel stabilizer, the fuel still went bad. If after you drain the fuel bowl it still will not start, you will need to clean the carb. Remove the carb and spray carb cleaner through all the accessible passages. If this does not do it, you will need to replace the carb. For long term storage I highly recommend draining all the fuel and filling just the carb with fuel stabilizer to keep gaskets moist. Then drain the carb when you take it out of storage.
Posted on Mar 30, 2009
  • 1632 Answers
SOURCE: honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
Posted on May 22, 2009
Low oil sensor
I would let it cool completely and see if it starts again. There are no specific timers that say after detecting a low oil shutdown don't start for X amount of time. It is more than likely a choke setting as it is hot, and you may now have flooded it.
May 11, 2013 | Powermate Portable Generator: 3250-Watt...
Kohler 14 RES won't start
You need a couple of things / options. The carb heater base, and an oil heater (srews in the drain hole, and possibly a battery blanket at that temp. Some OEM's offer an adhesive strip that you can also stick to the bottom of the alternator, that is also 120V and warms the generator windings to keep moisture out
Not sure what country you ar ein but in the USA/CA they will be a 120V accessory and as such need utility power at the generator
Dec 31, 2012 | Kohler 14RES 14 Kw Generator
Husky generator won't start
did you try cleaning the conductor that goes to the spark plug if not try to clean it with a real fine sand paper it should do the job.
Oct 27, 2012 | Husky Portable generator
Onan 5500 marque gold turns over but, won't start. fault code is 32 but, batteries ok, air cleaner ok, fuel pumping, oil changed, won't start
Code 32 is a low cranking speed sense. You didn't mention a Spec # which would help. You say batteries are ok, but the generator is not getting enough cranking amps or voltage to maintain the control properly. Check, battery voltage, wiring, any in line isolation solenoids, check generator solenoid, also make sure there is no mechanical binding on the generator, a good way to do that is remove the spark plugs DISCONNECT THE BATTERY to prevent starting, underneath where the air intake is under the alternator is a plastic plug, remove that and you can put a socket I believe 3/4" up onto the alternator shaft and rotate the engine, if it tuns freely there is no binding, if you feel it is hard to move, check the drive train, belts, pulleys underneath (A lot of work, best to take to a dealer if it is mechanically bound)
Sep 13, 2012 | Onan Marquis Gold Quiet Gas Generator 5500...
1998 Ducati Monster 750 won't start. Ticks over ok, but won't "fire". New fuel in tank only two days ago, ran several trips since, just won't start now. Tried push-start, sounds like...
Hi, Mlyndon and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
1999 750SS engine turns over but won start Ducati ms The Ultimate Ducati...
Ducati Monster won start fixed see how
Free Ducati Motorcycle Service Manuals for download
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Aug 31, 2011 | 1998 Ducati Monster 750 - Dark - City -...
It's almost brand new but i did not start it for about 10 months. Now i can't get it to start
the #1 enemy of generators or any outdoor power equipment. Old gas. It turns to gook that gunks up the works.
Jun 24, 2011 | Coleman Powermate Powermate 5000W...
I have a ford f350 duelly and it wont start but it will turn over i have jump started it and it started and now i have had it pluged in for 2 days and it still wont start plz help me figure it out
If its a diesel then you may need to get a spray can of ether starting fluid. Spray this directly into your air filter housing for approximatly 3-5 seconds. Try it once then try to start your truck. if it doesnt work then have someone else spray it in while you turn it over. However your problem maybe that you dont have enough charge in your batteries to completely turn your engine over to get full compression. in this case charge your batteries and try again.
Feb 04, 2011 | 1991 Ford F350
Electrical Supplies Logo
154 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
