Question about Everest & Jennings E & J Vista Ic Wheelchair 18X16 Detachable Full Arm, Swingaway Footrest
Need an 8 inch front wheel - Everest & Jennings E & J Vista Ic Wheelchair 18X16 Detachable Full Arm, Swingaway Footrest
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
Try "the after market group"
Posted on Nov 10, 2012
Will an 8 inch wide rim fit my 2001 jeep grand cherokee limited
Anything fits if you increase ride height accordingly. As long as it clears the brakes it should only affect how far the front wheels will turn before rubbing the wheel wells.
Jul 13, 2014 | 2001 Jeep Grand Cherokee
What are the wheel and tire sizes front and rear for my 99 1200 sportster?
Fitment for 1999 XL Tubeless Cast Wheels:
Wheel Position and size = 19 inch Front; Rim Size and Contour = T19x 2.15 MT; Rim Valve Hole Diameter = 0.45 inch; Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16 x 3.00 D; Rim Valve Hole Diameter = 0.35 inch Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 100/90-V19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16x3.00 D; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 130/90-V16
Tire Fitment for 1999 XL Tube Laced Wheels:
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Tube Size = MJ90-19 Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16 x 3.00 D ; Tube Size = MT90-16; Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 21 Inch Front; Rim Size and Contour = T21x215 TLA; Tube Size = 3.00 x 21; Tire Size = Dunlop Touring ELITE II MH90 - 21 56H
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16x 3.00 D; Tube Size = MT90-16; Tire Size = Dunlop Touring ELITE II MT90 - B16
Tire Pressure - All Models:
Cold up to 300 Lb. Load (includes rider, passenger and cargo)
Front = 30 psi (2.1 bar)
Rear = 36 psi (2.5 bar)
Up to GVWR maximum load
Rear = 40 psi (2.8 bar)
Jul 07, 2014 | 1993 Harley Davidson XLH Sportster 883
What tools are need for monte carlo front brake job
Hi: You'll Need a Floor Jack ,Jack Stands, To Keep it Safe ,Loosen Lug Nuts on Front Wheels Before You Jack it up. Then After Tires are Off, You'll need a 3/8 Inch Either a Allen L-Shaped Wrench or Even better and i Recommend you Use a 3/8 Inch Socket Type Allen Wrench,Using this you'll need a Ratchet to Fit the 3/8 Inch Socket Allen ,This Allen Socket is needed to Break Loose your Caliper Hold Down Bolts,There Located on Back Side of Caliper Theres On 2 of Them.Then You'll Rock the Caliper Back and Fort until it Comes out of the Caliper Bracket.If its Stubborn you Might Need to Use a Large Screw Driver to get Sme Leveage Under the Caliper to Get it Off.The You'll see the 2-Pads ,HERE Look and See which Pad goes in the Back Side Of Caliper and Which one to The Front Side.Normally the Pad With a Spring Like Tab Goes on The Inside And That Tab Fits into the Caliper Piston.Then you'll Need a Large C-Clamp To Compress the Caliper Piston Flush or Even With The Caliper Housing. You can Use 1 of the Old Pads To Tighten and Compress the Piston Back.The Old Pad you Use will be used on The Piston Side. As Far as Tools Thats Really ALL you'll Need. T\Let Me know How I Helped you By Voting on My Solution i Sent You. Thanks the WYOCWBOY
May 30, 2010 | 1999 Chevrolet Monte Carlo
How to remove and replace rear wheel tire on my mtd self propelled lawn mower model #126-478n134 part #634-0020 tire sized 8 inches.
Part # 634-0020 is listed for the FRONT wheel. Your post asks about the rear wheel. I was unable to determine if the same part number fits the rear.
FRONT
1) Remove plastic hub cab with a screwdriver around the outer edge.
2) Loosen the shoulder bolt in the center of the wheel (My guess is that you will need a 3/4 inch socket).
3) Leave the bolt and all washers/bushings together and remove the entire wheel assembly as a unit (the bolt serves as the axle).
4) Note the component locations and install the new wheel exactly as the old came off. Do one side at a time to be sure the reassembly is in correct order.
Working from the bolt-head to the mount hole, the assembly should go as follows: Shoulder-Bolt, Wave-Washer, Wheel-Bushing, Wheel, Wheel Bushing, Bell-Cone Washer, Mounting-Hole.
REAR
2) Straighten and remove 1/8 inch cotter pin from center of axle and slide ratchet-spur off the axle while making note of the tooth direction.
3) Slide the remainder of the wheel assembly off the axle.
4) Remove the small shoulder bolt from the ratchet-pawl and note the direction. Remove the ratchet-pawl and ratchet-plate from the wheel. On the inside of the wheel is a "pem-nut" which may need to be held with pliers.
5) Reassemble Ratchet-Plate, Pawl, Pem-Nut, Spur and Cotter Pin in the reverse order.
As was mentioned before, doing one at a time will help keep the parts in the proper order.
Hope this helps!
Sep 30, 2009 | Mtd 22" Yard Machine Push Mower
I need a diagram on front hub and brake assembly for 1999 dodge 1 ton dually 2 wheel drive. the front brake rotor is warped i need to replace it
8–Stud Rotor
  1. Raise and support the vehicle.
  2. Remove the wheel.
  3. Remove the hub extension.
  4. Remove the brake caliper assembly.
  5. Remove the axle nut cotter pin. Remove the axle nut.
  6. Disconnect the ABS wheel speed sensor wire from under the hood. Remove the sensor wire from the frame and steering knuckle, if equipped.
  7. Back off the hub/bearing mounting bolts 1/4 inch each. Then tap the bolts with a hammer to loosen the hub/bearing mounting bolts.
  8. Remove the bolts and remove the hub/bearing assembly.
Sep 16, 2009 | 2000 Dodge Ram 3500
1996 buick lasabre
A 1996 Buick Lasabre is a front wheel drive (FWD) car, so the front of the motor is facing the front passenger side wheel of the car. That said, the power steering fluid reservoir should be close to the front passenger side wheel tower.
Apr 07, 2009 | 1996 Buick LeSabre
2006 subaru legacy remove front brake rotor
Hello, hope this info helps...(subytech1)...
REMOVAL
15-INCH TYPE
  1. Lift-up the vehicle, and remove the front wheels.
120334720
  1. Remove the caliper body and the support from housing, and suspend it from strut using a wire.
120334721
  1. Remove the disc rotor. NOTE: If the disc rotor seizes up within hub, drive the disc rotor out by pushing with an 8 mm bolt in holes B on the rotor.
  2. Clean mud and foreign particles from the caliper body assembly and the support. 16-INCH TYPE Refer to 15-inch type. 17-INCH TYPE Refer to 15-inch type.
INSTALLATION
  1. Install the disc rotor.
  2. Install the caliper body and the support to housing. Tightening torque: 80 Nm (8.2 kgf-m, 59 ft. lbs.)
  3. Install the front wheels.
Mar 27, 2009 | 2006 Subaru Impreza
Jacking points
Please consult your owners manual. The manufacture is very specific about where to jack this car for safety reasons. If you do not have a manual, buy one and or talk to the dealer about this issue
Feb 09, 2009 | 2001 BMW 5 Series
2000 Silvrado z71 4wd Brake Pad Replacement
crawl underneath the front and look at the caliper if it has a duel piston caliper you will see 2 circles about 3 inches across and if it is a single piston caliper it will only have one of these circles in the middle this iswhere the pistons are. yes those pads are suitable. As for bleeding the brakes you need to start at the passengers side rear wheel and bleed it first then go to the drivers side rear wheel then go to the passengers side front wheel and then finally the drivers side front wheel. If you are only replacing the brake pads and shoes then you don't need to bleed the brakes. If you are bleeding the brakes then you will want to be sure to top up the brake fluid as you are doing thebleeding process as if you don't you will end up having to start all over again. as for special tools you may need a 3/8 hex bit and a 8 inch " C " clamp to compress the calipers after you remove the brake pads. If you are replacing the rotors you may require a special socket fo dis-assebleing and re-assembly of the front hubs.
Oct 05, 2008 | 2000 Chevrolet Silverado
Everest & Jennings E & J Vista Ic Wheelchair 18X16 Detachable Full Arm, Swingaway Footrest Logo
Top Everest & Jennings Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
ray gallant
Are you an Everest & Jennings Health and Beauty Expert? Answer questions, earn points and help others
