Question about Husqvarna 155bt Gas Backpack Leaf Blower
Husqvarn 140bt gas backpack leaf blower what is gas/oil ratio
  • 251 Answers
SOURCE: husqvarna 125bt backpack leaf blower. I put
if you've ran it for any length of time you will need a new cylinder and piston/rings and cylinder gasket ,
take the muffler off and look for scoring /scorching on the piston
Posted on Oct 21, 2009
jdlipscomb41
  • 157 Answers
SOURCE: what is the ratio of oil to gas for Husqvarna leaf
i mix my husky and stihl the same 50;1 ratio that way i know it has enough oil not to burn the piston
Posted on Oct 26, 2009
  • 430 Answers
SOURCE: Husqvarna 155bt Gas Backpack Leaf Blower throttle
Do you mean the throttle lock? It is a basic mechanical lock. If it just spins I would assume that a chunk of plastic has broke off or the lever is misplaced. Take the throttle housing apart and identify the problem. New parts are available from your local Husqvarna dealer.
Posted on Nov 26, 2009
  • 5 Answers
SOURCE: 1. what ratio of oil/gas
50-1..... but be very careful and exacting with this mix... one can usually pick up a six or eight pack of these mixes that are meant to mix with one gallon (as close to exact as possible ..but never go over on the gas amount and dump a little bit of the gas back into the mix oil container ,shake it and pour it back into the gallon jug to get all the oil out of it or your mix will be diminished and may possibly be to hot and overheat your piston....) the leak can generally be fixed by aquiring a fuel hose kit at a hardware store for your particular model...it could be one of a few problems ...a cracked hose or rubber seal on tank or possibly a loose hose or clamp on the carburator..check the tank itself for leaks and the fuel cap seal (a flat rubber ring ..or possibly the vent in the cap ,which is designed to not let fuel through,only air)....it should be evident when blower warms up... a slight seep is more evident than a good sized one that drips quickly...try to tighten fittings before going through cost of repair kit...if it has been dropped on a hard surface...the tank itself or the fuel cap may be cracked...
Happy blowing! ..and let me know...Oh...one more issue is that the primer bubble may have a pinhole leak in it...and check air filter for if it is dirty it could possibly creat a vaccuum in carburator that **** more gas than the blower engine can use...causing a blowback and flooding problem...
Todd
Posted on Nov 23, 2010
  • 64 Answers
I would read the directions On the machine. If you use it hard you can bring up the ratio a little.
Posted on Nov 09, 2012
What is the oil mix for 2 gallons of gas for a 2 cycle gas leaf blower
Only use 50 to 1 as that is what is specified.
To get 50 to one ratio with the 6.4 oz bottle of 2 stroke oil just add 2 1/2 U.S.. gallons and that will be 50 to 1 ratio so you will have the correct ratio .
Aug 11, 2014 | Husqvarna 130bt 130 Bt Gas Powered...
Have Stihl model Br400 Backpack the problem is the engine will not reach top rpm.
The oil to gas ratio is off - you need to either dump the fuel or run all the fuel out of the unit clean the carb and tank - replace the plug and filter mix gas and oil to correct ratio start and let run for 10 to 15 minutes - your carb may need to be adjusted as well.
Jan 08, 2013 | Stihl BR400 Backpack Leaf Blower
Oil to gas ratio
The ratio is 50:1. You can usually by oil in a container that matches the size of your gas can, takes the guess work out of it.
Nov 05, 2010 | RTO Echo Pb-755 Backpack Blower In Box
How much 2 cycle oil do i add to 4 gallons of gasoline
Add 3.2 oz of 2 cycle oil to one gallon of gas (40:1 ratio)
Dec 26, 2009 | Husqvarna Backpack Blower, Model No. 356bt
Need to find the oil to petrol ratio for Husqvarna 132 HBV blower
50:1
50 parts fuel to 1 part oil. The easiest way is to purchase the little premix bottles of Husqvarna oil- one bottle to one gallon of fuel. You can find premix oil bottles at the dealer that sold the blower.
Nov 20, 2009 | Husqvarna 155bt Gas Backpack Leaf Blower
What type of oil goes in the Ryobi 08570 Blower? What is the oil gas mix ratio?
You need 2 stroke motor oil or chain saw oil.Mix it according to the lable to make up 50:1 oil/gas mix.
Nov 07, 2009 | Ryobi Backpack Blower 25.4cc
Husqvarna 155bt Gas Backpack Leaf Blower Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
