Question about Sony PS-LX250H Turntable
Ground Wire For Sony PS-LX250OH Turntable
I need the ground Wire To This Turntable
  • 3 Answers
SOURCE: I need to determine appropriate stylus replacement
any stylus should work i think radio shack sells them for pretty cheap and I know for sure that best buy sells them for cheap thats where I got mine. Best though from what I can remember is diamond tip but very coastly.
Posted on Sep 23, 2009
SOURCE: Tremendous Rumble when using my new turntable
i have the same problem with my pioneer pl 510 .My technics is solid no microphonic noise when i touch the table ..yes both are grounded .. also when the bass is turned up i get this horble low end feed back ...nothing with my technics TT so its not an isolation thing or it being too close to the speakers .what is the problem ?? anyone with experience in older TT's might be able to help .As far as putting foam under the turntable that is complete ******** sorry .I know what this guy is talking about .
Posted on Nov 14, 2009
AJIN G
  • 6694 Answers
SOURCE: How can I ground my
hi,
take a wire connect its one end to the screw on the bottom on ur turntable and the other end to ur receiver's turntable ground. if there is no such point. connect it to chase, loosing any one screw of ur receivers top cover.
or take metal sheet( same dimension of ur turntable legth and width ). put ur turntable on it. make a connection from the metal plate to to ur chase.
ok
Posted on Dec 17, 2010
AJIN G
  • 6694 Answers
SOURCE: I NEED TO GET THE BAND BACK ON MY SONY PS-LX250H
hi,
whach the following video for replacing the belt
showing technics also same for any belt drive turntable.
ok
Posted on Jan 05, 2011
shajanrs
  • 890 Answers
SOURCE: I need a diagram to
I'm sorry for the difficulties you're experiencing in installing the drive belt. Please click hear to get the instructions to install a drive belt. Please click on the sub links on the page to view the diagrams.
Thanks for understanding. Please let me know if you require any clarifications.
Posted on Aug 01, 2011
Turntable will not work
If the other lead wire is a single wire, that's a ground wire that attaches to ground on the amp or reciever.
Jun 07, 2014 | Sony Ps-lx56 / Ps-lx56p Stereo Turntable...
Power supply Sony PS-LX10
Connect the RCA phono plug wires usually red and white wires with plugs to a receiver or amplifier in the back of it to phono in. New receivers will not work unless you have a phono preamp. Best to buy a vintage stereo receiver or amplifier with the correct connections. Make sure you connect the ground wire which is usually a small black wire coming from the turntable to an receiver or amplifier. Turn the stereo receiver on phono. Connect it to any screw attached to metal on back or look for a ground screw. If you do not attach it it will hum.
http://www.hardwaresecrets.com/imageview.php?image=357
Apr 18, 2014 | Audio Players & Recorders
Does a sony ps-lx100 turntable need grounding, and if so where does the ground wire fix to on the turntable?
The best way to find out is to connect it to an amp and try it out. If you hear a hum noise then it will need grounding. If not then no. Some turntables have a screw terminal to attach a piece of wire. Any wire will do, just connect to say a metal pipe.
Sep 11, 2013 | Audio Players & Recorders
Sony ps-lx250H loud buzzing sound
That is where the problem is, get a long insulated wire, bare both ends and attach one end to the turntable and the ground screw of the amp, use one screw on the chassis on the turntable and bare the metal for good ground connection.
Jul 20, 2012 | Sony PS-LX250H Turntable
How can I ground my LX300 Sony Turntable? The hum at high volume levels is due to lack of a ground from the turntqble and the receiver. Perhaps one of the screws on the bottom which holds one of four pads...
hi,
ok
Dec 17, 2010 | Sony PS-LX300USB Turntable
Disconnected wire in cartridge SONY turntable PS-LX300USB
If there is a hum, then the ground to the chassis is not connected you would wand to open it and connect it
Dec 04, 2009 | Sony Audio Players & Recorders
What voltage drives the Sony PS-LX49P turntable ,for use with other equiptment
Turntables Usually Work Out Fine With A 12v Dc Power Supply.
But You Have To Check What Is Ground And What Is The Positive Supply. check For Ground With A Multimeter To The Platter For The Negative. Other Things To Look For Is It A Ribbon Connector
Or A Dc Power Jack From The Turntable,and The Signal Leads. hope this helps
Apr 19, 2009 | Sony Audio Players & Recorders
Hum when turntable connected to phono sockets on amp
this turntable absolutely came with a ground wire that must connect to the gnd connection on the amp. maybe it got torn off or something but there should be clues on the back of the turntable as to what happened to it.
once the lead is found it must be connected to the amp gnd connect to get rid of the hum. this might require someone with soldering skilz or what have you in order rig up a new wire.
a tech might have to remove the bottom and solder in a new wire if it is cut or ripped off at the housing. This is common as people forget to unhook the gnd wire from the amp when moving things around.
Jan 05, 2009 | Sony PS-LX350H Turntable
Low volume on PS LX250h
This turntable has a built in pre-amp, under the platter is a on-off switch. Turn it to "on".
-Former PS-LX250H owner
Dec 12, 2008 | Sony PS-LX250H Turntable
Sony PS-LX250H Turntable Logo
98 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
