Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Refrigerator not cooling down below 60 degrees f.
Have a 9.7 cu whirlpool refrigerator; the freezer is working, or at least it is colder than the fridge, @ about 40 f. but there is not air blowing around in either the freezer or the refrigerator, it was working fine, but not now. the motor seems to be running, but not blowing any air? what can i do to fix this. it was working than we moved, waited two hours before turning it back on as instructed but we are think that maybe we missed something? thanks for you help
  • 163 Answers
Hi!!! make sure your inside fan is blowing and also go to back of your frig and see if the compressor and condensor fan are working if not then thats your problem..If they are working then you have a seal system problem in your frig..make sure when you look at the compressor you try to hear a cliking sound if you do then change the current relay..Good luck..
Posted on Jan 04, 2009
We have plenty of water and pressure coming to the refrigerator from the house, but when we try the in-door water dispenser, the water comes out at a slow trickle. Ice is not making. We installed a new...
whirlpool has had frozen waterline issues whats temp in refrigerator and freezer make sure refrigerator no colder that 37 degrees and freezer th 6 degrees
Jan 27, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Refrigerator will only get 58 degrees no colder, freezer is working fine, dial on fridge is on coldest setting...help
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Freezer get up about 27 degrees and then start going back down to 0 degrees. Does it everyday.
Sounds like the defrost timer/control is sticking...
heatman101
Nov 01, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrig does not cool to only 45 degrees Freezer is
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 08, 2010 | GE 18.2 Cu. Ft. Top-Mount Refrigerator -...
Older (20 to 25 years old) non-frost free Whirlpool refrigerator is not cooling below 60 degrees. I defrosted it and left it off with doors open in garage for 10 hours. Turned the cooler knob to 4...
Good day,
If it is a conventional refrigerator, there should be a cooling plate on the top back of the wall in the food section.
Assuming the door fits and closes properly, and the light goes out when the door closes, the plate described above should have a frost pattern on it. That is what cools the bottom fresh food section.
If left on for plus 12 hours normal cooling should exist.
If the plate is not frosted, and the machine runs constantly, you have a freon leak with no real practical repair possible.
You could recharge it, but it would be pricey, and just repeat the problem shortly.
Jun 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer works fine. Refridgerator wont get below 60 degrees.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 08, 2010 | LG 26.0 Cu. Ft. Side-by-Side Refrigerator...
Fridge does not cool below 40 degrees
This is a common problem and a design fault...
Jun 25, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
151 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
