Question about Cameras
How to repair my GE N13086 that have lines problems in the screen. And the big problem is the LCD or the screen is not the defect because the photo or video output of the camera have also the LINES problem.. It is very annoying , please help me..
t00nz
  • 4738 Answers
SOURCE: Red/White Lines On Photos and LCD
Sorry I didn't see this sooner. This definitely sounds like a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info: http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Dec 08, 2007
SOURCE: horizontal lines on LCD screen
Even i hve the same problem with my camera.It was reapaired once for this reason and again the problem is back.The solution i found is just try to lift the front protruding part of the camera and take the picture.It will be okay.Its becouse it is loose..!!
Posted on Feb 28, 2008
t00nz
  • 4738 Answers
SOURCE: lines across images
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Posted on Mar 18, 2008
  • 153 Answers
SOURCE: GE A830 digital camera
The camera is defective. Call 800 730 6597 to have it replaced.
Trevor Gordon
Senior Customer Tech
General Imaging Company
(Exclusive GE Digital Camera Licensee)
Posted on Oct 28, 2008
zohail
  • 1223 Answers
SOURCE: hORIZONTAL LINES APPEAR IN LCD EVEN AFTER TAKING PICTURES IN IAUT
Case 1: if these lines appear only on cam lcd and not on pics if u see them on pc then ur LCD is faulty get it replaced under warranty
Case 2: if all pics have horizontal lines on them if u see them on computer then it is a BAD CCD see the link below to confirm u can still get it repaired free under warranty if u dont have warranty they will still do it free of cost i am sure it is a manufac fault hope it helps u
http://www.imaging-resource.com/badccds.html
pls rate me FIXYA for diagnosis dont waste time run for warranty claim or tell me i can get help for u and guide u where to go tell me ur region !!
Posted on Mar 31, 2009
Small vertical pink line on the screen Garmin Nuvi 3590LMT
Most defects of the picture on the LCD display, typically points toward a defective display. We've repaired a lot of units with lines, splotches, color problems, etc. just by replacing the display.
Mar 18, 2013 | Garmin nuvi GPS
Lines on display, numerous horizontal, 3 vertical
This problem is caused by a defective LCD display. It is a common problem too. The only way to repair it is to replace the LCD display.
Dec 20, 2012 | Garmin nuvi 1450 GPS Receiver
Lcd screen problem
HI, this is isolated within the LCD screen. the input ribbon may be defective or, the entire screen could also be damaged. you will have to replace the lcd screen in this case due to the integrated design. you can confirm my diagnosis by, pulling the battery or plug for 5 minutes. if this screen is still not operating normally after you re insert the battery, this will confirm LCD screen failure.
May 24, 2009 | Fuji FinePix S5700 Digital Camera
Vertical lines on screen laptop
sounds like you have a defective lcd screen, there are these conductive rubber pieces that lead the signal into the lcd panel and once the connection deteriorates there is no going back. this could still be replaced, there are laptop repair places that do it, but you have to have to weight your options with buying a new laptop, repair could be up to 50% of what your's is worth as a 2nd hand laptop.
May 05, 2009 | Gateway MT6821 Notebook
LCD screen is black with horizont lines when trying to take photo
U ARE LUCKY !
it is CCD PROBLEM
thousands facing the same see the link but the best part is u can get it repaired free of Cost bcoz it is a manufacturing fault
see the link
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
Pls rate me FIXYA for help
Mar 27, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Wavy lines on photo's
Check if it is a dirty lens problem.
If lens are ok, then is either the camera optical sensor defective or a fault in camera main board.
You will need to take your camera to a computer shop or to send it in for repair.
You can call the number listed on the camera user manual to get repair service.
If camera is less than one year old, it may be covered by factory warranty, check warranty terms.
Sep 14, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
Toshiba Qosmio G10-133 PC
hi, the problem might be with the LCD connectors, of the LCD can be bad..??
Jan 03, 2008 | Toshiba Qosmio G10-133 Notebook
LCD display showing shattered lines - no picture displayed
Hello CathyCool The LCD itself may not have problems. If it ain't broken it most probably doesn't have a problem. Most likely the problems you have are given by a faulty connector between the LCD and the camera's mainboard. You should take the camera to a service center to have it checked. Tell them to make an estimate over the repair costs before they actually do something. In this way you will know what prices can you espect over the repair. I'll give about 60% chances that this is a minor defect involving that connector. In this case they will just need to reconnect it back firmly.
Mar 16, 2007 | Sony Cyber-Shot DSC-S70 Digital Camera
Canon a80 camera
It seems that either the image sensor or the connection between the image sensor and the processing board has been damaged or was improperly installed. If you sent it in because the lens was jammed it is highly likely that this is what has happened. See if you can get the facility who repaired it to cover the re-do, in the end it is their fault if your CCD is defective now and was not before the repair. However - if the camera was non functional after you dropped it they could very well say that the impact caused the problem. You might have no options besides either dealing with the issue or replacing the camera. David Millier Advance Camera Repair
Feb 09, 2007 | Canon PowerShot A80 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
