Question about Maytag Performa PAV2200
Making a sputtering sound on spin cycle
Each time the drum spins, it sounds like someone put a playing card in the spoke of a bicycle.
  • Anonymous Jan 09, 2009
    It sounds like the tub bearings are going. Same problem in my 6 year old maytag. We are not repairing it and starting a money-pit.
    The 'card in the spoke of the wheel' you describe is more like a grinding sound with us now and the tub will no longer drain and it shuts down in the rinse cycle with a strong acrid electical smell...It is getting replaced.
catriver
  • 878 Answers
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Posted on Jul 25, 2006
SOURCE: SPIN CYCLE
Front load Neptune model
Posted on Nov 25, 2007
  • 90 Answers
SOURCE: maytag washing machine repair
The water pump may be going bad...Yes it probably is a bearing. Take the belt loose and try turning each pully until you find one that makes noise or is hard to turn. Pump and motor should both spin very easily with out noise.
Posted on Feb 03, 2008
SOURCE: Sounds like a loose screw/bolt/nut during the spin cycle
if still under warranty get it checked out . same problem and cracked my outer drum. leaks water now outer drum costs $427.00
Posted on Jun 06, 2008
  • 20 Answers
SOURCE: Maytag washer won't Spin freely
You have a worn brake
Posted on Feb 10, 2009
1987 el camino makes clicking noise while running. clicks faster as I accelerate. sounds like somebody put a playing card in the spokes of a bicycle...
Being 24 years old it could be a number of things:It may be a exhaust manifold gasket. It could be a noisy lifter.It may even be a spark jumping from a faulty spark plug wire.
Jun 14, 2011 | 1987 Chevrolet El Camino
My engine makes a sound like a playing card stuck in the spokes of a bicycle.
Fro mthe sound described you could have an exhaust leak or valve clatter. Check your oil also, this could cause noisy valves.
Mar 12, 2011 | 2000 Ford Focus
When I put my shifter into four wheel drive and take off , the front wheels sounds like I have a playing card in the spokes of my bicycle
out at the wheel hubs they can be half engaged sometimes you can clean those out and grease but if there too worn you have to replace them.
Dec 07, 2010 | 1994 Ford F250 Supercab
My Samsung VRT washer model WF410 makes a clicking noise when it is spinning. It sounds like the noise you hear when you put a playing card in the spokes of a bicycle. It is brand new and has made this...
I'm trying to figure this out also. I think its coming from an air vent located on the top right of the machine (facing front.) It was blowing on a tag...still investigating. Also dances on initial spin up. I'm on concrete and travertine and I think the plastic feet are sliding on the marble. Am cleaning dust and putting rubber pad down to see if that fixya. I'll post back.
Aug 16, 2010 | Samsung Washing Machines
Will not spin and gives a grinding sound.
could be a problem with the basket drive tube or drive block
Feb 27, 2010 | Kenmore Washing Machines
I have a lg washer Model# wm0642h and yesterday my wife was washing clothes and during the last spin cycle it started making a loud clicking noise kind of like when you put a baseball card in the spokes of...
Sound like something has gone in between the drum and the outertank, usually a bra wire.. unless you can see it poking through a hole in the drum the only other access points for retrieval are through the sump hose at base , or the removal of heating element.. other than that it becomes a strip down job... but usually the 2 access points are sufficient..
Dec 19, 2009 | LG WM0642H Front Load
AC/Heat Blower makes noise when fan is on
almost sounds like something is in it and it is located on passenger side under dash.
Jan 17, 2009 | 1998 Dodge Ram
Fisher and Paykel clicking sound
it sounds like the bearings are going out as it spins faster the noise quietens down because the bearings are more spread out and as it slows they fall lower leaving an area that it causing "friction" of a kind
Dec 27, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Kenmore dryer
kutter1:
With the little bit of information you have given I would assume you have something stuck in one of the baffels ,((or possibly the most common is a Bra wire in one of the drum seals on the drum))
or a more in depth problem would be something in blower wheel (like the old playing card in the spoke of a bicycle)) when we where much younger.
woodychoppers
Jun 29, 2008 | Kenmore 75944 Gas Dryer
Washing Machines Logo
41 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
