Question about Harman Kardon AVR 55 Receiver
Shuts off In TV mode, the reciever shuts off after some time. By changing from Auto off to Auto ON fixes it till the next power off and restart.
The Audio Service is not running
Hi, Roselle. I hope I can help fix your problem.
You said the audio service has stopped, so here's how to get it started again.
Click your start button, and then click run.Next, type services.msc and press enter.
This will bring up the services info box.
Go all the way down the list till you see Windows Audio.
Click on it one time, and it will either give you a choice of "start", or it will give you 2 choices:"stop", and "restart"
Start or restart the service. Sometimes software can shut the Audio service off when the program shuts down.
Next, double click on Windows audio, and a properties box will pop up, make sure the selection in the middle is set on auto.
Next, click the recovery tab at the top.
Select restart service for all three selections, then click apply.
Close the properties box.
Next, go up the list to RPC. Do the same things that you did for audio service here as well.
Click apply on it as well.
Next, go to plug and play.
Do the same things to it as well, remembering to also save.
Close the services info box, and then restart your computer, as long as it is just the service, and not missing or corrupted audio drivers, then you should now have sound again!
Jan 29, 2011 | Computers & Internet
Tip
Copiers Sharp AL-1631 AL-1641CS DESCRIPTION OF SPECIAL FUNCTIONS
Toner save mode
Reduces toner consumption by approximately 10%.
Power save modes
The unit has two power save modes of operation: preheat mode and auto power
shut-off mode.
Preheat mode
When the unit enters the preheat mode, the power save indicator will light up
and other indicators will remain on or off as before. In this condition, the fuser in
the unit is maintained at a lower heat level, thereby saving power. To copy from
the preheat mode, make desired copier selections and press the start key
using the normal copying procedure.
Auto power shut-off mode
When the unit enters the auto power shut-off mode, the power save ( ) indicator
will light up and other indicators except the ONLINE indicator will go out. The auto
power shut-off mode saves more power than the preheat mode but requires a
longer time before starting copying. To copy from the auto power shut-off mode,
press the start key. Then make desired copier selections and press the star key using the normal copying procedure.
Auto clear
The unit returns to the initial settings a preset amount of time after the end of copy, or
scanner job. This preset amount of time (auto clear time) can be changed.
Stream feeding mode
For description of the stream feeding mode, see "Stream feeding mode".
Resolution of AUTO & MANUAL mode
You can set the copy resolution used for AUTO and MANUAL ( ) exposure
mode.
on Mar 14, 2010 | Office Equipment & Supplies
I turn on my ps3,tv displays message..invalid format... what can cause this,how to fix it?
Hi there, your display needs resetting back to standard resolution, please follow my guide on how to do this -
http://www.fixya.com/support/r6784945-playstation_3_no_display
Thank you for using FixYa
Dec 27, 2010 | Sony Playstation 3 (PS3) Console
I need the code to program my dish network remote for the Polaroid 42 inch LCD television
press and hold the tv botton on you dish remote till all the lights light up release the tv botton it should stay flashing then hit the larger of the two red power bottons next you will need to hit the up arrow one at a time till the tv shuts off when the tv shuts off you then hit the # botton at the bottom you wiil see the tv botton flash your code will then be saved
Dec 02, 2008 | Televison & Video
Blue screen of death
you need to boot from the cd, you have to change the boot senquence to start wth cd rom, when it prompts you to press any key to boot form cd,do that, it will load some files then restart again and the same message will appear, this time don't press any key, just let it continue on its own.
Mar 13, 2008 | Toshiba Satellite P25-S507 Notebook
Power does not stay on!!!
3 blinks in that model means convergence. change your convergence ICs and possibly the resistors located right next to them. Thats what is causing your set to go into protective mode and the blinks are a self diagnosis feature. Let me know if you need any additional info.
Feb 15, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Aug 18, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
No sound coming from reciever from tv
Make sure connections are going-audio out from tv to d-tv/cbl in on back of reciever. Then turn on tv and turn reciever input to d-tv/cbl and make sure the input mode is on auto. Hope this helps you.
Jan 24, 2007 | Yamaha HTR-5440 Receiver
Shutdown protection? HELP please
All of the Denon recievers I have repaired (over 100) that shut down after a very short time are going into protect mode. The display lights up and after about 10 seconds the display goes out and the standby led blinks red.
I have found that they have one of 3 possible problems and they all require that the reciever be taken apart and fixed at component level. No way to tell what your problem is until it gets put on a bench and troubleshot.
Problem 1. This is the most common problem. One of the front channels shorts out. On the big heat sink the front channels are at each end. It is the front left channel (close to the display) This requires that the output transistors be replaced as well as some driver transistors and some resistors and a capacitor. Lots of work for a blown channel. Denon has put out a bullitin to upgrade the bias transistor and change a couple of resistors to help compensate for this failure. That channel overheats more than any other channel.
Problem 2. There is a resistor that is right next to the preamp board that opens up. It is a 10 ohm 1 watt resistor and when it opens, it causes the unit to go into protect.
Problem 3. The +12 volt regulator fails. It is in the power supply area on a smal heat sink right next to the -12 volt regulator. Generic part number is KIA7812 It also causes the unit to go into protect.
Most decent repair shops can fix these from about $120 up to about $200. Depending on which problem it is and how fast they are at finding the problem. Most charge labor by the hour.
Sep 06, 2006 | Denon AVR-1603 Receiver
Harman Kardon AVR 55 Receiver Logo
32 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
