Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
SimpleTech 250 gig external drive not recognized on MacBook
Rebooted everything multiple times replaced cable - worked for maybe an hour - gone again suggstions? thanks in advance
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 137 Answers
It could be formatted in a different manner. See if it is detected by your mac. Go to Applications/Utilities/Disk Utility and see if your hard drive is shown there. If it is, then the formatting of your hard drive is not compatible and you will need to reformat to be able to use it on a mac.
Posted on Nov 04, 2012
Randy V
  • 236 Answers
SOURCE: SimpleTech PininFarina external hard drive - site to download drivers
the hard drive you have is plug n play.
if windows does not recognize it, you may have to uninstall the hard drive.
right click your computer. click properties.
click on the "Hardware" tab. Click on "Device Manager".
open the category of "Disk Drives".
If you see your drive with a yellow exclamation point or a red "X", continue. If it does not, either it was dropped or its a faulty drive.
Right click your drive and click "Unistall". Click OK.
Now, unplug the drive and plug it in again.
it will install by itself.
Go to my computer and check that its there. If its not, you may have a bad drive. either send it for a new one (if still in warranty) or replace it.
Posted on Aug 12, 2008
safenude
  • 124 Answers
SOURCE: SimpleTech 320 GB hard drive not recognized by PC
Windows likes to play with drive letter assignments, especially when you remove a device without using the "safely remove hardware" icon. When you plug it back in, Windows may think that you've plugged in a new one and assign it a new drive letter. Try this:
Your computer can use up to 26 drive letters, from A through Z. Use drive letters C through Z for hard disk drives. Drive letters A and B are reserved for floppy disk drives. However, if your computer does not have a floppy disk drive, you can assign these letters to removable drives.
Before you modify drive-letter assignments, note the following items:
  • Changing the drive letter of the system volume or the boot volume is not a built-in feature of the Disk Management snap-in.
  • Many MS-DOS-based and Microsoft Windows-based programs refer to specific drive letters for environmental or other variables. If you modify the drive letter, these programs may not function correctly.
uparrow.gifBack to the top How to assign a drive letter loadTOCNode(2, 'summary'); To assign a drive letter to a drive, a partition, or a volume, follow these steps:
  1. Log on as Administrator or as a member of the Administrators group.
  2. Click Start, click Control Panel, and then click Performance and Maintenance.
    Note If you do not see Performance and Maintenance, go to step 3. Performance and Maintenance appears in Control Panel only if you use Category view. If you use Classic view, Performance and Maintenance does not appear.
  3. Click Administrative Tools, double-click Computer Management, and then click Disk Management in the left pane.
  4. Right-click the drive, the partition, the logical drive, or the volume that you want to assign a drive letter to, and then click Change Drive Letter and Paths.
  5. Click Add.
  6. Click Assign the following drive letter if it is not already selected, and then either accept the default drive letter or click the drive letter that you want to use.
  7. Click OK.
The drive letter is assigned to the drive, to the partition, or to the volume that you specified, and then that drive letter appears in the appropriate drive, partition, or volume in the Disk Management tool.
I hope this does it for you. Thanks for using Fixya!
Posted on Jan 26, 2009
SOURCE: simpletech hard drive not working
I posted last year when I had this problem (Sept. '08 I think) and I just received an e-mail because when you guys posted today I got an e-mail that the topic updated. After my initail post I solved my problem, but I forgot to come back and post the solution, so here is what happened with mine...
This drive has a manufacturers default. If you don't use it for a while...if you detach it frequently...and/or when you reach a certain amount of space used it requires a certain power source to be used. There is no warning, and this is not stated anywhere, however I did contact the company directly. This problem occurs when the drive is not plugged into the main USB Port in the back/side of your machine. You cannot use a hub or external USB source for power. When you reach any one (or all) of the three points that trigger the drive to stop working the only thing that will enable the device to work properly again is for it to always be plugged into a main port. They are the only ports that have enough power to support the drive. This goes for laptops as well. When using a laptop, you cannot plug the drive into a mini hub, laptop riser, cooling fan, etc., it has to be one of the main ports or there will not be enough power to run the drive.
If your drive has already stopped working, all that is needed to enable it again is to properly shut down and disconnect it and your computer. Then reconnect and power up just like you would initialize it if it were new. As long as it is plugged into a main port you should have no problems. All your data should be fine and you should have no more problems.
Personally, I have had smooth sailing ever since we determined that this was the problem. I hope this helps some of you. Good Luck!!!
Posted on Jan 28, 2009
SOURCE: computer does not recognize simpletech
I have a simpletech external drive that was working, but after i disconnect it unproperlly, i was getting the message <usb not recongnize>. I called simpletech, but customer service is ****, and anyway the drive inside is a hitahi, i have another simpletech and the drive inside is a western digital, whatever...
They told be to go to best buy to make a recover, so i called and they told me it s 250$, and if they cant do it, they will send it to a labotory witch cost 1700$, crazy ******* hein?
I red about getting drivers, putting the hdd in a fridge and much more stupid thing, BUT THE SOLUTION IS SIMPLE, OPEN THE CASE, UNDER THE ALLUMINIUM STICKER THERE IS 2 SCREWS, REMOVE THEM, OPEN THE CASE, TAKE THE HDD INSIDE OUT AND REMOVE THE ADAPTER CONNECTED TO THE HDD(WHERE YOU CONNECT THE USB CABLE) CAUSE THIS IS THE PART CAUSING THE PROBLEM, THE HARD DRIVE IS OK AND YOU DIDN T LOOSE NOTHING. So now what you can do is just buy a new case for laptop hard drive (with a new usb adapter included), or buy another simpleshit hdd and switch the adapter part or just buy an adapter to make your hdd an usb hdd and Voila, and after that i suggest you buy yourself a better hdd than simpleShit and make a new backup.
Posted on Jul 25, 2009
lock123
  • 6831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
New computer doesn't recognize device
uninstall the drivers for the hard drive then reboot install drivers that came with drive and then plug it in.
Mar 27, 2010 | SimpleTech 250GB USB2.0 7200 RPM External...
Where can i get the installation softare for simpletech 250???
you can check on the official site from here http://www.simpletech.com/commercial/products/simpledriveexternalpininfarina.html ;you need to plug in USB to be recognized by you PC or laptop after that you can acces your hard drive when is instaled make a reboot to be sure that is instaled properly.
Dec 10, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Computer does not recognize simpletech
Assuming Windows, try the Device Manager and see if the (old) disk is listed there in the disk drives section.
If so, right-click it and select Uninstall. (do this while the new driver is disconnected)
That should force Windows to recognize and reinstall the new drive when you plug it again.
For other causes check out the external hard disk problems.
Apr 20, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Computer doesn't recognize the external drive
I asume the connection is via an USB?
Try another usb-port and see if that helps, if not try to connect the disc on another PC (maybe a friends pc) and see is that pc recognize the disc.
Nov 21, 2008 | SimpleTech Signature Mini 250GB External...
Computer wont recognize external drive
The simpletech 1tb drive's case has issues. I had the same problem. It actually quit while I was running a video off the drive. I replaced the case by removing the harddrive from the one it came in and installing it in another case and now it works again.
The first thing I would try is installing the drivers it came with, but failing that you will need to replace it's case.
It has 4 screws to remove, 2 under the silver warranty voiding tape and 2 visable on the bottom side. Remove them, then use a flat screwdrive to pop the case open (gently). Then remove the harddrive.
You will need a case with SATA data AND power cables for this to work.
Sep 26, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
My computer doesen't recognize the hard drive
you need to partition the drive in the first instance before it will do anything, ( as they are not initially partitioned) you need to go into logical drive management to partition the drive. (right click on my computer, select Manage then when the mangement screen comes up select logical drive manager, you should then be able to see your unpartitioned drive which you should then be able to partition and format)
Sep 22, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Problem with external storage
seems the harddive is no more in working condition. i too had a similar problem with mine( not external drive).the technician said that it is gone and replaced it with another one.
if your hard drive's warranty period is not over they will replace it with a new one.
Jul 27, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
120 gig Western Digital black no longer mounts on LEOPARD osx 10.5 grrrr
i have the same problem.
macbook doesn't see anymore my hdd western digital 2,5'' white 250 GB.
tried disk warrior, disk utility but nothing.
it's just seem disappeared, even if i hear it works inside (and the led light is on)
what can i do?
May 10, 2008 | Western Digital Passport WDXML800UE...
Won't recognize my USB
i have a feeling its not the hard drive thats bad i think it sounds like the case .
you can try buying another case and transfering the hard drive to it the case is around $20.00
Nov 30, 2007 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
71 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
