Buzzing plenum heater
We have a plenum heater that periodically makes a VERY LOUD buzzing noise (lasts from 15-60+ seconds). It happens when the furnace comes on and seems as though a switch is getting stuck. It will continue to have a low buzzing noise for several minutes. Any ideas?
  • 70 Answers
Is the fan relay going bad it is located normally inside control box behind panel where wiring enters unit
Posted on Jan 04, 2009
Our refrigerator does a very loud buzzing for 5 seconds 3 or 4 times a day what is the problem its only 3 months old and very annoying
Normally as loud buzzing from the fridge on that frequency it just the icemaker cycling, the water inlet solenoid valve often makes a buzzing noise depending upon water pressure. Other than the noise, there is nothing to worry about.
Sep 26, 2016 | Frigidaire Refrigerators
The e t c is buzzing what is causing this
ANSWERS: Oil Loss, Buzzing Noise, ETC. - Nissan Forum ' Nissan Forums
forums.nicoclub.com/answers-oil-loss-buzzing-noise-etc-t323273.html
Mar 20, 2008 - 3) Yet another buzzing, rattling or whinning noise. If you own a Quest van, Maxima, Altima 3.5 and some Z/G/FX vehicles, and get a loud ... Mysterious no-spark situation with a buzzing transmission
Mar 31, 2013
ABS brake fault light on, buzzing sound
Feb 7, 2011
ECU making loud buzzing noise
Oct 6, 2009
Buzzing noise under the hood towards the back of the engine ...
May 8, 2008
More results from forums.nicoclub.com
Buzzing noise at 2000-3000 RPM - Nissan Forums : Nissan Forum
www.nissanclub.com/...nissan-altima.../128490-buzzing-noise-2000-300...
Oct 28, 2003 - 6 posts - ‎3 authors
The "buzzing noise"; I can tell that I am not alone in having this problem but has someone figured out ... I fit does, that eliminates the brake rotors, tires, wheelbearings, CV's etc. ... BUT with an Altima it is probable the pre-cats. Loud humming noise when driving
Aug 29, 2009
Noise when accelerating
Jul 21, 2009
engine noise/whine - 05 3.5SE
Nov 17, 2006
My altima has a humming noise under my hood
Jan 17, 2005
More results from www.nissanclub.com
Jan 05, 2016 | 2000 Nissan Altima
Buzzing noise
Put off it's power supply then switch it on after somtimes
May 12, 2010 | Kenmore 76579 Bottom Freezer French Door...
1998 Lexus gs300 at idle Very loud buzzing type noise from engine
check brake fluid level.
master cylinder might be of interest, but i would check the fluid level first
Apr 08, 2010 | 1998 Lexus Gs 300
Loud buzzing noise
seems the the motor is ****! avoid switching it more further to prevent its motor from burning!
motor could be stuck due to rust build-up.
or something might have jammed along the motor area or along the rotating part.
Jun 18, 2009 | Dryers
Carrier 58GS150-CB ignites but fan will not blow (Loud Buzzing)
The loud buzzing soud i found to be the fan blower motor. I removed the fan bracket assembly and sprayed a little WD-40 on the set screws and protruding shaft so that sqirrel cages could be removed. (Also marked position of set screws on shaft) once squirrel cages were removed I removed 4 motor mounting bolts. Cleaned sqirrel cages and housings with industrial strenghth rim cleaner to remove solid dirt and will replace motor and capacitor.
BTW thanks for nothing
Nov 22, 2008 | Goodman GMS90703BXA Heater
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
A buzzing noise
Why do you say put in line to stop the buzzing? What is it that tells you the wire is creating the buzz?
It could be anything from a loose sheet metal part, rivet, fan, transformer, loose connection, or just the way it was built, although a loud buzz sounds like a problem waiting to happen to me.
No there is nothing to put in line to make it quit buzzing, I need to know all the information about the device, voltage, amps, brand, and then tell me how it is wired including number of wires, size of wires, voltage, how it is wired to what colors, how far from breaker, what breaker and size, and anything else that seemed unusual to you during install if anything.
Write me back here or allexperts.com or wbwill@sbcglobal.net.
Oct 24, 2008 | Fahrenheat Electric Convector Baseboard...
Loud periodic buzzing
Are you sure this noise is not just the ice maker trying to cycle without water? If it is not turned off it will dry cycle every 15 min or so.
Jan 18, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Heating & Cooling Logo
223 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
