Question about LG GW300 Cell Phone
MY CAMERA IS NOT WORKING IT KEEPS SAYING THE DSP IS NOT AVAILIBLE
  • 3 Answers
Ask verizon for HELP.!
Posted on Nov 02, 2012
2 Suggested Answers
  • 437 Answers
SOURCE: When pressing on the camera button, it says: DSP
HI arsinoe22 first take the battery out of the phone. Next clean the contacts . now put the battery back together and next you need to turn the phone on see if you can take a pic. oK IF your still getting that messages you.need to change the settings on the camera. If you cann't get into the settings. then you need to doa hard reset on the phone. back up all your information first . write your paswords so you can reset up your phone. Ok hope this helps
Posted on Feb 27, 2011
How do i turn off the dsp and run stereo mode?
Pressing the PROCESS button opens up the various screens that determine the signal path setup and that control processing parameters for the DSP modules: I/O, PEQ, XOVER, DEQ, DELAY, and LIMIT.
I/O
The I/O module sets up the signal routing inside the DSP from input to output. Press and rotate the SELECT encoder knob to choose between dual mono, stereo, bi-amped, or bridged routing options.
STEREO
STEREO mode routes the signal from both the A and B inputs through a single series of DSP modules. The parallel DSP modules process the A and B signals with identical, linked settings (only module "A" parameter settings appear on subsequent DSP module screens).
The manual is available at: http://www.behringer.com/assets/NU6000DSP_NU3000DSP_NU1000DSP_M_EN.pdf
Jun 02, 2014 | Behringer Inuke Nu6000dsp 6000-watt Power...
Crate GLX-212 combo. cant change DSP. repair??
The last knob on the right should give 16 different effects, are you saying the knob doesn't work at all? Is it turning smoothly? Do you hear any clicks as you turn it? Is anything plugged into the dsp socket on the back where the footswitch would go?
Mar 13, 2013 | Music
Camera dsp error
Welcome to FixYa,
DSP means Digital Signal Processor and this is the part in your phone responsible for processing digital imaging.
The amount of image data gathered by camera nodes in WMSNs is very large. They need to be compressed before transmission. JPEG2000 is the image compression standard which has many advantages, such as high compression efficiency and high image fidelity. However, its high computational complexity makes it a big problem when using it in WMSNs. To satisfy the low-power and high image quality requirements of WMSNs, studies shows the low-power JPEG2000 realization on DSP-based camera node.Fixed-point LS9/7 wavelet is used instead of CDF9/7 wavelet to decrease the complexity of computation. embedded block coding is improved for high efficient DSP parallel processing.
Some experiments results show that the improved JPEG2000 leads to a great reduction in implementation time, and hence saves energy consumption of camera nodes.
But sometimes, in my experience, pulling out the battery and try to insert it again, will solved the issue.
I hope this information help you to resolve yuor issue.
Thank You for using FixYa.
Mar 04, 2011 | Cameras
When pressing on the camera button, it says: DSP non available. I cannot take any pictures. What should I do?
Feb 27, 2011 | LG GW300 Cell Phone
I'm looking for instruction manual for my amp Yamaha DSP A-1000 THANK YOU FOR YOUR HELP
The manual is available to download on the Yahama site (usa.yamaha.com). Click on the "support" tab.
Jan 19, 2011 | Yamaha DSP-A1000 5-Channel Amplifier
How do i fix dsp camera error
The amount of image data gathered by camera nodes in WMSNs is very large. They need to be compressed before transmission. JPEG2000 is the state-of-the-art image compression standard which has many advantages, such as high compression efficiency and high image fidelity. However, its high computational complexity makes it a big problem when using it in WMSNs. To satisfy the low-power and high image quality requirements of WMSNs, the paper studies the low-power JPEG2000 realization on DSP-based camera node. Fixed-point LS9/7 wavelet is used instead of CDF9/7 wavelet to decrease the complexity of computation. embedded block coding is improved for high efficient DSP parallel processing. Experiments results show that the improved JPEG2000 leads to a great reduction in implementation time, and hence saves energy consumption of camera nodes.
Mar 03, 2010 | Samsung Alias 2 SCH-U750 Cell Phone
I just bought a used VSX-D906S and surround speakers. Should it have surround in the DSP mode, or is that only available in the ProLogic mode.
DSP modes usually act on ANY input source, including stereo. Are you saying you have no surround speaker fucntions? Get in the setup and define, then adjust them.
Jan 16, 2010 | Pioneer VSX-D906S Receiver
Dsp failure on my mp3
The unit is defective. Replace.
Nov 03, 2009 | Nextar MA933A MP3 Player
I cannot get the functions on the remote to operate.ie pbass dsp/eq etc?
The P.BASS function is only available with 2 channel LPCM sources such as mp3,Divx,cd
and wma. Press P.BASS button and "POWER BASS ON" will be displayed on the screen.
The P.bass does not work with DSP/EQ or DOLBY PRO LOGIC ll modes.
If you press P.BASS in the DSP/EQ mode, the DSP/EQ mode is automatically shut off and the P. BASS function comes on.
The DSP/EQ function is only available in STEREO mode.
Press the PL ii mode button to show STEREO on the display.
This feature works with CDs, MP3-CDs, 2 channel DVD-Audio, DivX and Dolby Digital discs.
When playing a DVD disc encoded with two or more channels, multi-channel mode will be selected automatically and DSP/EQ function does not work.
Nov 04, 2008 | Samsung HT-Z310T Theater System
LG GW300 Cell Phone Logo
50 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
