Adjust wick kerosun radiant 8 - Heating & Cooling
3 Suggested Answers
bird_one49
  • 4 Answers
SOURCE: KERO SUN RADIANT 8 HEATER-I NEED TO KNOW HOW TO
Click on this link to download the manual for your Radiant 8 heater.(it's now sold as a Toyotomi RSA 8 but is exactly the same). All the info you need is there.
http://www.toyotomiusa.com/products/manuals/RSA-8.pdf
Posted on Feb 04, 2011
bird_one49
  • 4 Answers
SOURCE: My radiant Kerosene Heater wick will light but
Go to this site. You can find out just about anything you want to know about kerosene heaters.
www.milesstair.com
Posted on Dec 08, 2011
Kerosun Monitor 30 water in tank
May have to drain & remove wick and dry or replace with new wick .
Mar 10, 2015 | Heating & Cooling
How do you replace just the top part of the wick on a comfort glow GR9B kerosene heater?
    • Remove the base plate from your Comfort Glow heater and expose the fuel tank. Lift the fuel tank out of the heater and set it to one side, well away from the heater. Note that the fuel tank is not connected to anything and will slide out easily.
    • 2 Run the heater until all the fuel in the lines is used, a process called "dry burnicon1.png," which usually only takes a few minutes. The fire will go out when the lines are empty. Turn the heater switch off and allow it to cool.
    • 3 Take the batteries out of the battery compartment on the back of the heater. This is an important safetyicon1.png step that keeps the heater from accidentally coming on while you are working on it.
    • 4 Lift the wick ring up and off, then remove the two nuts that secure the wick. The wick ring fits around the wick and the draft pipe -- the hollow tube that holds the wick -- and serves to hold the wick firmly in place.
    • 5 Slide the wick up as far as possible to reveal the positioning pin -- the small metal pin near the bottom of the wick. This pin is part of the wick and helpsicon1.png to ensure it is installed correctly. Push it out through the positioning hole in the draft pipe and lift the wick out of the heater.
    • 6 Fit the new wick onto the draft pipe and engage the positioning pin in the hole by pushing it in until it clicks into place. Move the wick down into the heater and replace the two nuts to secure it.
    • 7 Measure the distance between the wick and the draft pipe with the clearance gauge. The distance between the wick and the draft pipe should be the same all the way around, to ensure an even burn. Adjust the set screws as necessary to create even spacing. These are the small screws spaced evenly around the draft pipe that, when turned, move the pipe slightly so you can correct the spacing between the draft pipe and the wick.
    • 8 Replace the wick ring over the wick. Return the batteries to the battery compartment and the fuel tank to its compartment. The fuel tank will slide securely into its compartment in only one way. Replace the fuel compartment cover to complete the project.
Tips & Warnings
  • Keep the heater set on medium to medium-high for best results. Setting it too low or too high may cause soot to accumulate on the wick.
  • When operating a kerosene heater indoors, always have a working carbon monoxide alarm and a smoke alarm. These heaters are generally safe when in use, but an alarm will provide a safety backup in case the heater malfunctions
Oct 14, 2013 | Northern Tool 10,600 BTU Radiant Kerosene...
KERO SUN RADIANT 8 HEATER-I NEED TO KNOW HOW TO ADJUST THE WICK WHEN IT BURNS DOWN
Dec 02, 2010 | Heating & Cooling
Set to automatic extinguisher
Mine is missing too! Pull the front grid up, take the element out, and you will see a plate covering the wick area. Slide this plate to the left until it clicks into place. Now you're set! If your wick is old, you might need to 'prime' it by wetting it with some kerosene.
Dec 22, 2008 | Northern Tool 10,600 BTU Radiant Kerosene...
Kerosene heater will not wick up fuel from tank properly
Have you checked the length of wick. May not be long enough to get down into fuel. RON
Jan 26, 2008 | Northern Tool 10,600 BTU Radiant Kerosene...
Wickes
I went to a site that has questions and answers about a kerosun heater. from what I gathered, instructions on how to replace the wick are included with the replacement wick.
Dec 04, 2007 | Northern Tool 10,600 BTU Radiant Kerosene...
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
