Question about Dell Inspiron 1300 Notebook
Dell Inspiron 1300 can't connect external monitor
Trying to connect to tv, says 'no sync': should I use a function key to activate this? It works automatically with my partner's InspironT1501 (Vista). I have xp Home edition. Thanks.
    Problem Solver:
  • 13 Answers
I was having the same problrm for my dell inspiron 1300. It is not FN + f5. It is fn +f8. Notice the Crt/LCD...
Posted on Jul 20, 2010
I have same problem...
i can't make my external lcd screen to make it work with my dell inspiron 1300...
when u use fn +f5
i am using windows 7... no luck pls help
Posted on Feb 03, 2010
    Scholar:
  • 157 Answers
Try to use the Fn + F5 key..or which key indicate for TV
Posted on Jan 04, 2009
Can the dell inspiron m5030 work with a projector
You can switch to anexternal monitor by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key. Here is a list of keycombinations for some of the laptops :-IBM ThinkPad = Fn + F7HP and Compaq = Fn + F4Toshiba = Fn + F5Dell = Fn + F8
Nov 12, 2011 | Dell Inspiron M5030 Laptop
I cannot connect an external monitor to my dell inspiron 1300
DffffplPlease Hold FN Key and Press F4 Button it will be work
Jun 22, 2011 | Dell Inspiron 1300 Notebook
Dell inspiron 1300, g and h keys suddenly stopped
There are some circuits malfunktion in your keyboard.
Try to connect and external keyboard and you will see that the external keyboard works fine.
This way you can continue using your computer,
and continue writing,untill you get a replacement keyboard.
You need to replace the keyboard.
Hope this helped you to continue using your computer.
If you were helped. Please vote!
May 12, 2010 | Dell Inspiron 1300 Notebook
Inspiron 1300 PC Notebook: I can not start my Dell Inspiron 1300 , when i plu...
adapter should be fine..if light comes on adapter should be good...leave battery out of the system...just use adapter and when starting system up tap f12...see if u can see this menu..if not try a external monitor to see if u can get a image..if so run the diagnostic..if still no image or no external monitor it may be a mb
May 06, 2010 | Dell Inspiron 1300 Notebook
Dell Inspiron 1300 blank monitoe
the problem might be from the screen or from the screen inverter.
Connect your laptop to an external monitor and try again.
If there is a display, then its obvious that the problem is from screen or screen inverter of your laptop.
Good luck.
May 01, 2010 | Dell Inspiron 1300 Notebook
Dell inspiron 1300, g and h keys suddenly stopped working. have removed keys and cleared dirt. key goes down but nothing happens. if (in microsoft word) i hold both g and h down and tap 'f', 'j' appears!
If an external keyboard functions normally, then replace the keyboard. If the external keyboard has the same issue, then most likely a setting in the regional and language settings
You can buy a keyboard here
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=inspiron+1300+keyboard&_sacat=See-All-Categories
replacement instructions here:
http://support.dell.com/support/edocs/systems/ins1300/en/sm/keyboard.htm#wp1084976
Mar 20, 2010 | Dell Inspiron 1300 Notebook
My dell inspiron 1300 notebook seems to be working but I cannot see anything on the screen. I was told to hook it up using a VGA cord to a monitor to solve the problem. It doesnt seem to be working and...
after u connect it to VGA u need to change the display signal interface to monitor from lcd, the option is available in display properties in Control panel
under Display prop, go to Settings/Advanced/Monitor or Adaptor depending on the choice.
there u will get LCD or Monitor or TV to chose.
the big ? is if you cant view anything on the LCD laptop how will u do it....?
check if u can view any bit of display in ur laptop like a filim negative....if it's totaly dark then u may visit a tech shop to replace the lcd screen
Jan 27, 2010 | Dell Inspiron 1300 Notebook
I am trying to connect my laptop to the TV and would appreciated if someone could share information about connection details My dell inspiron 501 laptop has only the VGA port. The lowest resolution that...
Your dell should pick the TV up as a monitor if you have the VGA cable connected. The vga cable has a blue color on the TV but on the laptop, the color of the port is usally brown or dark in color. Windows should pick up on the new device and enable it. The Dell has an Fn key combination to allow you to toggle through the integrated / external monitor choices that you would have with two monitors active, that being clone both desktops to both monitors, extend the desktop from the laptop to the TV, use only the tv and turn the integrated off, use just the integrated and leave the TV off. The key combination is: Fn + F8
Jan 12, 2010 | Dell Inspiron 1501 Notebook
Funtion F8 not working s video from laptop to TV
Before connecting the external monitor,Shut down your computer,connect the external monitor,Restart the computer and the external monitor should load and The FN+F8 should now work.
May 21, 2009 | Dell InspironTM 1501 Notebook
Dell Inspiron 1300 Notebook Logo
1,854 people viewed this question
Alun Cox
