ATAPI DVD A DH16A1P ATA drive will not record. KU.01609.003 recommended as replacement. Do you know a supplier?
Computer is Gateway FX530XV
  • 2,878 Answers
Optical drives are standardized. Just purchase same connection and features you require.
Posted on Nov 03, 2012
5 Suggested Answers
SOURCE: CD Drive not working at all
If its the only CD Drive on that IDE cable it wouldn't be set as slave, would be on Master.
Yes you can go to http://www.driverguide.com you can download updated drivers for IDE and SATA on your PC.I checked on Acer support but there website isnt't working correctly for me.
Try updating the drivers, and try both drives again one at a time.
Posted on Jan 07, 2009
bharat_s
  • 178 Answers
SOURCE: ATAPI DVD A DH16A1P ATA Device has error 10. Due
Your problem is very common,the only reason found is that,your cd or dvd drive is corrupted, You will have to install new windows.
THANK YOU
Posted on Oct 11, 2009
SOURCE: plugged in an usb to ata/atapi bridge(ext HD)
There are a couple of possiblities but first you have to try the external hard drive into another computer, if this works then you may have a problem with USB drivers or the IRQ
if the external hard drive didnt work with other computer, then it is possible that the ext hard drive does not have working partition and or a logical drive,
to check this right click you computer icon then click Manage.
On the left side select Disk Management, then you should be able to see all your harddrives even the cd rom drive from there right click and create partion for any un partitioned drive.
Posted on Nov 02, 2009
wayneard
  • 1901 Answers
SOURCE: I want to replace CD drive on Dell Dimension 8200.
This computer has 2 IDE connectors. These are parallel ATA connectors.
See: Dell Dimension 8200 Specs
If you get a drive, look for IDE on the package. IDE, PATA and ATAPI are near synonomous. They use a 40 pin flat ribbon cable to connect.
Thanks for using Fixya.
Posted on Nov 25, 2009
I want to replace CD drive on Dell Dimension 8200. My options are serial ATA, parallel ATA & ATAPI. Which one do I need?
Nov 25, 2009 | Dell Dimension 8200 PC Desktop
ATAPI DVD A DH16A1P ATA Device has error 10. Due to this error, I computer does not read any discs. I tried to uninstall it and reinstall, but that did not work. What can I do to fix this?
THANK YOU
Oct 02, 2009 | Computers & Internet
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19) For emachines windows vista atapi dvd a dh16a1p ata device stop...
Hello there:
First i would double check to make sure that the device is windows vista compatable and is compatable for your system next i would uninstall the device using device manager and than select view and select scan for hardware changes and let the computer reinstall the device and it will let you know that your device has been found and is installing than it will let you know that your device is installed and is ready to be used or it wil give you a error message if so than i would contact the manufacturer of the device and see what they say about the message ok?
best regards michael
Sep 08, 2009 | E-Machines emachines (emachinees) CD-ROM...
Trying to locate a HDD caddy/Connector
In normal circumstances it would be a USB 2.0 but I don't know what you are connecting it to.
Jul 29, 2009 | Computers & Internet
Atapi dvd dh16a1p ata
If this is original equipment inside your pc then go to the website of who made your pc and check the spec's. If the burner does not say
dvd-rw, DL, then no it is not capable of burning a double layer dvd disk.
Apr 08, 2009 | Gateway (5500778) Internal 32x CD-ROM...
DVD player won't play DVD
Try downloading a DVD player such as uberdownloads. If the player still doesn't work, then look for an mpeg 2 decoder on the website for your video card manufacturer. If you are using windows XP check the region code on your DVD player that matches the region code on the DVD. This is done by selecting my computer, moving the mouse to your dvd player, pressing the right mouse button, selecting properties, and look for the region code. For the US use region 1.
Jan 07, 2009 | Acer Aspire™ T180 PC Desktop
Gateway laptop dvd drive does not start
http://support.microsoft.com/kb/314060/EN-US/
Dec 25, 2008 | Gateway (5500652) (  5500652)...
Disc drive does not burn to disc
double click on the my computer>right click on the burner drive > properties> click on recording > enable recording
if that is already there
than go to device manager and than remove the burner from the dvd/cd rom drive option and than remove the ide channels from ide ata/atapi remove both primary and secondary both and than restart the system and than chk if the burner is working
Oct 31, 2008 | HP Computers & Internet
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
