Question about Orion XTR Pro 1000 Car Audio Amplifier
Orion XTR Pro 1000 amp ticking
My amp was working fine, then the last time i started my truck , the stereo was already on ( I don't/didn't get that "pop" in the speakers that sometimes comes with starting up with the stereo on. The amp kicks on but, all I get is tick...tick...tick... I have the amp powering the subwoofer only, my other amp powers the rest. At first I thought it was just coming through the woofer but, after closer inspection, I heard the amp ticking & the power light flashing with the ticks. I know my proble isn't with sufficient power to the amp since 1. i have a truck w/high output alternator & 2. I have a yellow top optima battery. The amp worked fine for the past couple years. All this started up after I had a new head unit installed- the only thing the installer (supposedly) did was connect new RCA cables to it- y'know, the overpriced "stereo shop" kind. Before that, I had cheap cables running to it. When I was looking it over, I noticed I only had afew strands of my remote wire actually in the harness, I fixed it thinking "Ah Ha!!- that must be it" but, the problem still remains. I play my music loud sometimes but, not constanly so, the amp hasn't been abused since I've owned it. Is there a way to reset the amp? I've kind of got the impression that the ticking was a protection feature. I've disconnected the power & reconnected. The plug fuses look fine, pulled them out & put 'em back in. I don't think it would be the glass barrel fuse to the power at the battery, because it's for the entire system. It were blown, I wouldn't have any sound/no amps would even power up.
  • 45 Answers
The amplifier output transistor or ic may be damage, its the relay may be thats ticking, or if not the output going to the speaker may be shorted or overloaded with low impedance, you may remove some speaker and try again.
Posted on May 20, 2007
When the vehicle is off and stereo is off the speakers are making loud popping and banging noises all the time over the last week? when the vehicle is running and stereo on no popping noises
This can be tricky; there are several things that might cause this 'phantom' problem. You did not state if you have an alarm system. The alarm may be tied into your speakers and/or linked to the stereo itself. I would not initially suspect a ground issue since the stereo works well while powered. I would suspect a power feed issue. This can be tested by removing the fuse for the stereo and seeing if the issue continues.If the problem stops, the source may be internal to the stereo and you may need to get an aftermarket stereo - or pull the fuse every time you stop ( sucky solution, I know!) . I think this may be an issue resolved by a reputable stereo shop. Possibly a strategically placed Diode may solve the problem - a hands on diagnostic is certainly called for. You did not mention if the problem decreases or stops overnight. I would think this can cause your battery to drain over an extended period of time - and ruin the speakers too, if they're not affected already. I would try contacting the Dealer first and, as this problem has gone unresolved for so long, see if you can get them to replace the stereo or at the least pay the stereo shop to fix it.
best of luck and thanks for using Fixya!!
Feb 17, 2014 | Audio Players & Recorders
I have a CD Stereo system SA-AK17, 120V, 145W, without speaker. I provided 2 speaker with the brand of Technics, input 200W(.music), 100W(DIN) each speaker. I bought Audio wire and connect speakers...
Some stereo system have the ability to switch off the speakers when playing via headphones. In others the headphone socket itself does the switching. However headphone sockets can become faulty and when the headphone plug is removed it doesn't restore sound to the speakers. It's very easy to fix this, with a check that the contacts are not bent out of place. Or you can rewire a new headphone socket, making a note of the wire connections before you replace it.
Sometimes it is quite difficult to get the speaker cable to make a good contact with the speaker sockets. You should check that they are making contact.
To test any loudspeaker just connect a 1.5 battery for a short time across the disconnected speaker. If working the speaker will pop!
As the sound is going to the headphones the amp seems to be OK and one of the above options should correct the problem.
Oct 27, 2017 | Panasonic SC-AK17 Shelf System
2000 chrysler grand voyager Integrated speaker amps???
Replace the speakers if they are amplified types.
Apr 25, 2017 | 2000 Chrysler Grand Voyager
After an attempted installation of a new car stereo into my 1990 Toyota Corolla, the clock and the stereo won't work. At first the stereo was working. However, once I secured it into place, I checked...
Did you make sure the harness was plugged securely to the back of the deck? Sometimes if you don't make sure it is snuggly plugged into the back of the deck it can come loose.
Jul 20, 2011 | Car Audio & Video
My Alpine MRP-M650 Amp is acting up. When I start the car, if the volume is at low, the subs don't work. But when I turn up the volume, they eventually kick in, then I can lower the volume. But when...
There are a lot of things that could cause this issue ...
1. Your amp requires more power than it gets when you start your car, and needs to charge up before it can work. If this is the case, you should be able to give your stereo about 5 minutes to warm up at low volume and it should come on. This happens a lot with amps with built-in capacitors (capacitors give you stunning, instant kick when working, but require a bunch of power to initialize). If you wire a bypass switch for the power to your amp and bass components, you can turn it on separate from the rest of the car and allow it to charge before you start your car (just be careful to turn it off when you are going to be away from your car for a while since this will allow your system to drain your battery).
2. Your amp might be set incorrectly for handling the system you are running. If your Ohms do not match up exactly (8 ohm speakers with a 4 ohm amp -- it's the "Impedance rating") then the system should not work at all, or should burn out the amp ... but with a jury-rigged system it can work. If this is the case, I recommend getting a new amp that matches your speakers.
3. Depending on the amp, there might be a volume-based cutoff that is working improperly. Turn on the car with the stereo at low volume. While the speakers are still not working, check to make sure that the amp has power, and seems to be functioning correctly. If everything seems like it's on the up and up, but the speakers are not working, try changing the volume-filter options on your amp.
4. I put this last because it seems like you know what you are doing with the system setup, but it is possible that you have a bad connection between the speakers and the amp, or between the stereo and the amp. There could be a loose connection somewhere (either inside the amp, between the amp and the speakers at the jack, or between the stereo and the amp at the jack). If this were the case, everything would look perfect from a visual inspection, but there could be a tiny space, or corrosion in a connection. Turning the stereo up to a high volume could then bridge this short circuit, and the electric force could magnetize the connection shut, allowing you to then turn the stereo down with the working connection. The best-case scenario here would be an external wiring issue, where you can clean any corrosion off the connections with an eraser, and reconnect everything tightly fixing the problem. The worst case would be a short WITHIN the amp, which would have to be repaired by someone with a lot of time and a circuit tester -- in which case you might be better off trading the amp in for a new one.
May 26, 2011 | Alpine MRP-M650 Car Audio Amplifier
My Pioneer car stereo stops all audio signal after a couple of minutes regardless whether i'm playing a CD or the radio, but the stereo stays on. and the CD seconds and minutes still count, do you know why...
Check your connections to your speakers and amp and look for loose wires touching metal. I believe your stereo is fine, this has something to do with your speakers and the speaker wire
Jun 07, 2010 | Pioneer DEH-P6400 CD Player
No sound coming from my speakers
Possible scenerio's with the little info you gave.
1.You have a bad speaker thats blown or the wires are touching the chassis of your car.
2. You have a factory amp and you need to connect the blue wire to the amp turn on wire. And if it still doesnt work then you have to rewire it complete or maybe have to get a special car amplifier compatible harness so your aftermarket works with your amplified system in your car.
3. In certain Ford cars they crisscrossed the back speaker wires. To test this unplug your harness from the radio. VERY IMPORTANT( splice these colors of wires in the middle enough so you can use a 9volt small rectangular battery to make the speakers you want to test pop(harmless))
1. green = back left + speaker
2. green/black = back left - speaker
3. purple = back right + speaker
4. purple/black = back right - speaker
test green speaker wires first touch battery to the + and - and the speaker should pop if not you have already discovered the problem. Know this time pop the green + and the purple/black - on the 9volt battery if the speakers pop you have found the solution.
Just criss cross the the negatives of the back speakers. From the radio harness end attach green to green, purple to purple, green/black to purple/black and last purple/black to green/black. And all your speakers should work again.
Dont ask me why late Ford Models crisscrossed their speaker wires. They just did.
Apr 08, 2010 | JVC KD-G140 Car CD Player
Popping sound in new speaker when i turned it on and then buring smell of one of the speakers. disconntected it and the other one is still working fine. its installed in my van nissan kubistar 2004
trace the wires from this burned out speaker to the stereo, are they actually connected to speaker output or to 12V+ you could have a fried stereo/amplifier or miswired speakers. is one of the wires from the speaker connected to ground? at either end, this could also cook your speakers and amp/stereo...
Jan 15, 2010 | 2006 Nissan Z
My amp turns on and off
Sounds like there could be a short somewhere. Check to make sure that there aren't any (exposed/bare) wires touching each other or if there is a bare spot of wire touching something metal. Check both ends of all the wires. A speaker wire may have come lose and is shorting out against the frame or some other place. Usually if it goes straight into protection mode or you're popping fuses you have a short somewhere. I assume the capacitor you installed is somewhere on the power line, which would be for helping with
noise. You can also try disconnecting your amp from your stereo and see what happens but leave the speakers connected, you don't want to run the amp with out a load on it (the speakers). If your amp doesn't go into protection mode when the stereo is disconnected, then you have a problem with the stereo and not the amp, assuming you already checked for any possible shorts first.
Jun 15, 2008 | Pyramid PB1236GX Car Audio Amplifier
Orion XTR Pro 1000 Car Audio Amplifier Logo
474 people viewed this question
Top Orion Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Marvin
Marvin
Morne Olivier
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
