How to take the cover off an LP2407
Need to know how to properly remove the cover from a gateway LP2407 monitor.
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 43 Answers
There are 3 screws along the bottom of the monitor, remove those along with any screws where the stand is attached. There are 2 slots on the bottom where the halves of the monitor come together; with a screw driver, you can use those for leverage. With another small screwdriver on the sides of the monitor where the front shiny cover, and the duller back case come together, pry the shiny piece away from the back cover and lift. It is a very tight snap fit, you have to go slow and coax it off.When you get the front cover started you can usually pull it off with your fingers by lifting up. Be very careful Of the front panel switch ribbon cable it is very easy to break. Hope this helps
Posted on Nov 03, 2012
  • Michael Giard Nov 04, 2012
    Thank you for the response. I finally was able to remove it with a little difficultity. Yes, the ribbon cable is one to watch out for. Seems the front frame is groove locked with the back panel, and had to edge a screwdrive along the edges. They sure dont make it easy, hehe.
  • Rich Young
    Rich Young Nov 04, 2012
    Glad to help!
Where can i get an owners manual for gateway monitor lp2407
can't find user manual, what is the problem with your monitor .
Aug 13, 2012 | Computers & Internet
Video controller (VGA Compatible) download
For Video driver you need to download video driver from (Gateway website)
try to connect VGA port properly so that the monitor works properly.
May 22, 2012 | Gateway FPD2275W LCD Monitor
I'm having trouble with my Gateway monitor coming on model # LP2407
Steve
there are so many things that can go wrong, the best thing is to take/send to a professional , or i can take a look at it.
many repairs are the standard capacitor replacement, but many others should be done by someone that has a bit of background in electronics to test all the circuits. For more help i can be contacted at Sprint6@zoominternet.net.
if you would like i can test the unit, at no cost to you, and give an estimate of repair cost once i have evaluated the condition of the unit.
Dec 01, 2011 | Computers & Internet
How to open gateway FPD 1765 LCD CASE OR BACK COVER
At Last! Okay this is how you open a Gateway FPD 1765 monitor. This Monitor open from the front first to reveal 4 screw under the black trim. Lay the screen face up, NOT FACE Down. So that the GATEWAY LOGO is looking at you. Carefully, lift up the black plastic trim slide a knife or slim tool, or your fingers will do,lifting the trim up a off. BE CAREFUL NOT TO BREAK THE POWER BUTTON WIRES, near the power on button. Then remove the 4 screw holding the back cover on. When you remove these screw the monitor is free, but careful there are 2 set of thin short wires that need to be un plug. You should be able to go for there.
Jan 30, 2011 | Gateway FPD1765 17" Flat Panel LCD Monitor
My gateway monitor flashes gateway logo then it (FPD 2185 W)
Look for bad DC filter caps in the power/inverter board.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 27, 2010 | Gateway FPD2275W LCD Monitor
REPLACE GATEWAY LAP TOP TOUCH PAD
HI THERE!!
Replacing the touchpad of your laptop is not difficult but because laptop parts are very delicate you need to be careful
To remove the touchpad you need to remove the top cover, also known as the palm rest
1.Power off the Gateway laptop, then disconnect the AC adapter from the power jack. Remove any other devices connected to the laptop.
2.Place your hand on a bare metal surface to release any buildup of static electricity. Close the lid to your laptop and turn the computer over.
3.Slide the battery lock over to the side to pop the battery out from its compartment.
4.Set the battery aside, then turn your computer over once again so that it's facing up. Rotate the laptop so that the back (not the bottom) is facing you.
5.Remove the two screws securing the bezel in place from the back of the laptop
6. Open the lid to the laptop, then insert a flat-head screwdriver underneath one end of the bezel to loosen it from the top cover. The bezel is located just above the keyboard, but below the monitor
7. Carefully remove the bezel the rest of the way. Insert the end of the flat-head screwdriver underneath the top of the keyboard to pull it away from the laptop.
8. Turn the keyboard over and place it face-down on the top cover. Remove the cable connecting the keyboard to the motherboard. You may need to pull back and unlock a connector securing the cable in place.
9. Set the keyboard aside. Remove the four screws located just beneath the display panel, then remove the cable connecting the monitor to the motherboard. Carefully set the LCD display aside.
10. Remove the four screws located near the center of the top cover. Release small blue and white cable connecting the touchpad to the Gateway laptop.
11.Pull the top cover up from the base of the laptop, removing the touchpad along with it.
NOTE; you can remove your touchpad and swap it out with a new one, but you can also buy a top cover with a touchpad pre-installed.
Jul 08, 2010 | Gateway MT3705 Notebook
I have a gateway lp2407 monitor and can not get a picture but the power is on. The blue display lights on the right side of the frame light up, then go away while the power button stays blue. Tried...
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
Please post back what you find.
Nov 24, 2009 | Televison & Video
I need to know how to get the bottom off my laptop so i can get to the power button and fix the sensor underneat it. i removed all the screws on the bottom yet it wont come off. myl aptop is a gateway...
the bottom doesn't come off......you have to remove the cover on the screen hinge and remove the keyboard and monitor to isolate the "bottom" of the unit. After you have removed the panel on the hinge, you can unscrew the keyboard and detach the screen. At this point the bottom can be removed by taking off the main boards and other connected components.
Good Luck and please rate this post
Oct 04, 2009 | Gateway ML3706 Notebook
Gateway GT5028 will start but no signal comes up on the monitor.
your hard disk/drives may not be set to shut down
in control panel display under screen saver click power
then check settings for turning off monitor and hard drive
make sure they are set
do a virus scan
then do a disk defrag
please let me know
Feb 23, 2009 | Gateway GT5028 PC Desktop
Removing cover
Firstly you have to take off two screws from the backside. Secondly: there are two holes on the upper side, you must press in with small screw driver(one by one ) and pull backcover back.
I hope this will help you.
Jan 12, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
201 people viewed this question
David Payne
David Payne
