L300 wireless problem
I have a toshiba l300 and a bt black wirless router. The internet connection seems to cut in and out for example if i am on msn it will cut in and out, I thought this might be the strenth of teh signal but on my laptop it is showing i have 3 out of 5 bars of strentgh,Could you help me please/
  • jonnymck Jan 04, 2009
    Yea i tryed that eariler today sitting about 2 feet from the router but still had the same problem! Would it be something to do with the wireless software on my toshiba?
    President:
  • 846 Answers
Ive had a similar problem and it was due to windows and the software for the router both trying to run the network and was causing problems.Perhaps check and see if there are two programs running.
Other than that perhaps you could return that router if you can and stick with linksys or netgear.
Question :
Does it cut out the same no matter how close you sit to the router ?
Posted on Jan 04, 2009
  • Quickfx PC Repair Jan 04, 2009
    That's what I meant by two programs running, perhaps you ran windows wireless network wizard, and installed the software that came with the router and is also trying to manage your wireless network.
    1. Try un-installing any software for your router and rebooting then reinstalling drivers only for the router no network management software.
Hello, im trying to install my wirless printer to my wireless computer and im having some difficulties. for example its asking me to check my wireless LAN access point.. I dont know waht that is? im...
The Canon is trying to connect to a wireless router or wireless access point which is connected to your computer network. Your Sprint 3g device is a wireless broadband device for Internet connection and cannot connect to the Canon using this device.
You need a wireless card that connects to the wireless router or wireless access point.
Otherwise you can connect to your printer using a printer cable.
May 16, 2011 | Canon MP560 All-In-One InkJet Printer
Hello, i have a toshiba L300 and i cannot get online, it says that it cannot find a connection and every time i get to the point where i put in the key code for the router it says it cannot be found, i've...
I would take an ethernet cable which looks like a phone cord only a little thicker and plug it into your wireless router. If your computer gets on the internet then you know that it is simply a wireless setting. Then all you need to do is login to your router and modify the settings in the router. If you tell me what kind of wireless router you are using I could help you with that.
Feb 28, 2011 | Toshiba Satellite Pro L300 Notebook
Netgear wirless - installed on toshiba satellite a45 - S151 will not connect to internet router = comcast - linksys also causes conflict with connection of other wireless computer
Presumably, you have configured your wireless router:
* SSID (your "network name")
* encryption-level ('WPA' or higher security)
* password for your network
With that information, any wireless device (iPod Touch, iPhone, NetGear wireless adapter) should be able to connect to your wireless router.
Exactly what error-message are you getting?
Feb 21, 2011 | NetGear WNA1100 Wireless-N 150 USB Adapter...
My PC can't seem to stay connected to the router permanently, the connection will time out, then reconnect again after half a minute or so (making it impossible to stream media/play online games) PC uses a...
Could be interfernce from your neighbours wirless signals.
Somewhere in the wireless settings of the BT router, you can change the radio channel it is working on - I belive there are about 6 to choose from.
It doesnt actually matter which one the router operates on, but by default the router (and probably your neighbours' routers) is most likley set on the middle one and therefore interfering with each other.
So try changing to another channel and see if it makes any differnce. No joy ? Try another one.
After changing channel, the router will need to re-boot, but your PC will automatically search all channels and will re-connect once the router has finished re-booting.
Sep 22, 2009 | D-Link Air DWL 520 802.11b (DWL-520)...
My new Toshiba Satellite L300-20W will not connect to the internet via my wireless broadband connection (which is working fine as I tried another computer with it). The Connectivity Doctor gives the...
This problem is common.
This error message occures when the wireless card does not get an IP address from the wireless router. To get the wireless router to issue the wireless with a new IP address the connection needs to be repaired.
Right click on the wireless icon and click on repair.
Jul 30, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
Heyyy i have take tosiba model L300 wireless len drivers so wht can i do????
You need an Internet Service Provider and a wireless router and a broadband DSL or cable modem. The DSL or cable modem could have a built-in wireless router, this modem could be included in the broadband plan from the Internet Service Provider.
1. You need organise an Internet Service Provider, they should provide configuration settings, password, and e-mail info etc.
2. Install the hardware device and wireless LAN drivers. If you have not got these drivers, download them from the Toshiba WEB site. Make sure you select your model laptop and the XP or Vista versions of the drivers that match the Windows version on your laptop.
3. Follow the Internet Service Provider to configure your LAN card, and E-mail program.
If you follow the instructions correctly you will be able to connect to the Internet and send and receive E-mails.
Jul 03, 2009 | Toshiba Satellite Pro L300 Notebook
Type of wireless
http://explore.toshiba.com/laptops/satellite-pro/L300
this shows all the l300d models at the bottom and what the card is in it. I would get the newest available for speed, and reliability. it is N. an N router will be backward compatible with B, G, and A
Dec 22, 2008 | Computers & Internet
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Agere systems ac'97 modem and wireless internet
you can not connect to ur modem wirelesly unless ur modem has wirless plugins in it..
Well the firmware upgrade wont help u unless u have wirless plugin hardware in ur modem
In that case u would require to contact ur ISP(internet service provider) to get wireless modem
srini
Feb 09, 2008 | Computers & Internet
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
