I need Help Replacing A thermocouping on a wall heater
  • Heating & Co... Master
  • 2,461 Answers
Thermocouple run from side of the pilot to the gas valve cooper tube brass nut by the pilot and grey nut on gas valve undo these nuts remove thermocouple at both ends and fix new
Posted on Nov 03, 2012
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
My cadet wall heater wont turn off
My cadet heater was doing this so I pulled it off of the wall and saw that the two wires coming from the thermostat portion had melted out of their insulation and were crossed. The heat is of some concern, but for now I just wrapped them in electrical tape to insulate them better against melting
Mar 11, 2012 | Cadet Manufacturing Built-In Wall Heater
Pilot small some times big
could be a pressure problem water in the gas line causing it to drop or reg problems
Mar 05, 2012 | Heating & Cooling
How do you get to the thermocoupe? it is under warrenty yet.was made in 06.had a plummer look at it
it isnt under warranty, the plumber should have been able to replace it. It is a small copper line that goes from the gas valve to the pilot. let me know if i can help any further. and a rating would help also.
Apr 17, 2011 | Heating & Cooling
I have a Sterling garage furnace,pilot is on ,but main burner will not light.
Be sure you turned the Control knob from Pilot to ON. Without doing that the heater will not turn. If that's not the problem, the Thermopile may need replacing. Also, check the volume of gas at the heater. It should be a minimum of 5 to 7 water column inches. If it has a wall thermostat, be sure the wires are correctly installed at the heater and the wall thermostat and the it's turned up higher than the ambient air temperature in the garage. If this is an older installation, be sure the exhaust vent piping is not blocked.
Feb 09, 2011 | Sterling RF75 Natural Gas Heater (75,000...
Need coolant hose diagram for 1992 Chevy Cavalier
it makes no difference as long as you have coolant going it and out
Nov 13, 2009 | 1992 Chevrolet Cavalier
Food is freezing on left side of refrig and not so cold on right
Check the back wall of the freezer section for any ice buildup. This would be from a failure to defrost and requires parts.
Check the freezer side for the evaporator fan motor. Is the fan motor running?
If not a fan motor is needed.
If there is ice on the back wall of the freezer you can activate the defrost control by turning the cold control thermostat OFF then back ON "3" times.
Once you activate the control listen closely in the freezer side for a sizzling sound. This would indicate the defrost thermostat and defrost heater are good and the defrost timer needs replacing. If there is no sizzling sound after 20 minutes,the defrost thermostat and possibly the defrost heater need replacing.
Nov 09, 2009 | Maytag MSD2756G Side by Side Refrigerator
Heater shutting off
this type of heater is very sensitive to the state of the pilot since it uses a Renni type thermocouple to sense a low oxygen situation. Usually the pilot needs to be cleaned. If that does not restore operation only other thing to do is try replacing the thermocouple.
A low pilot will usually hold for a few minutes so I would expect that you have a bad thermocouple.
Nov 17, 2008 | Desa International Blower Glow Warm Wall...
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
