I have coleman evcon furnace model#DGAT095ADA the induction motor starts when thermostat kicks on but furnace does not light
22yooper
  • 828 Answers
SOURCE: Coleman Evcon model DGATO70BDC Starts to run then stops?
What you have is an ignition problem and your unit is shutting down on safety.
Posted on May 09, 2008
22yooper
  • 828 Answers
SOURCE: I have a coleman/evcon heat
I would check the hig voltage power supply to the unit. Check the main breaker and make sure it is on. Check the disconnect and make sure there is power at that point to the condensing unit. The contactor will kick in from the low voltage in the control circuit.
Posted on Jul 11, 2008
morefords
SOURCE: have a coleman evcon furnace
Your centrifical swith is stuck open on your blend motor. I found that removing the blend motor housing and spinning the stuck motor (from setting over the summer) will get you out of a bind ,.but you may end up needing this centrifical switch (locatedon the bottom of the blend/fresh air intake) motor replaced.
Posted on Nov 07, 2008
mrgrzz
  • 88 Answers
Thanks for your question,
more than likely it would be your Flame sensor, it is more than likely dirty and needs cleaning, it is the rod that the flame impinges on when the unit lites off, if it is dirty then its a matter of removing it and cleaning it with emery cloth, or replacing it, cleaning is the cheaper alternative, just look at the front of the burners, and you will see a pencil thin rod, thats your flame sensor, should be just one 1/4 hex head screw holding it in place, a quarter inch nut driver works great for this, then remove, clean, and reinstall, make sure you have the power off while preforming this task, hope that fixes your problem. please leave a rating for this, thanks again,
mr.grzz
Posted on Jan 23, 2009
atocrxr
  • 135 Answers
SOURCE: The thermostat clicks but the a/c won't turn on. I
You need to check the breaker for the A/C in the electrical panel, and have the fuses in the disconnect located near the A/C outdoor unit.
Posted on Apr 04, 2010
Coleman Evcon model DLAS075ADC, glow plug lights, fire starts, then the blower comes on,..after ten minutes the whole system shuts down and will not re light, what is causing this?
Check to see if the pressure switch is sticking...it wont restart the furnace if it is already pulled in before the inducer motor is called to kick on.
Dec 17, 2013 | Heating & Cooling
Our coleman evcon furnace has started clicking over & over again before it starts up, we replaced the thermostat & the same thing happens.We are afraid that this is hard on the furnace & have resorted to...
Suspect that the igniter is causing the clicking (or could be a relay). Suggest having the furnace serviced. There is also a major recall for some models of the Coleman Evcon furnaces.
Oct 29, 2013 | Heating & Cooling
Coleman Evcon furnace. Can i make it circulate air?
Your thermostat should have a "continuous blower" setting. Use that instead of fooling around with the A/C setting
Jul 17, 2013 | Coleman 7990-319p Evcon Gas Furnace...
I have a Coleman evcon gas furnace. The inducer motors activates when the thermostat is engaged,but shuts off before the heater kicks on. There is also a blinking red light.
Hello, it sounds like the pressure switch is not closing on your furnace and remaining open, reasons for this could be a blocked flue pipe, the tubing going from the inducer motor to pressure switch could be blocked, loose, or have condensation in it, or the switch itself is bad. U can check the tubing by taking it off blowing some air through it and making sure no condensation is in the tubing, then reinstall it. If everything checks out good then the pressure switch is bad and must be replaced.
Feb 20, 2011 | Coleman Heating & Cooling
I have a coleman evcon model dgat070bdf furnace. As soon as the furnace fan kicks on the burner shuts off. Any ideas?
Hi check the flame sensor is clean also check out the pressure switch , and check air filter is clean
Feb 05, 2010 | Coleman Propane Forced Air Heater...
My goodman gas furnace is not kicking on. the light on the unit is saying that it should be working but it is not. there is no pilot light, the fan is working the heat is not
If you are not getting any codes from the board, then the furnace is not getting a call for heat from the thermostat. A wire may have come off, the thermostat not properly wired, or a break in the stat wire. On a call for heat, you should have 24vac between W and C on the circuit board. This will let you know if you are getting a call for heat all the way back to the furnace.
Oct 01, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
