Question about Audio Technica AT-PL120 Turntable
How to replace the pin in the stylus - Audio Technica AT-PL120 Turntable
I have replaced new cartridge in Epson Stylus D120 still printer is not working and shows cartridge empty light on.
I would expect you used a refilled cartridge.
The epson cartridge needs to be reprogrammed to say its full again.
You can get the reprogrammer of ebay very cheaply. you just hold the re programer on the contact pins for a couple of seconds until the light flashes.
Several printer manufactures are now doing this to lock you into their ink cartridges.
Please dont forget to vote this answer was helpful
Many thanks
Feb 15, 2011 | Epson Stylus cx7450 All-In-One InkJet...
My camera lens wont come out
Hi there its a problem of your lens. The lens guide pin is damaged or dislocate. Thats why the lens can not able to focus properly. Replace the guide pin. Thanks.
89bf7ce.jpg personalaudio;subcat=mp3%26digitalmediaplayers;brand=apple;product=ipodnano4gb;ptype=thread;tile=1;sz=300x250;ord=552766421135872? -->
Mar 24, 2010 | Olympus Stylus 800 / ? 800 Digital Camera
Recyled ink isn't being recognized
Have you reset the Chip on the cartridges. What model you use--- a nine Pin or old seven Pin model. Nine Pin are difficult to reset, seven Pin are easy with a hardware Resetter. If Chip show empty cartridge, you can fill them two days, it will show empty-- reset the Chip!
Apr 17, 2009 | Epson Stylus Photo R260 InkJet Printer
Hook Up possible for EPSON Stylus 880 to new computer w/USB ?
There is no conversion cable that you can use with parallel connector since USB transfers data in Serial mode and the parallel cable handles data in Parallel mode.
Sorry.
Mar 01, 2009 | Epson Stylus Color 760 InkJet Printer
Record PIN needs to be changed, where can i get spare in Bangalor
It is called a stylus and is part of a cartridge. There is a small release lever or it comes out as a plugin device. I cannot see where you are but eBay will have your stylus/cartridge for your turntable if a stereo shop is not nearby. Also any TV repair shop can order it for you. Steve Medley
Feb 07, 2009 | Philips Audio Players & Recorders
Poor sound output
One of the wires from the stylus had a poor connection through the pin connector.
I recrimped the pin lug reconnected and all is now working as it should.
Jan 01, 2009 | Ortofon Stylus DJE Turntable
Forgot pin number for epson stylus cx6400
If you forget your PIN code, you can regain access to the CX6400 by running the security lock program from your computer:
1.
Insert your Stylus CX6400 software CD-ROM.
2. Windows: If you see the Software Installation screen, click Exit.
Open the
SecurityLock Tool folder on your CD-ROM, then double-click the program file located in that folder.
Macintosh: The EPSON folder automatically opens (if it doesn’t, double-
click the EPSON CD-ROM icon). Then double-click the Security Lock icon.
Nov 24, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Epson cx5000
The problem may not be the nozzle on the cartridge, but the pin on the printer that connects to the nozzle. There may be better ways to do this, but it worked for me: remove all the cartridges and look into the docking bays; you'll see the pins sticking up. I use the word pin for lack of a better word; they're actually nozzles themselves. Take a paper towel and gently wipe off the pins until most of the ink is removed, then replace your cartridges.
I found all that the print utility clean function does is waste ink. Don't use it.
Good luck
Sep 18, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Audio Technica AT-PL120 Turntable Logo
24 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
