Question about Cooktops
Need jenn air cooktop fan switch part #PS1515393
Looking for white fan switch Part # PS1515393
fridgetech
  • 473 Answers
SOURCE: Jenn-Air JED8430 Electric wiring confusion
On Cooktop From Box
Black to Black
Red to Black w/red stripe
White to Ground
Green to Cooktop frame
Posted on Nov 16, 2007
  • 1314 Answers
SOURCE: jenn-air downdraft fan not working
there are 4 wires for that red white black and green sure you didnt miss a wire
Posted on Dec 30, 2007
SOURCE: Jenn-Air Gas Cooktop Model CVGX2423
Just had this problem today on our seven or eight year old Jenn-Air cooktop. When using the front right burner all ignitors would continue to fire until I turned off the burner. The three other burners worked correctly. After trying all the obvious soulutions w/o success I pulled off that burners control knob and the rubber seal which exposed the valve. Their was a bunch of crud in there. I put a small (one inch) paint brush in there and vigorusly loosened all the crud. I then inserted the nozzle of our central vac - which just happened to fit perfectly - and sucked all the stuff out. I repeated the proceedure a couple more times, reassembled the knob and started the burner. Worked just perfectly!!! YMMV. Good luck.
Posted on Feb 08, 2008
SOURCE: cooktop fan switch replacement
1. Turn off the power at the breaker box.
2. lift off the air grill.
3. remove the two screws at the front of the control switch panel (escutcheon)..
4. slide the control panel forward until it disengages, then lift up to expose the switch assembly and wiring.
Posted on Jun 18, 2008
Eddie Rentas
  • 59 Answers
SOURCE: jenn air jed 8430 electric cooktop control switch for rear burner
The cook top is attached to the wood frame by brackets, just remove the screws and the electric connection, make sure the power is off from the main box, it's a 220 volt wiring and then just lift the top off. to remove the glass, look around the edges and you should see some small screws, just remove them and the glass should lift off.
Eddie Rentas
Tupper Lake NY
Posted on Jul 23, 2008
Replacing fan switch jenn aire D156
I have a Radio Shack 3-in-one remote control 15-302 and I need codes for Dinex TV..it says it is 4 numbers
Jan 01, 2014 | Jenn-Air Cooktops
I have a Jenn-Air downdraft cooktop. My blower fan will not shut off. When I press down on the metal part the knob goes on, it will shut off. Can anyone help?
It appears you simply have a bad switch. Try contacting Jenn-Air or looking them up on the web to find out if they have replacement parts available
Apr 29, 2011 | Jenn-Air JED8430 Electric Cooktop
Jenn-air cm200 fan switch replacement part number?
Here is the part number for the switch 74009254
May 08, 2010 | Jenn-Air JED8430 Electric Cooktop
JED 8320 fan and burner switch
http://www.whirlpoolparts.ca/index.php?PHPSESSID=f2330dc59be8bdd5f5463d5e0d1362f9
Oct 05, 2009 | Jenn-Air JED8430 Electric Cooktop
ONE OF THE FOUR TOUCH PADS DOES NOT RESPOND
JED 8320 Jenn Air Cooktop with down draft. I need a burner switch and a fan switch.
Oct 03, 2009 | Jenn-Air JED8230 Electric Cooktop
Wiring problem
those wires dont go to the down draft. those colors are to hook up the stove. do you have the instalation instructions?
Nov 09, 2008 | Jenn-Air JED8430 Electric Cooktop
Cooktop fan switch replacement
Jun 14, 2008 | Jenn-Air JED8230 Electric Cooktop
Jenn-air downdraft fan not working
Apr 15, 2007 | Jenn-Air JED8430 Electric Cooktop
Cooktops Logo
132 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
