Can you help me with the univusal code for an rm5199 to connect to a clarity tv
Mitsubishi 60 dlp 120hz tv picture is not as bright as before
have you checked your connections and sure your getting a HD signal for the clarity . as to Darkness it may be a lamp failing and that also may be your clarity problem if its getting to the end of its life span on the bulb
Oct 19, 2014 | Mitsubishi Televison & Video
Wanting to watch Netflix on tv, from IPad
We do it all the time there is an adapter I bought one on amazon and have seen others at Target/ Bestbuy/ any electronic store. Depending on weather you want the connection to your TV to be A/V or HDMI they have both. Mine is white in color and it has an IPod/IPad/IPhone connection on one side and the other is either the female end of an HDMI or a female end to and A/V cable with red white and blue. Mine was about $10-$15. Although depending on your TV the clarity will vary depending on which one you get. I have an older TV in my kids play room and the AV cable gives the best picture. However on our newer Plasma TV the HDMI is much better as far as clarity! Hopefully this helps if you need it I can give a link to what I'm talking about. http://www.cellphoneshop.net/ipadhdmi.html?CAWELAID=1061793656&catargetid=530001600000009805&cadevice=m&cagpspn=pla&gclid=CIXb_eHKhrsCFVaTfgodgQoAGg
Nov 15, 2013 | Televison & Video
Have a clarity tv need code forit
code for clarity tv 0672 turns tv on and off does not work volume?
Feb 10, 2011 | Audio Players & Recorders
I was given a GE 27GT616 television but can't figure out how to connect a converter box or dvd player
If your tv has video in socket (yellow color)and audio in socket(white color),you will connect the dvd player audio video output. it will give give clarity picture. your tv have not av socketyou can connect your dvd player audio video output to converter audio video input.And then connect to converter RFout to tv Rf input(antenna socket)and tune the tv you wlii get picture.
Jul 31, 2010 | GE 27GT616 27" TV
Can't get it to work with cable box.
You might try to make sure that your firend is using HDMI cable and his unit with his box and/or TV with an AUX setting.
Just thought this might be how his is operating. We hope the suggestion is helpful. Thanks for contacting FixYa.com
Sep 03, 2009 | Plantronics Clarity C120 Wirelesstv...
Sky+ Remote code 'Clarity' LCD TV
I have decoded the remote code from my 32"
the code is 1239
if you need further help then please email chrisryu2@googlemail.com
Thanks
Dec 17, 2008 | iLO 2600 Television
Televison & Video Logo
150 people viewed this question
Top Televison & Video Experts
Electro Med Services...
