Question about Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx6 1400 express
Washing would not spin at end of cycle. Have checked the filter in the front and cleared it - still dosnt work. Drain hose not kinked-any ideas please?
  • Anonymous Apr 06, 2009
    The washing machine is not starting due a child safetly lock how do you get it off
  • Bosch Master
  • 3,463 Answers
Possibly worn brushes in motor.
Remove rear panel, remove belt, remove motor connector plug, inscrew 2 screws that secure the motor.
Lever motor back with a screwdriver, keeping hold of it as you do.
You will see the brushes at the terminal end of the motor.
If they are less than 4-5mm, they need to be replaced.
Refit motor and belt and motor plug. Test on spin
Plz rate my solution.
Posted on Jan 13, 2009
I have just had this problem and as in the other solution he is correct. once you have the motor in your hand the brushes can be changed simply by removing the spade connection then slide the brass locator along and this will disengage the brush and release the spring which holds it in place. make sure you note which way the diagonal part of the brush is facing and be sure that you replace facing the same way the brushes only cost me £15 for the pair
Posted on Aug 04, 2009
My Bosch washing machine showed e29. We checked the filter and now the machine won't spin the clothes.
Is the drain pump actually running, if so check for blockage at the drain end "assuming you cleared the filter", if not check the motor carbons
Sep 07, 2017 | Bosch Washing Machines
Bosch classix water won't drain
check for blockages in the outlet pipes, filter and pump.
Dec 30, 2012 | Bosch Classixx WFL 2066 Front Load Washer
I have a Bosch WFMC330SUC that does not end the cycle, it just keeps starting over. I assume it is a bad control board, but they are $300+ and I'd probably replace the machine instead. Any suggestions?
Hi wwwylie,
First check the Drain Pump filter, as the last 2 cycles of a machine is Drain & Spin, and if the Drain pump cannot drain the water, the filter may be clogged and the cycle won't progress to spin.
Please follow my below Tip on how to do this:
Kind Regards
* If this solution helped you, please rate it
Aug 16, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
I have a Bosch Classix 6 1200 Express that stopped working 23 minutes before the end of the cycle. It has been noisier recently but this time it stopped altogether and when I tried to spin the clothes the...
Hi davidandsall,
Before it can Spin (The last part of any cycle), it would need to drain the water first. Your machine is stock on that particular position, most likely because of a clog in the Drain Filter compartment.
You will need to clean it.
Please follow my below Tip on how to do it:
Kind Regards d")
Aug 05, 2011 | Washing Machines
I have a Bosch clasixx 1200 s express washing machine, When I select a program the machine buzzes but the cycle doesn't begin. The drain cycle works and the spin works. if i select freshen and rinse the...
Bosch clasixx 1200 This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 26, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Cycle stops and won't drain or spin. The 'end' light flashes and it makes a whirring noise, won't go onto the rinse cycle.
Have you checked the pump and filter are clear? bottom right flap on front panel to expose pump. Check the hoses are clear, particularly if it is connected under the sink, via a spigot connection. If the machine has good motor action, but not spinning effectively, it will more than likely be a drainage problem.
Jul 05, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch logixx 1400 express washing machine spin is not working . ALSO THE WATER IS NOT BEING DRAINED OUT IN THE NORMAL CYCLE
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Apr 10, 2010 | Bosch Exxcel WFX 145S Front Load Washer
My Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Dec 09, 2009 | Bosch Washing Machines
Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Dec 22, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
932 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
