Question about Eljer Whirlpool In-Line Heater- 494-1550-00
Thr e on/off switch on the side of tub that turns on the jets is what I am talking about. Some thought they are a vacum switch. Our whirlpool has a heater and I do have the operating and maintance instructions for that premiere series whirlpool from Eljer
5 Suggested Answers
SOURCE: installing whirlpool tub
If it is a five foot tub, home depot usually carries them, if not any plumbing supply store will have them.
Posted on Jun 23, 2009
SOURCE: We like the eljer sheridan six jet whirlpool tub.
We have not solved our problem,but we will pay a price to find our correct size. We can do it locally for no fee.
Posted on Jan 05, 2010
  • 11 Answers
SOURCE: Eljer jetted tub on and off switch will not work
It may seem like a dumb answer but check the ground fault outlet or breaker. Then make sure there is enough water in the tub. It should be a few inches over the jets.
Posted on Mar 23, 2010
dogsled48195
  • 411 Answers
SOURCE: Eljer total massage tub. Problems
CALL: 866-883-9832 for service problems
Posted on Jan 26, 2011
I have a whirlpool tub and need to find some caps to cover the jets. Not sure what brand tub is, sides are all covered. Can you help?
try a plumbers shop as it is a whirlpool tub
you state that it is a whirlpool tub then you say don't know what brand of tub it is
whirlpool is a brand name
any way the plumbers display of bathroom units and tubs will help you as the jets used are generic and not specific for the tub
Nov 16, 2015 | Whirlpool Home
My new jacuzzi 6 jet tub is only working on one side. What could cause that?
Probably control panel or if there are separate pumps for each side, that side's pump probably doesn't have a relay working with bad switch from the control panel.
Mar 31, 2015 | Whirlpool Jacuzzi Bath Tub with Jets
I have a Jacuzzi Espree 6036 and switch will not shut off whirlp
Hello. yes you can replace the switch. All of the parts come with instructions. plus you can call the jacuzzi repair technician directly and have him/her talk you through the procedure at 866-905-2289. here is the owner manual in case you don't have one
http://www.guillens.com/jacuzzi/images/ESPREE.PDF
Apr 02, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jets don't work in the jetted tub.
First the obvious, most are electrically connected to a ground fault device, ether an outlet or a breaker. BEFORE ADDING WATER, check these out to make sure they are not tripped. Most all tubs have a minimum water level which must be reached before the jets will operate. This is usually a piece of trim located above the depth of the jets. Make sure the tub is filled to cover this part. If you cant identify the water level device fill the tub so that all the jets are covered by an inch or 2. Some tubs have push button switches or touch pads to control the motor, some have touch sensitive trim. There may be some sort of medallion from the maker on the tub, simply touching it will start the tub. Once you get it going most tubs have a built in timer that turns off the pump in 15 - 20 minutes. For more tub time just hit the switch again but keep in mind that extended exposure in a hot tub can mess with your blood pressure and cause you to loose balance or pass out, hence the 20 minute timer.
Mar 22, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
Filter leaks water after use.
I know what you are talking about, :). There is more than likely a large nut that holds that overflow in place behind the tub wall. See if you can put pressure on it, like pulling it out while you turn it clockwise The gasket is more than likely under the nut and pulling as you turn may get the gasket to grip the rough exterior of the tub and hold the nut still. then as you feel it snuggung up, put your palm over it as turn it as far as yo can tightening it up. See if that helps. the gasket probably shrunk or it was never properly tightened. If it seems to get looser, stop and go the other way. good luck.
May 10, 2009 | Home
My american standard jacuzzi tub is pluged in but jets won't turn on
check for power at plug in if power your vacume switch is probably out replace switch.
Apr 28, 2009 | American Standard 2771.002.021 Cadet 5' x...
Kohler whirlpool will not shut off and sounds like about to blow
Sounds as if you may need a new switch to turn the tub on/off. You can find one on our site www.uspartscenter.com
Feb 28, 2009 | Kohler 1221-H-0 Seadream 6' Whirlpool Bath...
Power switch for whirlpool tub
the easiest thing (maybe) is to install an air switch kit on the side of your tub. Here is a link to the part. Basically you install an air button on the side of the tub, install the air tubing from the nipple on the underside of the air button to the nipple on the box that plugs into an outlet under the tub. The pump plugs into that same box and the air tubing from the air button pushing onto the nipple on the box. When you push the button on the tub it will turn the pump on/off. Air Switch Kit
Jan 17, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Eljer Whirlpool In-Line Heater- 494-1550-00 Logo
54 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
