Question about OKI MICROLINE 520 Matrix Printer
Okidata 320/420 printhead not printing aligned.
Printhead starts printing at proper position then after each line is completed starts printing further and further to the left until printhead has no more room to go left and alarm light goes on.
  • GWAC Sep 15, 2009
    HOW DO YOU CLEAN A OKI DATA MICRO LINE 184 PRINTER HEAD?
  • Anonymous Mar 29, 2014
    can't fined home position
    Scholar:
  • 77 Answers
Clean the large silver rod that runs through the carriage. It is dirty and not allowing the carriage to move as freely as it should. Ideally it should be left dry. Also change the ribbon. The same motor drives the carriage and the ribbon. If it has a bind, the same thing can happen. Hope it helps Ed
Posted on May 19, 2007
Below the head is a black serrated rack called the space rack. Replace that item and it will sort out the moving of margins Michael
Posted on Oct 05, 2007
Why would my printer be printing very fuzzy print with lines through it.
Blocked Printheads and/or Alignment issues.
Try cleaning the printheads and see if there are any increases in quality. Then start down the alignment road. Be very careful when tinkering with alignment. If you mess it up it may require a technician to realign it properly.
Aug 27, 2014 | Brother MFC 6490CW InkJet Printer
How to replace printhead to okidata 321
Unplug power, look down on printhead some have a chrome metal clamp that swings out and then you pull up on print head. Some models have two screws that hold print head in. Then the print head pulls up.
Jul 23, 2014 | Okidata 321 Turbo D Printer - Factory
Does not print evenly. Some lines are very faint. Have done calibration and cleaned print head several times. Prints from internet and e-mails okay. But does print from Simply Accounting, tax software...
Welcome to FixYa.
Since you have already performed calibration and cleaned the printhead, kindly verify that the ink cartridges are not damaged and are completely seated in the printhead:
1. Lift the printer access door, then remove the ink cartridges from the printhead.
2. Verify that the labels on the ink cartridges are intact, and that the cartridges are not damaged.
3. Verify that the KODAK Ink Cartridges have not been refilled.
4. Insert the black ink cartridge into the printhead, then press down firmly until you hear it click into position.
5. Insert the color ink cartridge into the printhead, then press down firmly until you hear it click into position.
6. Close the printer access door.
7. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
NOTE: When the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
8.Reprint the original picture or document that had the quality problem.
Hope this helps. Thanks for using FixYa.
Dec 15, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have an hp officejet d135. It has knew ink jets and is hooked up. When I try to print the ink won't come out and the window says it's empty. Do I have a toner and if so where is it?
Your printer has a print head under the ink cartridges. You can try a cleaning, and if this does not fix the issue, you may need to replace the print head .
Clean Printheads function
To activate the Clean Printheads function from the front panel:
  1. From the front panel, press MENU.
  2. Press the RIGHT or LEFT ARROW until Status and Maintenance displays.
  3. Press ENTER
  4. Press the RIGHT or LEFT ARROW until Clean Printheads displays.
  5. Press ENTER
After a few minutes the HP Officejet D series will automatically complete the printhead cleaning operation.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 24, 2011 | HP OfficeJet D135 All-In-One InkJet...
When prints come out the landscape is all white .sky and sea ok. photos comes out with lines on them
Verify that the ink cartridges are not damaged and are completely seated in the printhead:
    For more information view Installing the Printhead and Ink Cartridges:
  8. Reprint the picture or document that had the quality problem.
Dec 05, 2010 | Kodak ESP7 PP All-In-One Printer
My TI 810 printer has begun to error out. It prints a few lines, and the lines appear to "slide" to the left, until it is printing off the left edge of the paper, and then it stops printing, and the error...
Hello.
This is a ribbon problem, it needs to be changed. The fact that the lines "slide" to the left prove that the carrier is not going back to its original position every time.
So, the solution is to change the ribbon.
Aug 24, 2010 | Texas Instruments TI 810 Matrix Printer
The documents are faded even after putting in a new cartridge
  • make sure you are using inkjet papers as inkjet printers work on inkjet papers.
  • Lift the printer access door, then remove the ink cartridges from the printhead.
  • Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  • Close the printer access door.
  • Reprint the picture or document that had the quality problem.
  • if still light prints then proceed further
  • Print Test Page
  • Review the printed test page and verify that:
    • the left color blocks are gray, cyan, and black.
    • the right color blocks are magenta, yellow, and black.
    • each block is completely filled with color.
  • If no---> Clean Printhead, the On/Off light flashes during the cleaning procedure.When the On/Off light glows steady, print test page again.
  • If Yes---->The problem could be caused by the type of paper you are using.
May 28, 2010 | Kodak Office Equipment & Supplies
The black print doesn't fully print each line, roughly every third line only has the top or bottom printed and the rest is very faded
Here are the steps.
1.Please verify that the ink cartridges are intact and securely inserted into the printhead.
a.Lift the printer access door, then remove the ink cartridges from the printhead
b.Verify that the label on the ink cartridges is intact, and the cartridges are not damaged.
c.Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
2.Clean the printhead.
a.On your computer, open your Kodak AiO Home Center software.
b.Click on the Help (?) button.
c.Click on the Maintenance option.
d.Click on the Clean Printhead option.
3.Print Demo Page.
Press Photo and Copy buttons at the same time for 2-3 seconds or until the printer starts printing then release the buttons.
If issue persists,the printhead on your printer require replacement. Call 1.800.421.6699
Thanks.
Regards,
Neerak21
Aug 04, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
OKI MICROLINE 520 Matrix Printer Logo
1,702 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Clive
Clive
Timothy Van Der...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
