Question about Uniflame Table Top Outdoor Patio Heaters - Endless Summer ES6000 Table Top Patio Heater
My Sunjoy L-PH007PSS-B wont stay lit.
I can get it to light but it will not stay lit when i release the knob.
  • Uniflame Master
  • 2,598 Answers
Blocked pilot too small needs cleaning , or clean end of thermocouple ,or replace thermocouple
Posted on Nov 03, 2012
  • 108 Answers
SOURCE: pilot light wont stay lit
You need to replace the pilot safety switch which is usually a Thermocouple. It is connected by a thin tube from the gas valve to a bulb near the pilot burner. It should be available at Home Depot or online.
Ray
Posted on Dec 17, 2008
SOURCE: Nexgrill patio heater won't stay lit
I called Nexgrill technical support at 1-800-913-8999. They are sending me a new thermo couple to keep the valve open when ignited - so the patio heater will stay on. I needed to give them the serial number (inside the propane tank door) and fax them a copy of the receipt.
Hope this helps.
Posted on Jul 18, 2008
  • 333 Answers
SOURCE: dyna-glo rmc-fa100a won't stay lit after releasing pilot knob
You should hold the pilot knob in at least 1 to 2 minutes, if it still goes out you need to replace the thermocouple. I hope this helps you out.
Posted on Nov 29, 2008
zonaluver
  • 7 Answers
SOURCE: Torpedo heater wont stay lit.
Do you have the serial number or the manufacture date? There are some design changes and I would need to know the year of manufacture to assist accurately. Usually it is a relay or the thermocouple connection that will affect the unit staying lit.
Posted on Mar 29, 2009
  • 30 Answers
SOURCE: ventless gas wall heater. Pilot lights but wont stay lit.
The thermocouple may be worn out.
The thermocouple may have come loose from the valve.
The ODS pilot may be clogged with dust or lint and may need to be cleaned with air(less than 30psi)
The valve or regulator may be faulty.
Posted on Mar 04, 2010
Oven lights but then flame goes out as soon as I release the knob
The flame sensor seems to be bad.
When I light my pilot light, it stays on till I release the button ...
askville.amazon.com > Home > Home Improvement
Mar 18, 2008 - Similar Questions: light pilot stays till release button suggestions ... If you have held it for a long time and it still won't stay lit, then your thermocouple is bad.... the gas valve doesn't think a flame is burning the gas coming out of the pilot ... less likely but somewhat common is the gasvalve... if the knob you are ...
Troubleshooting Gas Range and Oven Problems ' Back ...
blog.etundra.com > Tundra's Tech Talk
Dec 15, 2015 | Fisher Paykel Fisher & Paykel 24-in...
Village series QV32B pilot light won't stay lit
Classic symptom of a malfunctioning thermocouple. When you press the knob, you force the gas valve open so gas will flow. The function of the thermocouple is to confirm that the pilot is lit and allow gas to continue to flow when you release the valve. A new thermocouple is not that expensive. Good luck!
Jan 05, 2015 | Heating & Cooling
Schematic patio heater sunjoy g ph018pss
You will not be able to blow through a gas valve when it's disconnected. You may have air in the lines which would cause the pilot to go off when knob is released if not held in long enough. Try lighting again. Once the pilot lights - hold knob in for 5 minutes then release. Try twice, if pilot will not stay lit it's probably the thermal coupler. (metal prong right next to flame of pilot burner.)
Mar 13, 2014 | Heating & Cooling
NEED REPLACEMENT GAS LINE
I have a Sunjoy industries stainless steel patio heater l-ph007pss-b that I needs a propane fuel hose
Dec 06, 2013 | Uniflame 200209 Open Flame Patio Heater
The Sunjoy MLPHO18PSS will light but will only stay lit for about 15 minutes and then it goes out. We've replaced the propane tanks thinking it was low but that wasn't the case. Thank you! shar...
More than likely, the Thermocouple is loose where it attaches to the control valve. Or the Thermocouple is going bad.
Sunjoy is manufactured by Uniflame, which is owned by Blue Rhino Corp.
If you end up needing to purchase a new Thermocouple call 800-672-1142
Hope this helps resolve your problem.
Feb 26, 2011 | Uniflame 200209 Open Flame Patio Heater
Pilot wont light
If the pilot light goes out when you release the primer,then the thermocouple is bad.You can try to adjust the thermocouple,if it can be.It needs to be in the pilot flame.If the thermocouple is not in the flame,it will not stay lit.If you can not get the pilot to light at all,with the primer pushed down,then replace the regulator.To light the pilot light,you need to turn the dial to pilot.Then press the primer button down and hold it.The primer is either built into the turn knob,or it is a res button.Hold the primer down,and light the pilot,continue holding the primer down for at least 40 seconds.Then release the primer slowly,and if the pilot light starts to get weak,and try to go out,then push back down,and hold 30 seconds more.After the pilot stays lit,turn the knob to furnace or low,or whatever the directions say.
Oct 19, 2009 | Heating & Cooling
Mar 29, 2009 | Reddy Portable Forced Air Propane Heater...
Hope this helps.
Jun 01, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Heating & Cooling Logo
453 people viewed this question
Top Uniflame Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mike
Are you an Uniflame Heating and Cooling Expert? Answer questions, earn points and help others
