Question about HP Deskjet F340 All-In-One Printer
I have a problem
My printer will print but it will not scan..i push the scan button and the power light just blinks....
  • Mohammed Rizwan
    Mohammed Rizwan May 11, 2010
    Hi
    Does it makes photo Copy???
    Thanks
    Rizwan
    Guru:
  • 731 Answers
Hi
Please reset the printer
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
NVM Reset:
--Take the Ink Cartridges out.
--Unplug the printer power cable while its ON.
--Press and hold Cancel and Plain paper simultaneously, while holding them insert the power cable and release the button after 10 sec.
--Insert the cartridge and check the printer
Thanks
Riz
Posted on Jan 08, 2009
Why does my HP 1500 prints a test page every time I begin touse it???
HI
As soon as the printer prints the test page or alignment page place it on the scanner glass (Place the printed side down) before that Examine the scanner glass and white scan backing. Clean the scanner glass and scan backing if they are not clean. To clean the scanner glass and scan backing, use a soft cloth towel slightly dampened with clean water.
After That press scan on the printer button panel it will resolve your issue.
Try to double check it by turning it off and turning the printer back on after 2 minute's. If still the problem exists call HP Total Care 800 - 474 - 6836 if you are from US/Canada.
) Lift the lid of the product.
2) Place the top of alignment page face down in the right front corner of the glass.
3) Place the alignment page face down
4) Close the lid.
5) Press the Start Scan button.
6) The Power button light will blink during the alignment process.
7) After the Power button light stops blinking, alignment is complete.
Aug 04, 2010 | HP Office Equipment & Supplies
Epson Stylus CX6600 does not print
Suggest you try resetting the waste ink counter on this printer to see if it will then allow it to print again.
  1. You will see big button on your printer like power on (this is on the left
  2. side), black & white photocopy, color photocopy, and then the stop button (these are on the right side).
  3. first turn off your printer
  4. push the b/w + color + stop buttons together and hold
  5. push the power on button and hold (so you'll now be holding down 4 buttons together)
  6. Don't release all the buttons until you see the light indicator is blinking and then a message display on the lcd
  7. release all the buttons
  8. push the color button (once)
  9. turn off the printer
  10. turn it on again
IF this works you will then need to fit an external waste ink tank as soon as possible to ensure you don't end up with a major headache (ie: ink swimming pool!) under your printer.
Instructions for completing the modification are available if you google your printer model and "waste ink".
Jan 17, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Error number 1700 canon s9000 printer
knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
Waste Ink Tank Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
1. power off Printer
2. Push and hold resume button and push power button
3. Hold Power button and release Resume button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and stop.
6. When green light on, push resume button 4 x
7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
Aug 20, 2008 | Office Equipment & Supplies
Scanner on HP psc 1315
Check the power and the data (USB) cables in the printer...check both ends...
Check :-
# The printer powers on properly
# There also can be problems with the printer driver
# and also internal printers....
Jul 30, 2008 | HP PSC 1315 All-In-One InkJet Printer
Scanner
Check :-
Try reinstalling the printer driver...
<PLEASE RATE ME AS FIXYA>for my help......................
AAAGGGHH! Cannon i9100 printer WON'T Print...can't get help
jast go in control panal in parinter doble cilck on printer icon cancel all the print documets try this mthrod & tell me what happen
Feb 26, 2008 | Office Equipment & Supplies
Printer
It will not print when power button blinks, you must clear jam or reset until power button is on steady.
Feb 11, 2008 | Lexmark X1270 All-In-One InkJet Printer
Hp deskjet f380
I have experienced this before...
Disconnect the printer and remove the installed drivers, that is to remove the virus-infected file or a corrupt printer driver.
Now re-install the printer and the driver.
Fixya me on this one...
Feb 08, 2008 | HP DeskJet F380 All-In-One Printer
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
236 people viewed this question
Seeker5211
Seeker5211
