Question about Philips Televison & Video
Philips DPTV 310, 60PP935217 We got this tv. As it was brought, they took out the front glass to transport. Question is. There are 2 glasses. Wich glass, in wich order, and which side has to be Built
Plilips DPTV 310, 60PP935217 We got this tv. As it was brought, they took out the front glass to transport. Question is. There are 2 glasses. Wich glass, in wich order, and which side has to be Built in. Both glass and 4 all sides are different. (actually there are 3 glass, but 1 is taped to a other glas)?
    Top Expert:
  • Philips Master
  • 14,553 Answers
The pair taped together usually are the inner and it is possible to put in backwards----should have marked this with masking tape before removal which is rarely needed to transport this set---cover with heavy quilt and face forward in a pickup etc so wind does not **** screens out.
Posted on Nov 03, 2012
SOURCE: convergence problem???
you must move red and blue lines into the green. change red to blue by useing the select button on the remote. till all convergance lines are white
Posted on Feb 02, 2008
  • 9 Answers
SOURCE: I have a Mitsubishi WS-A48 TV. The plexi-glass
not personally order them no, mitsubishi will not let private parties order servisable parts, so u will need to order it through a service man, then, take of the back part side part etc... can be done, but before u get to it u will feel like u own a hardware store with all the screws they put in. be carefull not to touch the mirror!!!
Posted on Mar 18, 2009
Ecollier2012
  • 3459 Answers
SOURCE: my philips 60
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Posted on Sep 13, 2009
  • 167 Answers
SOURCE: hour glass shaped image after the tv is on for awhile
Probably a power supply problem.
Get a new TV...
Posted on Dec 27, 2009
  • 19 Answers
SOURCE: I have a HDTV 524159 RCA, it has an hour-glass
Hi Sandy, the problem with your TV is called "convergence". It can be a problem with the convergence board or more likely in this model in the power supply or deflection circuits. Unfortunately, troubleshooting by a technician is required.
Posted on Apr 22, 2010
Testimonial: "Very helpful with the problem I have encountered with my TV. Very thorough with what my problem is and what all may need to have fixed. "
Need to glue outer cold glass door to the door frame.. in cadco convection oven
not sure which to use but id go to a window auto glass shop and inquire
Dec 12, 2012 | Cadco Ovens
Both the front glass and dark glass right behind the front glass are shattered....assuming this is the extent of damage, can these be replaced and for how much? The tv is 42PF9630A
In my somewhat admittedly limited experience, the replacement of any display screen, plasma or LCD, the cost exceeds the price of a new set.
Mar 30, 2011 | Philips 42PF9630A 42 in. Plasma Television
I have a 2003 volkswagen jetta. i need to remove the glass on the front drivers side and front passenger side doors and replace it with new glass.after i remove the door panel how do i do this?
The panels have 3 t20 torx screws on the bottom and one philips head near the mirror. Under pull handles there are 3 philips on the drivers and 2 philips on the passengers sides. Pull the panels from the bottom and lift the panels up. There are 2 black rubber plugs in each door, pop each plug out and the glass is held in place to the clips on each side with either a 10 mm bolt or t30 torx bolt. Move the glass to the point where you can see the bolts, loosen, but don't remove the bolts. Once loose, you can pull the glass loose. Once loose, lower the window a bit, angle the rear of the glass up and pull it out. The glass may be epoxied in place, as VW had a problem with windows coming loose. If so, try to pop the rubber in the clamp loose (above the bolts you see through the holes) and reinstall it with the window removed.
Dec 22, 2010 | 2003 Volkswagen Jetta TDI
Plate glass broken
My concern is that if this unit took a hard enough bang to bust the glass, what else suffered?
Did you transport the printer yourself or did a moving company do the work? If you moved it, take it to a Canon authorized repair center and get an estimate. If a moving company transported the unit, contact them and place an insurance claim on the damage. By law, the moving companies are required to carry damage insurance.
May 20, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
I took apart to clean glass - think it is assembled wrong!
that glass( slanted one) is supported on top by the metal plate ( problably 3 inches wide) running across the top of the metal cover(covering the insulation level) the glass inserts inbetween 1 or 2 tabs in the metal support, it then lays on an angle against the metal cover( hoilding the insulation level) and is secured by the 1 in thick angled metal retainer. hope this was helpfull.
Mar 14, 2009 | KitchenAid Architect Series KEBC107KSS...
Hourglass Shape
If there is a hour glass shape to the image but convergence is normal, there are 2 possibilities. You either have a pincushion correction problem or if the hour glass seems to be moving, it will be an open filter capacitor in the power supply.
Unless you are electronically inclined troubleshooting this issue will require a factory trained service technician. You can expect to spend $300-$400 to fix this.
Feb 17, 2009 | Philips 60PP9202 60" Rear Projection...
Finding mirror glass replacement in projection tv
THe part n umber will be dependent upon the exact model number of your set. Can you please post that model number. This entry is listed under model number PT-47WX49. Pleaes confirm the model so we can get the proper part number.
Thanks,
Dan
Feb 09, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Looks like 3D with out the glasses
you need the phillips dptv 305 - dptv345 chassis convergence repair kit which contains both convergence ics and all feed resistors and also free installation instructions with pictures. heres the link.
http://servicemanuals.vstore.ca/
Jan 22, 2009 | Philips Magnavox 51MP392H Rear Projection...
Remote code
0-6-2-5-9-6-MENU
Google Philips DPTV 305--310.pdf
Complete Service Manual
Jan 14, 2008 | Philips 60PP9502 60" Rear Projection...
Philips 37PF7321D LCD TV
Try to replace the power supply board of your tv.
Nov 15, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
96 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
