Question about Sharp LC-15SH1E 15 in. EDTV-Ready LCD Television
At the moment on my bench I have 14 Sharp LC15SH1E TVs and they all have the same fault. The common fault is as follows. Upon power up the standby LED turns green and the unit briefly turns on. A stat
There are no obvious Cap faults and I cannot find information online i.e. a datasheet or service manual to test voltages.
5 Suggested Answers
SOURCE: Sharp TV powers off after 15-30 seconds
FOR SHARP LC-13AV1U TV - is it lighting up with in 5 sec
Posted on May 11, 2009
dsacco86
  • 1077 Answers
SOURCE: Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
Posted on Jun 03, 2009
  • 74 Answers
SOURCE: I have a Sharp LC-32D44E LCD TV. Purchased Oct
If the red light stays on and the tv does not react to any input from buttons or remote... the problem is one 7 pins integrated circuit on the upper side of the power board .the ic is situated on the right side of the power socket .It costs about 2$ and can be replaced by someone with mimimal electronics skills and a 30w solder iron .
Posted on Apr 20, 2010
  • 1156 Answers
SOURCE: i have a tv sharp
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem, take care in handling the fault.....
Posted on May 25, 2011
SHARP TV MODEL LC-46LE830U WILL NOT TURN ON. I HAVE REPLACED THE POWER SUPPLY BOARD WITH NO HELP. IT HAS 2 BLINKING LED LIGHTS FOLLOWED BY 5 BLINKING AND REPEATING AGAIN. WHAT IS MY NEXT STEP?
It sounds that the main board fitted with your Sharp television is of Philips. Those blinks are fault indications, and you should follow the procedure of counting the number of blinks, as you do with Philips brand LCD TVs.
From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
May 11, 2017 | Sharp Televison & Video
Sharp LC-70LE650U blinking code 2 slow 5 fast
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Some models of Sharp TV uses Philips main board. If your TV has such a board fitted, you should follow the blink count procedure for Philips. From your description itself, I do understand that your TV is fitted with such a board. The blinking code procedure seems so.
Nov 05, 2016 | Sharp AQUOS LC-70LE650U 70" LED TV...
What do you need help with? sharp LED TV model LC32LE265M when powered On only the red indicator light keep blinking, no sound no picture no backlight.
With some models of Sharp sets, they have used Philips main board inside. If your set is of that type, you should follow the LED blinking procedure of Philips.
Sep 30, 2016 | Sharp Televison & Video
I have a sharp LC-60LE831U tv that is flashing a code on the power light 2 slow 5 fast. No picture or sound and factory resets I have tried do not seem to work, any ideas or suggestions.
Some model Sharp sets, they have used the Philips main board. Yours should be one like that. These blinking codes denotes it. That means; your TV is a not duplicate one. Sharp did it for some sets of their own. So, when you try to count the blinking codes of such set, you should follow the way of how to count the blinking codes to Philips TVs.
Aug 23, 2016 | Sharp Televison & Video
I have a Sharp LC 52LE640U TV. It has a 1 Blink Fast and 1 blink SHort. I can Power Tv on with CH down/ Vol Up upon power up and it will show display. Only problem is; half the backlight on left si
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Some models Sharp TVs uses Philips kit. If yours is such, the blink count procedure is entirely different. It is not direct.
Jan 11, 2016 | Sharp LC52LE640U 52 inch 120hz AQUOS LED...
I have a Sharp 70" (LC-70LE632U) LED TV. When you turn it on, the front led is on, but no screen. After a few seconds, the front led starts 5 short and 2 longer blink and continue this way constantly.
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Nov 12, 2015 | Sharp Aquos LC-70LE632U 70 Inch 1080p...
Sharp TV LC-70LE750U was first showing horizontal banding distorted picture(http://imgur.com/UmEZi7v), now no picture when powered on. LED indicator would blink twice then follow by 5 faster blinks.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jun 12, 2015 | Sharp AQUOS 70 " Black 1080P LED 240Hz...
Sharp LC-37SH2OU FAILS TO POWER UP.BLINKING POWER LED
Feb 12, 2015 | Sharp Televison & Video
Sharp LC-C6077UN power led flashes green will not power on
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Sep 30, 2014 | Sharp Aquos Televison & Video
How to fix sharp crt tv model 14v-l70m,standby red lights only and will not power on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Jul 28, 2014 | Sharp Televison & Video
Sharp LC-15SH1E 15 in. EDTV-Ready LCD Television Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
