Question about Garden
John Deere 310D backhoe transmission won't engage
SOURCE: Won't start John Deere 310D Rubber tire backhoe
wont go forward or back
Posted on Jun 24, 2010
  • 246 Answers
SOURCE: My fuse keeps blowing on my neutral safty switch
Hello williamhowar:
>>As I am Sure you are Aware, Most Backhoes do a Lot of Bouncing and Jarring. LOL.
>>If you can Trace the Harness, then Check of a Bare Wire that is May be Touching the Unit.
>>If the Harness is Good, then I will Require some More Information about this Unit in Order to Assist you Further.
>>Send me the Model Numbers Off the Unit, Please. With these I can Locate the Proper Manual and Better Assist you.
Thanks.
Respectfully
jbridger (John)
Posted on May 14, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
miket756
  • 2702 Answers
SOURCE: John Deere 210 C backhoe loader - quesion on hydraulic fluid
yep there is!
Posted on Jul 13, 2010
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
What year is the following john deere backhoe 310G :t0310gx911769
You just go to the link I attached I'm sure you will get the solution of your problem.
Apr 25, 2017 | John Deere Garden
Where is the serial number located on a john deere 510d backhoe..so i can find out the year of the backhoe
Diane, JD 510D VIN# Location: On older models plate is attached on outside of frame behind either left or right front wheel. On newer models VIN plate is attached just above left (Highway) side cylinder arm. Same location as Caterpillar. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://cppsocal.org/wp-content/uploads/2014/04/Heavy_Equipment_Catalog_Vol_5.pdf
https://www.oswca.org/uploads/combatting-heavy-equipment-theft-2015.pdf
Thread where is Serial number for 1977 John Deere 510 hoe
Serial number plate location for john deere 510d backhoe Google Search
Jun 20, 2016 | John Deere Garden
I have a 310d john deer backhoe will not move
Hi Robert:
Cool!
Will need some more info.
- Does the motor run.
- Do the hydraulics work.
- Are the brakes locked on
- Is there fluid in the transmission?
- Do you have any experience with equipment.
If you reply as a comment to this post I will receive it, and may be able to help.
Dec 06, 2015 | Garden
Transmission won't engage
sounds like its time for a new mower
Apr 24, 2012 | John Deere Garden
If you can test the alternator after it has run for 2 hours that would be helpful,if it is quiting after it gets hot then it likely need the stator replaced in the alternator.If this is not the case,then you need to either replace the park lock solenod valve or the instrument cluster is overheating a transistor and failing,this will cause the safety interlock circut to engage.Also the operator pressence switch may need to be relocated if the operator is less then 150lbs.Let me know how you make out,thanks.
Apr 25, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
744 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
